My ESS TS2 install, it all starts NOW! :) - Page 17 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 06-05-2008, 09:57 AM   #321
elite53
My Ride: Twin Screwed 325Ci
The shudder will go away in time I promise. You just need to get some more miles on that new clutch. Not sure about the odd noise though?
elite53 is offline   Reply With Quote
Old 06-05-2008, 01:48 PM   #322
fmzip
My Ride: '08 328xi / '01 530i
Thanks for the encouraging words!
I really poked around while I was under the car replacing the transmission mounts. I thought it was a heat shield possibly, but it wasn't. I need to get my ZHP muffler installed to eliminate some resonating vibrations. Waiting to hear back from a fellow fanatic on installing it, otherwise I will need to find a shop....
fmzip is offline   Reply With Quote
Old 06-05-2008, 08:43 PM   #323
fmzip
Originally Posted by Lemonsqr View Post
How hard are these to install? Is there a link to a DIY....too lazy to search this time
Get under the car, support tranny with a floor jack, remove the 4 bolts for the crossmember, remove the two nuts for the tranny mount that pass thru the crossmember. Once the crossmember is out, remove the nuts from the top of the tranny mount.
This takes all of 5-10 minutes.
Installation is as simple, make sure you secure the tranny mount to the crossmember first, install crossmember, lower tranny onto mount, attach top bolt.
It's imperative not to load the bushing before torquing it to 16ft lbs. 16ft lbs is not much more than hand tight. If you don't follow these simple guidelines, you have a good opportunity to introduce vibration.
Old 06-19-2008, 03:37 PM   #324
fmzip
I was wondering if this odd sound I have since the clutch install was related to the exhaust. What do you guys think of the looks of this soot on the exhaust, possible leak?
Old 06-19-2008, 03:49 PM   #325
TxZHP04
My Ride: ESS TS2+ ZHP
Is this a hole that I circled in red?
Old 06-19-2008, 10:31 PM   #326
fmzip
might be.....the exhaust gets dropped when pulling the tranny, correct?
Old 07-15-2008, 03:18 PM   #327
fmzip
Just an FYI for the next person installing a TS2......do not tywrap back the cable for the intake side cam position sensor as I did in this photo. When your sensor fails, there will be no way to reach it to unplug it. Ask me how I know??!
It's the item in the left of the photo with all the electrical tape wrapped around it
Old 07-15-2008, 04:13 PM   #328
Lemonsqr
My Ride: 2001 TiAg 330i
So did you have to remove the TS mani??
Lemonsqr is offline   Reply With Quote
Old 07-15-2008, 08:43 PM   #329
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
that looks like an exhaust leak/hole
damn Fran - you are having a hell of a time
and +1, did you have to remove the mani
/_________\
O==[][]==O
Old 07-15-2008, 08:52 PM   #330
fmzip
Fortunately I did not..........what a PITA though!
To top it off, I just finished putting everything back together, took it for a spin and the car was stumbling badly. I checked for a code and it's once again the intake side camshaft position sensor.
I bought the sensor from BAV Auto......it was the obsolete PN, it also was a third of the price of what the dealer wanted for one. Sometimes it just doesn't pay to be cheap!
Can there possibly be another reason which is causing the sensor to fail??
Old 09-07-2008, 02:07 PM   #331
330i ZHP
330i ZHP's Avatar
how's it running these days?
/_________\
O==[][]==O
Old 09-07-2008, 08:13 PM   #332
330i ZHP
330i ZHP's Avatar
ok, who is using the new pulley system? Does the belt come into contact with itself between the two pulleys?
/_________\
O==[][]==O
Old 09-07-2008, 08:44 PM   #333
TxZHP04
No, there should be a couple of mm between. It is close though.
Old 09-07-2008, 08:49 PM   #334
330i ZHP
330i ZHP's Avatar
thank you - i cant see any space between them...but i also dont have the SC in yet for the last pulley to apply pressure on the belt.
/_________\
O==[][]==O
Old 09-08-2008, 06:39 PM   #335
fmzip
I can't stand the clutch.......squeals like a pig constantly!
Never the less......I love the TS2! I am reminded daily with my 530i how much torque the 330 has in comparison!
Old 09-08-2008, 08:46 PM   #336
330i ZHP
330i ZHP's Avatar
i installed the CM3 clutch and the JBR flywhl...i hope it isnt as noisy as yours...sorry for recommending it
/_________\
O==[][]==O
Old 09-09-2008, 12:53 AM   #337
HighBoostin330
My Ride: 2002 Stock 330Ci
Mines is quiet and VERY rarely squeals. Maybe I am lucky?
HighBoostin330 is offline   Reply With Quote
Old 09-09-2008, 08:02 AM   #338
fmzip
No hard feelings here............I plan to go organic when I find myself a six speed.
