Thread Tools Search this Thread Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Old 08-04-2008, 02:57 PM   #1
dheafey
My Ride: 2003 330i
Accident, Air Bag deployed, car won't start
Gang,
apologies for the cryptic title; I'm trying to make sure it gets picked up in searches for future reference.
I was in a somewhat nasty accident with my '03 330i. It's a bit hard to describe, but I was on a 2 lane 1 way street making a left-hand turn into a driveway when I was hit from behind. The driver of the second car hit me broadside on the driver's side denting both doors and the rear quarter. The car spun 90 degrees counter-clockwise and came to rest after the right rear tire hit the curb. Both rear tires were severely bent in, damaging the axles and rims.
Both the driver's side airbag and curtain deployed. After almost 3 months in the shop (my autobody guy is very meticulous, but I'm losing my mind!!), it's almost ready. The issue is he can't seem to get it started. The airbag circuit is not connected and both of us think that may be the culprit. It would seem to make sense as a safety feature; you wouldn't want someone driving the car around without properly functioning airbags. However, I thought I'd ask here: does my model BMW have an ignition shutoff "feature" when the airbag circuit is disconnected?
dheafey is offline   Reply With Quote
Old 08-04-2008, 03:04 PM   #2
ModBargains
ModBargains's Avatar
My Ride: M3
Jeez, sorry to hear that. I hope no one got hurt. From what I remember there is no shut off feature. Has he checked all fuses and relays?
Blake Brunner|blake@ModBargains.com|(714) 582-3330 ext. 8011
We Specialize In:
BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts | BMW Tail Lights |
BMW Wheels | BMW Intake
Hours
Check out our Blog for updates!
ModBargains is offline   Reply With Quote
Old 08-04-2008, 03:04 PM   #3
davidwarren
Halfway to 2L
davidwarren's Avatar
My Ride: 2010 335i
there is a charge on the positive terminal of the battery that goes off and disconnects the battery when the airbags are deployed.
You down with UCC? Ya you know me!
sowing the seeds of jiggery pokery
davidwarren is offline   Reply With Quote
Old 08-04-2008, 03:08 PM   #4
justanotherokie
My Ride: 2002 330i
Check the trunk for a Green pull wire. It shuts off fuel flow. You need to reset it. (By the battery)
justanotherokie is offline   Reply With Quote
Old 08-04-2008, 03:18 PM   #5
davidwarren
Halfway to 2L
My Ride: 2010 335i
are you sure that's not the manual release for the fuel door?
Old 08-04-2008, 03:30 PM   #6
iceberq
My Ride: 02 LSB M3
sounds like it but my body shop told me that straight up. it's hard to believe his body shop wouldn't know that already?
iceberq is offline   Reply With Quote
Old 08-04-2008, 03:32 PM   #7
rosario.luis
My Ride: 2000 E46 323i
The green cord is the manual release for the fuel door. I had that problem when once when my airbags got deployed but a hole on the street. There is this wire that gets damanged when the computer detects a crash. This cable is quite expensive and comes from the battery in the trunk to the fron of the car. Check that cable out that might be the problem
rosario.luis is offline   Reply With Quote
Old 08-04-2008, 04:29 PM   #8
JK1150
My Ride: 2004 325CI
i have an 04 but i remember reading that the battery is disconnected in the event of a crash...
JK1150 is offline   Reply With Quote
Old 08-04-2008, 04:37 PM   #9
davidwarren
Halfway to 2L
My Ride: 2010 335i
I think this is what you need:
http://www.realoem.com/bmw/showparts...03&hg=61&fg=10
Old 08-05-2008, 01:00 PM   #10
dheafey
My Ride: 2003 330i
All,
thanks very much for your replies and info. I've taken the posts to my autobody guy and will post the final solution.
Old 08-12-2008, 12:32 PM   #11
dheafey
My Ride: 2003 330i
Latest update: I had my bodyshop guy call Turner Motorsport in Amesbury, MA. They knew exactly what the issue was, so once I get it back, I'll document it in this thread. I'm lucky enough to live 30 miles from Turner or, not so lucky depending on your viewpoint. Living that close could cost me a fortune.
Old 08-15-2008, 03:12 PM   #12
dheafey
My Ride: 2003 330i
Positive cable to starter/alternator
This is, indeed, what happened. The interesting thing is it disconnects the positive terminal from the starter/alternator and not the rest of the car; when I turned the key, everything in the interior worked (lights, radio, etc...), but the car wouldn't turnover. Once the wire was replaced buy Turner, all is well. Thanks to all for your advice and information.
Old 09-30-2008, 01:32 AM   #13
chu77
My Ride: E46
Can you just repair the "fuse" inside the cable instead?
chu77 is offline   Reply With Quote
Old 09-30-2008, 02:08 AM   #14
BodyMan
My Ride: 2002 325i
NO you cannot. Its not a fuse. Its a pyro charge just like an airbag.
When your airbag is deployed, your positive battery terminal is cut, shutting down the engine, unlocking your doors, turning on your interior lights on, and turning your flashers. And it also sets off your seat belt pre-tensioners. A lot happens in a accident.
You need the part in post #9
BodyMan is offline   Reply With Quote
Old 09-30-2008, 10:14 AM   #15
easyman
My Ride: MKV GTI 4 Door
I just jump started my car after my crash to move it around the body shop. Nothing else need in my case.
2007 GTI 4 Door (MKV)- Current
2010 Acura TSX (cu2) - Retired
1987 BMW 325i (e30) Vert - Burned Down
2002 330i (e46) - Retired
ZPP - ZCW - ZSP - Nav - Bi-Xenon/85122+ - Mtech - 18" CSL - FSD's - 4300k Fogs-
Sig courtesy of fskarboe
easyman is offline   Reply With Quote
Old 09-30-2008, 10:15 AM   #16
easyman
none of that happened to me, atleast not that i can remember. But only my side airbags blew.
Old 10-11-2008, 10:28 AM   #17
chu77
My Ride: E46
Does the whole cable needs to be replaced? Or just the part connecting to the battery? I bought one from ebay and they just gave me the black box on the terminal.
Old 10-11-2008, 10:35 AM   #18
howie
My Ride: CLK55 AMG, E90 335i
Send a message via AIM to howie Send a message via Yahoo to howie
I didn't know that...good info!
howie is offline   Reply With Quote
Old 10-16-2008, 09:55 AM   #19
chu77
My Ride: E46
Did you guys also know that the airbag comp cuts off the fuel too if the airbags were to deploy
Old 10-16-2008, 10:13 AM   #20
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Yes briefly then fuel is restored the next key cyle.
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
accident, air bag, airbag, won't start
