Thread Tools Search this Thread Rating: Thread Rating: 474 votes, 4.95 average. Display Modes
Old 09-12-2008, 06:18 AM   #341
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
sedan and coupe tails are very different in shape
there are aftermarket LED tails, but the light pattern is iffy at best and the inside panel isnt a clean OEM look and the wiring is exposed instead of covered behind a nice lighted panel....can it be modified? yes, but only if you are a talented DIY person.
/_________\
O==[][]==O
Old 09-19-2008, 12:18 PM   #342
gra_2472
My Ride: 2005 BMW 330CI
Very useful information. Thank you for your work.
gra_2472 is offline   Reply With Quote
Old 09-26-2008, 10:09 AM   #343
kevinterkelsen
My Ride: 328 ci (TS 3)
M3 springs
Hi, i have read your answers on M3 suspensions starting post 11 and 317 - but it would be really helpful for me to know is there any technical difference that will make it impossible to use m3 springs on a e46 coupe?
I'm asking because I need stiffer springs, because i have a TS setup + a cast iron block adding up to 50 kg to the front axle load. My current springs cannot cope under spirited driving and my choice is to go with 330diesel springs (front axle load 1030) or M3 springs if they can be used at all. I'm partial to Eibach and would buy their spring set for either 330d or m3.
Your help would be greatly appreciated, again :o)
kevinterkelsen is offline   Reply With Quote
Old 09-29-2008, 03:03 PM   #344
GGray
My Ride: 00 330it Wagonator
Wink Putting an E46M3 rear into....
My touring I bought an entire E46m3 rear assembly...
I figured I would post here first...I may make a thread on the conversion once I get it finished... Probably be a month or so.
What you get!
3.64 gear set with LSD!
Big brakes for the rear
wagonator project beggining
GGray is offline   Reply With Quote
Old 09-30-2008, 10:39 AM   #345
natty99
My Ride: 2005 BMW M3
What you get!
be careful about not throwing off your brake-bias when you put those larger brakes on in the rear.
natty99 is offline   Reply With Quote
Old 09-30-2008, 10:40 AM   #346
natty99
does anyone know if the armrests in the door of the M3 fit the 330i ZHP sedan? I'd love to add those aluminum trimmed armrests into the ZHP
Old 09-30-2008, 10:47 AM   #347
rorschach
My Ride: '01 318i
Doubt it, since the coupe doors are longer and the shape of the armrest is different. They are interchangeable between M and non-M coupes, though.
rorschach is offline   Reply With Quote
Old 09-30-2008, 10:50 AM   #348
GGray
Wink Its fine
I have ALCON four pistons on front already, its fine I checked. I also have a E46M3 Master cyclinder coming.
Main reason is so when I put the LS1/T56 in next year it won't destroy the diff. An E46M3 rear will handle 500+rwhp...
Old 09-30-2008, 10:53 AM   #349
natty99
Well, I know the M3 doors are longer, but it's not like the M3 armrests run the length of the door like in the sedans. So they seem like they would fit.
Old 09-30-2008, 11:26 AM   #350
SWINFORD
///PIITB
SWINFORD's Avatar
My Ride: Low Life Marie
Send a message via AIM to SWINFORD Send a message via MSN to SWINFORD
They will not fit
Swinford-Hypnotyzd : Dirty South-Swinny
| Hypnotyzd FB |Tischer BMW|
SWINFORD is offline   Reply With Quote
Old 09-30-2008, 11:44 AM   #351
natty99
Originally Posted by SWINFORD View Post
They will not fit
cool, thanks for the definite answer
Old 09-30-2008, 11:46 AM   #352
SWINFORD
///PIITB
SWINFORD's Avatar
NP
Old 10-01-2008, 09:38 AM   #353
Mc 007
My Ride: 325ci Performance
hello,i would like to put the M3 hood on my 325ci,what i must buy and do to do this work?
thanks
Mc 007 is offline   Reply With Quote
Old 10-09-2008, 08:38 PM   #354
jkb2one
Account Under Review
My Ride: e46 M3
How can i put paddle shifters on my 325i e46.
jkb2one is offline   Reply With Quote
Old 10-13-2008, 09:19 PM   #355
Phil323i
My Ride: 2000 323i
very helpful, thanks!
Phil323i is offline   Reply With Quote
Old 10-22-2008, 11:43 PM   #356
diablorojo
My Ride: Supercharged 330i
Hello all,
Hope somone could help. I converted my BMW 330i guages to M3 guages. Everything works except my stepronic gear indicator (i didnt expect it to work) and more importantly the traction control is turned completely off!
how do i fix?
Started ESS...ended CUSTOM!
diablorojo is offline   Reply With Quote
Old 10-25-2008, 01:28 PM   #357
m-tints
My Ride: 2004 E46 Coupe
Send a message via Yahoo to m-tints
any instructions or guides on how to ajust the fenders to fit the m3 bonnet on non m3 coupe
thanks
m-tints is offline   Reply With Quote
Old 10-26-2008, 12:22 PM   #358
Mc 007
look here!
http://forum.e46fanatics.com/showthread.php?t=575340
Old 10-27-2008, 03:10 AM   #359
Darkoz
My Ride: E46 325Ci
Originally Posted by diablorojo View Post
Hello all,
how do i fix?
How did you get around the "tamper dot" showing instead of your correct mileage?
Darkoz is offline   Reply With Quote
Old 10-27-2008, 06:06 AM   #360
LOLAS E46
My Ride: 01 330CI SPORT PAK
hello all,
hope somone could help. I converted my bmw 330i guages to m3 guages. Everything works except my stepronic gear indicator (i didnt expect it to work) and more importantly the traction control is turned completely off!
How do i fix?
hey what happen to your milage?? Did it keep your or the m3??? I really like to know
SILLY RABBIT CIVIC IS FOR KIDS
LOLAS E46 is offline   Reply With Quote
