Rear camber arm replacement DIY? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-24-2007, 02:13 PM   #1
thefitter
My Ride: Is tight all night!
Anyone know of a rear camber arm DIY for the E46?
I found one for the E36 but Id like to find one for the exact car Im working with.
It looks very accessible and pretty straight forward but Id still like to have a detailed DIY so I do not screw anything up or drop something on my face.
Im putting on GC adjustable rear camber arms with urethane bushings.
thefitter is offline   Reply With Quote
Old 11-24-2007, 11:47 PM   #2
FTWeisse
My Ride: has no hip-hop rimz
I would take it to a shop to do it...you're going to have to drop the differential housing to be able to remove the big bolts that go through the top of the control arms and the ears/half-shafts are in the way.
Old 03-24-2008, 09:06 AM   #3
BDUB328I
My Ride: bmw 328i S54 sedan (
anyone know how long this would take a shop to do?
BDUB328I is offline   Reply With Quote
Old 09-08-2008, 03:29 PM   #4
Thunk In The Trunk
My Ride: 2000 323i
A socal stealership quoted me around $1100 to install the spc adjustable control arms and do an alignment. RIP OFFFFFF! This is a job u can do but you must do the right steps in the right order to do it without a humongous head ache. I Wish someone would do a write up. maybe ill do one tonight.
Thunk In The Trunk is offline   Reply With Quote
Old 09-08-2008, 06:29 PM   #5
Tom Busby
My Ride: 2001 325i, 1995 318i
Do you mean you are replacing the lower control arms? The really thin OEM arm, parallel to the axle?
These are not hard to take off but you need to be able to hold the diff' up with a floor jack, after you take off each caliper bracket, rotor, shock and spring, lower the muffler, and so on. Plan on 6-8 hours for normal amateur worktime.
Tom Busby is offline   Reply With Quote
Old 09-08-2008, 06:36 PM   #6
xcelr8dbmw
My Ride: 2007 X5 4.8
you also have to remove the pasenger side rear axle. i got lucky and a mec. i know at the stealership snuck my car into the shop, did the adj. arms and replaced a leaky seal on the diff, did an alignment all for 300 bucks.
Cyanide & Happiness @ Explosm.net
xcelr8dbmw is offline   Reply With Quote
Old 10-03-2008, 11:13 AM   #7
Devious1
Invalid User
My Ride: 330ci
Send a message via AIM to Devious1
any write ups?
Devious1 is offline   Reply With Quote
Old 10-05-2008, 12:26 AM   #8
m3m3me
My Ride: 2002 M3
Originally Posted by Devious1 View Post
any write ups?
I used my Bentley and Turner Motorsports tech guide to install their camber arms last month. Step by step, inch by inch, it's doable in one day with a mid morning start time. Here's some pictures just to point out the two rear fasteners on the differential to remove and the one forward fastener on the differential and the half-shaft fasterners. It's an involved project if you're all alone on your back on some cardboard. Two heads would be better than one.
Good luck!
http://www.turnermotorsport.com/html/tech_tips.shtml
http://www.turnermotorsport.com/imag...TSU9940B77.pdf
ID:	286967   Click image for larger version
ID:	286968   Click image for larger version
ID:	286969   Click image for larger version
m3m3me is offline   Reply With Quote
Old 10-06-2008, 12:03 PM   #9
Devious1
Invalid User
My Ride: 330ci
^^ nice, i just ordered the same arms.
Old 11-01-2008, 10:44 PM   #10
dakkon
My Ride: e46 330ci/e30 318is
i installed my tms rear control arms in 2.5 hours. i was using a lift though, 1100$ is a freaking rip off.... you only have to unbolt the diff and push it back some..
dakkon is offline   Reply With Quote
Old 12-01-2008, 01:07 PM   #11
Devious1
Invalid User
My Ride: 330ci
anyone else local ever do this install themselves?
Old 12-01-2008, 06:31 PM   #12
vaio76109
My Ride: Race Cars
It's not hard. You'll need to remove the 3 diff bolts so you can wiggle it around to remove the inner bolts. The outer bolts are easy. I don't know why everyone is making this out to be a hard job.
vaio76109 is offline   Reply With Quote
Old 12-01-2008, 06:44 PM   #13
Devious1
Invalid User
My Ride: 330ci
standard tools? i'll have to get under there to check it out.
Old 12-01-2008, 07:39 PM   #14
vaio76109
My Ride: Race Cars
Yup, ~15-22mm sockets and wrenches
Old 12-02-2008, 12:07 AM   #15
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Not hard to do. It shouldn't take more than 2 hours.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 12-14-2008, 07:07 PM   #16
api
My Ride: 03 M3 6-spd
I did this install with friends in my garage. I had the car on jackstands and it was a little bit of a pain. I think $1100 is a steep price. Once I loosened the diff, I just moved it back a few inches and had a friend swap the bolt and rear trailing arm.
MODS: 03 M3, 6MT, PSS9, AFE Intake, Euro Ceramic Coated Headers, El Diablo Exhaust, Turner Motorsports Rear Adjustable Camber Arms, AKG Diff and Subframe bushings, PowerFlex suspension bushings, Sub-frame Reinforcement, 18'x9' square setup & one driver that grins ear to ear everytime he is driving it
api is offline   Reply With Quote
Old 12-29-2008, 01:27 AM   #17
BreakMyWallet
My Ride: B6 A4/ Mini Cooper S
fuk this man it was hard LOL. well its hard with 1 person for sure. 2 people wouldve been much easier.
BreakMyWallet is offline   Reply With Quote
Old 05-14-2009, 08:11 PM   #18
fmzip
My Ride: '08 328xi / '01 530i
So it's just removing or is it loosening the differential bolts? Does the driveshaft need to be removed?
I think there may be an option to cut that upper bolt and use a shorter one. Details are here but sketchy.....
http://forum.e46fanatics.com/showthread.php?t=572194
fmzip is offline   Reply With Quote
Old 10-15-2009, 10:52 PM   #19
pish180
My Ride: 02' M3
Send a message via AIM to pish180
Question... does the diff need to be supported after removing the bolts? If so what can u use to support it while its on a lift?
pish180 is offline   Reply With Quote
Old 10-29-2009, 07:27 PM   #20
api
I had two friends help me do it because I did it in my garage. I am sure you can use a floor jack.
I have not looked at the "short bolt" link but I prefer to have the extra threads to keep the extra threads.
