Old 10-08-2008, 08:57 PM   #1
bimmer323boy
My Ride: 323 CI
Pulling my motor
Can anyone help me out? I ill be pulling my 323ci motor this weekend. Any pointers or things I should know.
bimmer323boy is offline   Reply With Quote
Old 10-08-2008, 09:37 PM   #2
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
This will take some time, but lable EVERY wire you disconnect from each connector. I recommend using a Bentley manual to help with labeling, or simply use numbers to match up the wire to connectors.
If you don't do this, you WILL regret it.
Take your time...
Old 10-08-2008, 10:14 PM   #3
bimmer323boy
My Ride: 323 CI
Thanks will do. Anyone have a DIY guide or something?
Old 10-09-2008, 12:13 AM   #4
Chris-TK
My Ride: Mazda
Why are you pulling the motor?
K.
Chris-TK is offline   Reply With Quote
Old 10-09-2008, 06:10 AM   #5
bimmer323boy
My Ride: 323 CI
The head gasket went in the old motor and i bought another motor and need it installed asap. I lost my garage in the move lol.
Old 10-09-2008, 02:33 PM   #6
zeshon
My Ride: S/C 2000 328Ci
Get a bently manual. It has a very good guide for pulling the motor. Also, why not put a 328 motor in while you're there. It's plug and play.
- Austin
Favorite sponsors
Bavarian Soundwerks | Euro Spec
Mods : Performance : Active Autowerkes Stage 1 C38 • New Subframe and TMS Rear Re-Enforcements • Upgraded VANOS seals • M3 Fuel Baffle • KW V2 • ZHP Control Arms • E60 Short ShifterSound : Bavarian Soundwereks Stage 2 • DICE iPod LinkLooks : Replica M3 Mirrors • Replica M3 Front Bumper • Matte Black Grillz • LED Signals
zeshon is offline   Reply With Quote
Old 10-09-2008, 03:02 PM   #7
mechanicalmadness
My Ride: e46 323CI
Honestly the pull isnt that bad. I recommend taking the hood off as opposed to locking it in the service position. You will need every inch possible. As mentioned before label every plug you pull, and if possible take some pics of the harness routing.
Its open to debate but some of my friends claim that its easier and faster to pull the motor with the tranny, and some say its better without the tranny. i personally do not trust the factory hard points on the motor. With that said i wouldnt pull it with the tranny. Good luck man. If I can get a hold of a scanner Ill scan some of the pages from my bentley manual if you dont allready have one.
Born in the BG Raised all over. No wonder I'm confused.
mechanicalmadness is offline   Reply With Quote
Old 10-10-2008, 08:16 AM   #8
bimmer323boy
My Ride: 323 CI
Thanks alot for the help guys Im gonna go after this tonight, lol. But I was told I had to keep it 2.5 if i upgraded to 326 I needed to change alot of things???
Old 10-10-2008, 08:52 AM   #9
paraklas
paraklas's Avatar
My Ride: ESS TS2 320ci
We (me+mechanic) pulled the engine with the tranny and the exhaust manifold still attached. We only disconnected the hood from its shocks to allow us to rise it a bit more for clearance.
http://www.argyrides.eu/makeyourownsig.jpg
Old 10-10-2008, 02:34 PM   #10
mechanicalmadness
My Ride: e46 323CI
Honestly I dont think you will need to change too much. i have to do a bit of research to confirm the following, but i believe the engine harness should be the same with all of the wires being the same length. Not sure about the ECU however. You might also have to swap some of the sensors if they have different values or manufacturers so as to mach the setup you had on your previous motor. Again i have to do some research to back that statement up with facts because Im just going off of previous experience.
Old 10-10-2008, 10:26 PM   #11
bimmer323boy
My Ride: 323 CI
Thank you guys so much I was scared hahahahha so I did the suspension first. I know dumb but tomorrow is another day. Thanks again everyone for the input this site is the shiot!!!!!!
