Old 08-27-2008, 08:23 AM   #1
Bguinee
My Ride: 99 BMW 323i
Engine Modification
Does anyone know if the enigine in the 323i can be bored out and bigger pistons & rods can be installed? If so, is there a company that sells a kit?
Bguinee is offline   Reply With Quote
Old 08-27-2008, 11:25 AM   #2
ridin325
My Ride: 2011 Z4 35i
Yes every engine that is made can be bored and stroked out.
ridin325 is offline   Reply With Quote
Old 08-28-2008, 05:50 PM   #3
Chris-TK
My Ride: Mazda
Yeah it can be, but it's not worth the money.
K.
Chris-TK is offline   Reply With Quote
Old 08-29-2008, 01:17 AM   #4
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
The crank/rods/pistons from a M54B30 can be used to stroke to a 3.0L.
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 08-29-2008, 04:01 PM   #5
tinkwithanr
My Ride: '00 323i + '75 2002
^^ seriously, what else would need to be done along with that. ecu tuning etc im guessing....
Sig
^^Mica_____________________________Fiona^^
tinkwithanr is offline   Reply With Quote
Old 08-29-2008, 04:03 PM   #6
Rayce185
Modifiziertes ///Mitglied
Rayce185's Avatar
Schrick cams, Intake, Headers.
IMO that would cover up the ideal NA engine modification, along with 3.0L stroke and ECU.
dun dun duuuunnnn
Rayce185 is offline   Reply With Quote
Old 08-29-2008, 05:03 PM   #7
shady3one3
Banned
shady3one3's Avatar
My Ride: gets replaced soon.
Send a message via AIM to shady3one3
If you have a street car, don't bother.
shady3one3 is offline   Reply With Quote
Old 08-29-2008, 05:09 PM   #8
Rayce185
Rayce185's Avatar
dun dun duuuunnnn
Old 08-29-2008, 05:21 PM   #9
shady3one3
Banned
shady3one3's Avatar
There's no point in opening up a 323 motor if its in a street car. You cant make appreciable power gains without doing the kind of modding that ruins streetability, reliability, and practicality. If you just want 330 power, its cheaper and easier to swap an m54b30.
Old 08-30-2008, 10:26 AM   #10
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
^ werd, check out some prices on 3.0 motors, and THEN decide if you feel like opening your motor up.
Old 08-31-2008, 07:09 PM   #11
dpgrand
My Ride: 2005 330xi
your best bet is probably finding the internals from a 330 engine (crankshaft, con rods, pistons)
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
Old 08-31-2008, 07:55 PM   #12
shady3one3
Banned
shady3one3's Avatar
its cheaper to drop in the whole motor in most cases
Old 10-02-2008, 08:36 PM   #13
Sev21
My Ride: 01' 325i (zf trans)
wouldit be a good idea to get a 330 motor and manual trans? what prices would i be looking at rounded out?
Sev21 is offline   Reply With Quote
Old 10-02-2008, 09:21 PM   #14
Chris-TK
My Ride: Mazda
Probably around 3-5k.
K.
Old 10-09-2008, 04:50 PM   #15
NOVAbimmer
My Ride: GT/CS, 01 330 6MT
I'll sell You a manual trans if You want it
NOVAbimmer is offline   Reply With Quote
Old 10-09-2008, 07:45 PM   #16
NOVAbimmer
You can also talk to Hamann about their stroker kit. I'll give You a guess as to their prices.
Here's a hint...whatever You're thinking, You're probably guessing low
Old 10-10-2008, 04:14 AM   #17
mechanicalmadness
My Ride: e46 323CI
Anything you do and buy that's BMW specific will probably be really, REALLY overpriced. NO I mean really overpriced.
Your better off finding a bigger motor. As for force induction on a 323 motor, simply forget it. Anything without a forged crank will pop in no time flat.
If anything do what i plan on doing. Find a bigger motor.
Born in the BG Raised all over. No wonder I'm confused.
mechanicalmadness is offline   Reply With Quote
Old 10-10-2008, 04:31 AM   #18
Rayce185
Rayce185's Avatar
I'm wondering why it would be cheaper to change the entire engine instead of just the internals.
The swap would require a new transmission, drive by wire, and probably to complete electronics, not just the software. Plus the entire swap is pricey as hell.
If you go with the internals, I would only guess that modified software would be needed. And the install should be cheaper than a swap. I'm just guessing here.
Headers and pulleys are no-brainers, and cams can be installed by any halfway competent shop with the right tools.
Only thing I imagine to be really pricey, is if the ECU needs custom software tuning. Other than that, I can't imagine an internal swap to be physically or financially more complicated than a complete engine/tranny/electronic swap. As said I have no experience with this stuff, and only know as much as I read on forums...
It may be cheaper to just FI the engine, or change the car for a 330ci/i.
dun dun duuuunnnn
Old 10-10-2008, 07:30 AM   #19
Activ3
You can swap the M54B30 in to the 323 and keep the 323 intake manifold so that you keep the cable TB. You can also keep your 323 transmission. A simple flash tune can then be done to get it running perfect.
Old 10-10-2008, 07:55 AM   #20
Rayce185
Rayce185's Avatar
Okay, but wouldn't it be very expensive to remove the entire engine, and insert a new one?
With an internal swap, I would imagine it would just take to raise the car, drain oil, remove the oil pan, disconnect the crank and remove it with rods and pistons mounted
dun dun duuuunnnn
