Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
#1 |
different springs in front and back
so my fronts low enough but i want lower in the back, can i just change the rear springs to something else?
#2 |
Yes you can, as long as the fronts are the same, and rears are the same, I don't see a problem. It's just like coilovers with different spring rates.
#3 |
And that reason, my friend, is why you go with coilovers rather than springs
Go ahead, ask me a question... Check out the CopTalk thread in the California forum
Thank you Sam ![]() |
#4 | |
![]() i fail |
#5 |
#6 |
The De46vil's Army
back in the early days of fanatics there was the jawknee setup (sp?)
it was basically e36 M3 springs in the rear if i remember correctly.
![]() Garage Queen |
#7 |
'a certain moderator'
^ I believe they were H&R Race springs, E46 non-M in the front, and E36M in the rear.
The OP should get coils. Especially if he is considering mixing brands front to rear, that just seems silly!
#8 |
Eurowerkz Midwest
Koven, You know the issues I am having with my iForged, so I am actually thinking of keeping my UUC v.2 fronts and putting in my stock sport spring in the rear. This will bring up the fender to the top of the tire and also firm up the spring rate so I won't rub. My UUC v.2 rears sit pretty low so if you're thinking about just getting new springs I will sell you mine for cheap. PM me if you want to talk more about it.
Edit- check your PM Koven
-Chad - Eurowerkz, Midwest Director
![]() SPONSORED BY: | TOYO Tires | WheelSTO | Level Industries | C.Moon Photography Last edited by C Digital 323CI; 09-11-2008 at 08:31 AM. |
#9 | |
so i'm guessing it's ok to mix springs thanks |
#10 |
$1k for coilovers?? Check out the ST setup. I got mine installed for less then a grand!
#11 |
LOL I used to run that when I first got my car...
#12 |
any more details/link?
#13 |
Call Sam at Autotalent. Get a price from them.
#14 |
My Ride: 2003 BMW M3 (TiAg)
or.. you can take out your spring pads in the rear.
i did that and it dropped a pretty good amount. before: ![]() after:
#15 | |
will this work?
![]() -Jorge All low no go |
#16 |
For you? NO! Not unless you let me have that engine cover!!!
#17 |
#18 |
My Ride: have 5 doors and FI
any noise or weird ride from removing the spring pad? I have a friend that wants to do this
![]() /_________\ OO=[][]=OO |
