Sponsored by BimmerWorld
Thread Tools Search this Thread Rating: Thread Rating: 21 votes, 5.00 average. Display Modes
Old 10-17-2008, 12:53 PM   #1
paraklas
My Ride: ESS TS2 320ci
Thumbs Up Hotchkis Sport Sway Bars arrived and Installed! WOW!!!
After snapping the ARB brackets twice I decided to go a step ahead and get a complete ARB set (Front + Rear). Also, the addition of the S/C made me drive more spirited than usual hense the requirement for better road stability, and reduced body roll. After a lot of research, I ended getting the Hotchkis Sport Sway Bar Kit, with rear endlinks and adjustable stiffness. Initial impression is WOW. Very well packed from factory, power coated bars, grease, manual, parts list to make sure you don't miss anything, adapter plates etc.
From the manufacturer:
H Sport has significantly increased the handling performance of the E46 with the addition of our Tubular Sway Bar Set. Bar diameters are 30mm front and 25mm rear. Both are adjustable for fine tuning with the front being 3 position and the rear 2 position. H Sport utilizes special adaptor plates for the rear bushing brackets which allow the use of a standard bushing brackets instead of having to struggle with the oe 'tabbed' brackets. This benefit allows for a zerk fitting and additional strength over the rear subframe. Perfect for street or track days, the set comes complete with front and rear black powdercoated bars,rear end links, polyurethane bushings, bushing brackets and zerk fittings for easy occasional lube.
Specs:
Front 30.2mm (1 3/16") Hollow
3 Way Adjustable
Stiffness over stock 04 330ci Sport
+31%,+51%,+77%
Rear 25.4mm (1") Hollow
2 way Adjustable
+138%,+171%
Bar Rates lbs/in (Not Wheel Rate)
Front:
470 lbs/in.
540 lbs/in.
630 lbs/in.
Rear:
475 lbs/in.
540 lbs/in.
I kept this picture to make a comparison of what is advertised and what is actually delivered. No difference at all!
And here is what the UPS delivered: :wink:
Very good packing!! Nothing moved!
mmmm Thick bars!
Manual and parts list
Front bar, 3-way adjustable
Don't like stickers but where this is going, nobody will see it.
Rear Bar - 2 Way adjustable
I was planning to do the install over the weekend but I managed to squeeze 3 hours of "lunch break" to do the install today
Old 10-17-2008, 12:55 PM   #2
koven
My Ride: 330Ci
very nice.. post a review after u install it!
koven is offline   Reply With Quote
Old 10-17-2008, 01:01 PM   #3
n2Bimmer
My Ride: Loves Corners
very nice, im still deciding between H&R and these, can anyone think of the differences, Such a weird name, where are they made.
Old 10-17-2008, 01:30 PM   #4
InLoveWithE46
My Ride: e46 non-M, e36 ///M
Send a message via AIM to InLoveWithE46
Congrats on the buy. You will LOVE them. I installed Hotchkis about 6 months ago and couldn't be happier. Handling is much tighter and feel much less roll on high speed turns. If you haven't already done so I would advise changing the end links, mine broke because the sway bars were too strong, plus if you get the adjustable end links you can not only adjust rear but fronts. Good luck with install!
InLoveWithE46 is offline   Reply With Quote
Old 10-17-2008, 02:41 PM   #5
paraklas
Hotchkis Sport ARB Install
Front Stock ARB
Endlink connection
The dreaded brackets that break all the time with the -now gone- powerflex bushes
Install was very easy for the front one. Just remove the brackets, disconnect the endlinks and replace with new ARB. I set it to the softest mode as the manual suggests, but I will change it later on when I have time to test the handling characteristics.
The PS hose was too close so we pushed it a bit out of the way.
New bracket in place with greased bush
Endlink connected at softest setting
Now the rears were a bit more challenging to install. Had to drop the exhaust from the rear mounts to allow some extra space. Just a ratchet with an extension did the job.
YESSSS No subframe damage!!!!
Left is OEM Vs new bolts
Rear ARB brackets removed
Rear ARB removed with the endlinks & brackets still attached to it. A 17mm open wrench was needed to hold the bolt's head on the upper side of the control arm.
Removing rear exhaust mounts to drop the exhaust a bit. Hotchkis doesn't mention this but my mechanic doesn't like following printed instructions blindly.
Testing the new endlinks with the OEM brackets
Securing them in place. We had to adjust the endlinks to lengthen a bit because the bar was touching the rear axles.
Installing the brackets with the PU bushes. The OEM brackets are held in place by a single bolt, the Hotchkis has 2 bolts and a massive aluminum reinforcement plate to hold the bar in place.
Adjusting endlinks to clear axle, screwing the exhaust back in place and DONE. Total time around 2 hours (10 minutes for fronts and 110 minutes for rear)
Old stuff in trunk to go in storage
Now, from the second the car touched the floor, the difference was noticeable. I will reserve my opinions once I manage to test the new setup in varying roads/conditions.
Old 10-17-2008, 02:57 PM   #6
n2Bimmer
sweet, so how much did it cost you, where are these made
Old 10-17-2008, 04:52 PM   #7
rellik
My Ride: is too slow...
wow bro. nice string of PICS. another great addtion from a fellow fanatic. anyone on the planet thinking about this set up for their BMW will be well served by looking at this post. nice work.
02' Black Sapphire Metallic Dinan 330i
* Dinan TCAI * Dinan Stage III engine software, Tranny software, Throttle Body and Strut Bar * UUC TSE3 * ///M3 Steering wheel * ///M3 lip spoiler * UUC Slotted Rotors * KONI FSD's * 35% tint * OEM (ULO) clears * 5000k bulbs * NGK Iridiums * Stewart WP * Delmarco's Bluetooth retrofit * LED Angel Eyes * 3K HID Fogs * USA Spec * P3Cars Vent Gauge * Hotchkis Sport Suspension Sway Bars *
rellik is offline   Reply With Quote
Old 10-17-2008, 05:08 PM   #8
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
Congrats! Helpful install write up as well.
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is offline   Reply With Quote
Old 10-17-2008, 05:44 PM   #9
paraklas
$380.00 from ebay
The seller also has a website which sells www.lightningforceperformance.com
I don't see any Made in.. but on the box it has date 10/08/2008 from an address in Santa Fe Springs, CA. I assume they are made in USA? I guess a call to hotchkis will solve this question.
Thanks for the comments
Old 10-17-2008, 09:16 PM   #10
UTL1098
My Ride: DINAN 135i, T4R LE
I bought mine from the same seller on eBay. And I believe the stickers were only for reference when installing them. Nice write up! I love mine.
UTL1098 is offline   Reply With Quote
Old 10-17-2008, 09:37 PM   #11
SeanC
My Ride: 330i
if this is you after the softest setting:
this will be you at the intermediate setting:
and at the tightest setting:
Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
HellrotDove Grey e36///M3 - RIP
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
Imola RedBlackBlack Aluminum e46 330i ZHP/6MT
SeanC is offline   Reply With Quote
Old 10-17-2008, 11:36 PM   #12
Transporter99
Transporter99's Avatar
My Ride: Audi A5 3.2/6MT
I'm sure there are some similarities. Probably just thickness differences, though I'm no sway expert.
Hotchkis made a reputation making suspension parts for muscle cars. Only within recent time did the get into the sport compact & euro scenes.
And for anyone that watched Sports Car Revolution when it was on TV, they were big fans of Hotchkis suspension parts.
For sways & springs, it's hard to bet against Hotchkis, imho.
328i ZSP/ ZPP/ ZCW - Sold
_________________________________
'99 DINAN 328i - Sold
'93 Honda Civic Si - Sold
'09 Audi A5 3.2 6MT
'87 Ford/Merkur Sierra XR4 Turbo
Transporter99 is offline   Reply With Quote
Old 10-18-2008, 12:07 AM   #13
chnzgoofball
My Ride: 04 325CI STEP
Send a message via AIM to chnzgoofball Send a message via Yahoo to chnzgoofball
nice! i had mines for about 2 weeks now and i love it!
JL Audio CleanSweep, JL Audio Mono 1000w Amp, JL Audio W6 v2 12in Sub, MB Quarts 6 1/2 components front, Polk Audio 6 1/2 Coaxial Rears, Lanzar 4ch 1200w Amp, K&N Drop in Air Filter, Black out grill/reflectors, 35% Tint fronts, F2 Coilovers, Hotchkis Swaybars, ECS Tuning 5mm Spacers, BF Goodies T/A KDW, UUC SS Brake lines, ATE Super Blue
chnzgoofball is offline   Reply With Quote
Old 10-18-2008, 12:43 AM   #14
UTL1098
I am pretty sure they are made in the US, and I believe the main difference is that they are tubular.
Old 10-22-2008, 04:00 PM   #15
Many330i
My Ride: e90 M3
Do I have to get endlinks too? If so, for F and R? I thought the Hotchkis kit include endlinks! I have a set at home I bought 3months ago and have been dreading to install - guess I will have to pay someone to do it. If getting NEW endlinks, any recommendations out there? Will OEM (M3 or 330)ones work? Still on that, do I need an alignment afterwards?
Many330i is offline   Reply With Quote
Old 10-22-2008, 04:08 PM   #16
paraklas
Rear endlinks are included in the kit.
No you don't need an alignment
You don't need to remove wheels, you don't even need jack stands. 2 good ramps and you are good to go.
Old 10-22-2008, 04:46 PM   #17
UTL1098
^What he said. You may want to unbolt the rear muffler to make the rear install easier, but I think you can handle it.
Old 10-22-2008, 04:55 PM   #18
cbmw
My Ride: 323ci
excuse me for my ignorance but what exactly does these sway bars do?
cbmw is offline   Reply With Quote
Old 10-22-2008, 05:32 PM   #19
Toxic0n
My Ride: E46 M3 6MT
Reduce body roll when cornering. Hence, "anti-roll bars" (ARB)
Ground Control Street/School coilovers, 19" HRE 441R wheels, ACS exhaust
2DIN touchscreen carputer, Bimmian CF E-brake handle, Titanium CF Trim, Illuminated ZHP knob, BMW Performance SSK, 2-way Compustar
Clear turn signals, LED license plate lights, LED tails, 3000k HID fogs, angel eyes, matte grills, CF Emblems etc
Toxic0n is offline   Reply With Quote
Old 11-03-2008, 04:08 AM   #20
Dannyncc
My Ride: Aw m3
Send a message via ICQ to Dannyncc Send a message via AIM to Dannyncc Send a message via MSN to Dannyncc Send a message via Yahoo to Dannyncc
Front end link use OEM right?
Dannyncc is offline   Reply With Quote
