Old 08-19-2008, 07:05 PM   #1
SoundOfSpeed
My Ride: Clownshoe
Any 2.8s with headers?
So I threw on some S52 headers on my dual vanos 2.8 a little while ago and I didn't get the results im lookin for.
Car is running rich to the point where it's throwing codes and the ecu can't cut back on any more fuel.
I'm on a stock tune.
Anyone else run into problems when putting in some headers on a 2.8?
Ghery
SoundOfSpeed is offline   Reply With Quote
Old 08-20-2008, 11:53 PM   #2
bmw_chuzo
My Ride: HPF M3
Send a message via MSN to bmw_chuzo
I didn't had any problems. no codes, errors.
my motor was the m52tu
bmw_chuzo is offline   Reply With Quote
Old 08-21-2008, 09:13 PM   #3
KriTiKaL AspecT
My Ride: 2001 AW 330Ci
Sure your o2's are in the corrct banks? Or any good?
Headers - KW V2 - Hotchkis Sways - 55w 6000k HID - 35w 6000k HID fogs
EVO 3 SSK mit ein DSSR - EE Tails - Meyle LCA, FCAB, & RTAB w/ Rogue Limiters - M3 Mounts ....
-Paul
KriTiKaL AspecT is offline   Reply With Quote
Old 08-21-2008, 09:18 PM   #4
Snik
Snik's Avatar
My Ride: IR M3 Vert.
so hold on, S52 headers fit on M52TU with no issues, and gains?
Do you ride a sportbike?
Old 08-22-2008, 06:25 AM   #5
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
Check your o2 wiring/connections, and if anything have your mech. clear the adaptations.
The OBDII S52 headers work fine on the M52tu/M54, but you need to use the downpipe midsection from the e36, unless you're having a custom exhaust built. You'll also have to extend the o2 wiring if using the e36 exhaust (which I'm assuming the OP did).
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 08-22-2008, 10:27 AM   #6
Snik
Snik's Avatar
and there are measurable gains from this?
Old 08-22-2008, 12:14 PM   #7
Activ3
IMO it's not worth it seeing as you can get a set of eBay headers for ~$150. Before headers were available on eBay, these would've been a cheaper alternative to the brand name headers for our cars.
Old 08-22-2008, 12:24 PM   #8
Snik
Snik's Avatar
ah..... but without an aftermarket ECU, how can u run ebay headers with no CEL?
Old 08-22-2008, 11:26 PM   #9
SoundOfSpeed
My Ride: Clownshoe
o2 sensors are brand new and wiring is fine. Exhaust is custom from S52 headers back. I've recoded the DME and adaptations ahve been reset. Been trying to figure this out for a little while.
What did you guys do about the cats? I installed a single 2.5" CARB legal Magnaflow cat.
Ghery
Old 10-07-2008, 01:22 PM   #10
TheRiddle
Sofa-king-what
My Ride: M52TUB28-Vert
here I am..
bought them on ebay a long ago...
no cats,just the 2nd resonator and a remus muffler....
sounds great, revs better..
and i felt the gain since the 1st km... they said 20hp, for me are 15...
and in 2 years of abuse the light engine light pop out only after a trip of 500km on the highway...
TheRiddle is offline   Reply With Quote
Old 10-19-2008, 10:03 PM   #11
240sxplan
My Ride: 328I
hmm.. no engine light huh.?? for me too I'm thinking putting in the headers from ebay and deleting the cat and resonater ..
If there is no codes .. I' d be looking for these upgrades soon..
240sxplan is offline   Reply With Quote
Old 10-19-2008, 10:59 PM   #12
Bimmer Dude Xi
My Ride: 03 325XI 07 ZX-6R
Send a message via AIM to Bimmer Dude Xi
Replacing the headers will give you codes
|Dinan High Flow Air Box|Eibach Pro Kit|Koni Sport|UUC Strut Barbarian|UUC TSE3|UUC Underdrive Pulleys|18" VMR V710|
|BMC Race Air Filter|CRG Spectrum Levers| Galfer Steel Braided Brake Lines|Volar Motorsport Spiked Frame & Bar-end Sliders|
Bimmer Dude Xi is offline   Reply With Quote
Old 10-19-2008, 11:35 PM   #13
BartenderPlease
My Ride: '03 540i/6 M-Sport
There will be a dyno graph of before (stock M52TU - 'cept for a CAI) and after with the only mod being the eBay headers. I'll keep you informed.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Trim | JL Audio | V1
BartenderPlease is offline   Reply With Quote
Old 10-20-2008, 01:54 AM   #14
Snik
Snik's Avatar
Are there any gains to be had from a S52 head? Or cams maybe?
Old 10-20-2008, 06:26 AM   #15
TheRiddle
Sofa-king-what
If it happens is given by the different ECU settings (US cars/EURO cars)
