Old 10-27-2008, 12:43 PM   #1
christraylor2
My Ride: 2002 325CI
Exclamation PLEASE HELP! Brand New Thermostat, Still a problem....
Hey, I replaced my thermostat because my car threw a SES about low coolant and the thermostat. I replaced it, hoping it would fix that and fix my heating problem. However, my heat problem remains, and as I drive my car, the engine temp goes from mid (12 o'clock) headed back to cold. I was wondering if my brand new thermo might be stuck or if there is something else.....
christraylor2 is offline   Reply With Quote
Old 10-27-2008, 12:52 PM   #2
DesertMotorWorks
Past Site Sponsor
My Ride: 2004 330CI
You may still have air in your cooling system. Re-bleed the system, and for good measure, bleed it again.
DesertMotorWorks is offline   Reply With Quote
Old 10-27-2008, 12:57 PM   #3
christraylor2
My Ride: 2002 325CI
I have tried to find instructions for proper 'bleeding' techniques. Is there anyone with a DIY or a link to a good one out there?
Old 10-27-2008, 01:28 PM   #4
snowie007
My Ride: 2000 323i
"...Turn your car to ignition (do not start), then put the heater temp on high and the fan on full blast (opens the core valves). Then SLOWLY refill. As you fill, you will hear the system burping and gurgling. If you fill slowly enough you will evac all the air in the system. When you get to the top, the bleeder hole will overflow. Contiue to slowly refill until no bubbles come out. Close the bleeder and the cap up..."
http://tuningemotion.com/forum/showthread.php?t=2471
snowie007 is offline   Reply With Quote
Old 10-27-2008, 01:53 PM   #5
christraylor2
My Ride: 2002 325CI
Alright, so I just bled the system and there still is no heat and the car goes back towards cold when driving speeds as well. Faulty (new) thermostat or re-bleed once more?
Old 10-27-2008, 04:41 PM   #6
tko200
My Ride: 01, 325i
Did check your Final stage Resistor
tko200 is offline   Reply With Quote
Old 10-27-2008, 04:51 PM   #7
christraylor2
My Ride: 2002 325CI
I don't believe that resistor would cause the temperature to heat up then cool back down, and I am able to control fan setting and do get random bursts of heat....
Old 10-27-2008, 05:30 PM   #8
vze3t229@verizo
My Ride: E46 DINAN 3
Send a message via Yahoo to vze3t229@verizo
Replace your watervalve, this should remedy your problem you may have!!
Jeff - BMW CCA Member
Checkerd Flag BMW,MINI & Smart
BMW Parts Advisor
MINI Parts Advisor
Smart Parts Advisor
SGT USMC/Disabled vet
93 E36/coupe 325is (sold)
03 E46/sedan DINAN 3
06 E83 SAV X3 (sold)
11 MINI Countryman S
02 E46 M3
vze3t229@verizo is offline   Reply With Quote
Old 10-27-2008, 05:38 PM   #9
christraylor2
My Ride: 2002 325CI
So it isn't the thermo? And is this DIY, and sounds pricey!
Old 10-27-2008, 05:55 PM   #10
vze3t229@verizo
I had the same problem. They changed my water valve under warrenty and my heating in my cabin was restored and my cooling of my engine temp was in the middle where it should be. I do not know your abilities but it should be fairly simple. If you do tackle it yourself ensure you properly bleed your system.
BMW Parts Advisor
MINI Parts Advisor
Smart Parts Advisor
02 E46 M3
coolant, cooling, heat, hot, thermostat
