Sponsored by BimmerWorld
Old 10-24-2008, 11:15 AM   #21
pmfp423
My Ride: 2002 330Ci
Send a message via AIM to pmfp423
The 330 calipers and the M3 calipers use the same brake pad size, front and rear. I believe that the M3 comes with a more aggressive friction compound from the factory.
pmfp423 is offline   Reply With Quote
Old 10-24-2008, 11:25 AM   #22
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Originally Posted by simsima325 View Post
in a word, no. get some stainless lines, a more aggressive pad, and you will stop fine.
bingo... unless you are doing it just for looks in which case, it's all personal opinion on whether or not it is...
i upgraded to a stage 2 kit from stoptech and am more than satisfied
Timeless Motor Group
Old 10-24-2008, 12:51 PM   #23
bmw_chuzo
My Ride: HPF M3
Send a message via MSN to bmw_chuzo
not worth it hehe.. I got m3 brakes on mine and 330's were the same
bmw_chuzo is offline   Reply With Quote
Old 10-24-2008, 07:29 PM   #24
ModBargains
ModBargains's Avatar
My Ride: M3
Agreed. The Stage 2 kit will be more than enough. Very wise choice to upgrade your brakes first before going with fi. Most people go the other way around. Let me know if I can help you out with a kit. It includes the front and rear Stoptech rotors, Axxis pads, Stoptech stainless steel brake lines, and 3 bottles of Motul high-performance brake fluid. Everything you need to upgrade your OEM brakes. Let me know if I can help you out with a quote.
Stoptech Stage II
Blake Brunner|blake@ModBargains.com|(714) 582-3330 ext. 8011
We Specialize In:
BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts | BMW Tail Lights |
BMW Wheels | BMW Intake
Hours
Check out our Blog for updates!
ModBargains is offline   Reply With Quote
Old 11-03-2008, 05:00 AM   #25
mkodama
mkodama's Avatar
Originally Posted by snikwad View Post
if the M3 has a larger caliper piston it would be well worth it.
but no one seems to know.
Why would it be well worth it? What are you trying to accomplish?
Larger diameter caliper pistons would simply mean your brake pedal would get softer since you need to move more brake fluid to move them. It would have the exact same effect as getting a smaller diameter master cylinder.
Seriously, the only reason for larger brakes is to dissipate heat better. And since the M3 and 330 brakes are nearly identical, well, you aren't going to notice a difference.
