m54b30 vs m54b25 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-10-2008, 02:49 PM   #1
Rafals
My Ride: M3 E30
m54b30 vs m54b25
Hi. Is there anyone on the forum who can tell me whether m54b30 enigne will work properly with controller from m54b25? Are maps and fuel dose the same? Thanx
Rafals is offline   Reply With Quote
Old 11-10-2008, 03:15 PM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
Controller, as in DME? Not likely. You're also going to have a very hard time swapping in a used DME from another car, even if it's the exact same model.
Old 11-10-2008, 05:50 PM   #3
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
You can use the 2.5 DME, you just need to get new software put in.
ESS can do the deed.
Old 11-10-2008, 06:50 PM   #4
TxZHP04
Assuming you get the right DME, MS43 or MS45. Yes, if you start talking about reprogramming the DME, then you have more flexibility and ESS can surely take care of everything. I bought a second DME from a junk yard and use it when sending them my DME for updates (since I have their supercharger). They were able to make it work for me, no problem. Without doing something like this however, it's tough to just swap DMEs between vehicles.
Old 11-10-2008, 08:52 PM   #5
azzy989
azzy989's Avatar
My Ride: 325i
Send a message via AIM to azzy989 Send a message via MSN to azzy989
dang...i was wondering about this too
thanks for the info pei and txzhp
-Azlan *I want to be like CD330*
azzy989 is offline   Reply With Quote
Old 11-11-2008, 09:38 AM   #6
mrshelley
My Ride: 2004 330i
To change DME's between vehicles, this is what you need:
-DME
-EWS
-Keys
-All tumblers (ignition, door, trunk, glove box...)
-General Control Module V (this will allow the remote to work)
Remember, these all have to come out of the same car.
I actually have a spare DME for my car (in case my primary one takes a dump). I have two EWSs and keys under the dash. In case I need to change out the DME, everything I need is right there. I have an old ignition tumbler zip tied under the dash with a coil snapped around it. This keeps the key from falling out.
Old 11-11-2008, 10:32 AM   #7
TxZHP04
-DME
-EWS
-Keys
This is all necessary assuming no modifications are made to the DME. In my case, I can swap DMEs and then only need to re-align the EWS to make the spare DME work with the rest of my car. Not sure exactly how ESS pulls it off but it sure came in handy for me - of course, I was already having my DME modified with a tune for the SC anyway.
Old 11-14-2008, 05:59 PM   #8
copracr
My Ride: 02 325i
Sorry, but i have a couple newbie questions.
Is a DME a PCM?
What's a EWS and basically what does it do?
Who or what is ESS?
Are there any good threads on motor swaps or BMW tuning options?
I'm new to the BMW world so some of the terminology is tripping me up. Thanks guys.
copracr is offline   Reply With Quote
Old 11-15-2008, 11:48 AM   #9
NikolaiD
My Ride: 2002 M3C
Send a message via AIM to NikolaiD Send a message via MSN to NikolaiD Send a message via Yahoo to NikolaiD
One n00b to another:
DME = BMW's ECU, DME=Gasoline, DDE=Diesel
EWS = Immobilizer System. It basically checks all vital components: the alarm status (DWA), cluster status, it checks the miles, keys and transponders to control engine, door and trunk access based on the way it's programmed.
ESS= http://www.esstuning.com/
EGS just for info is the automatic gearbox controller. It comes up a lot on this site.
As for engine swap, you'll just have to search through the hundreds of threads on that topic, basically, it takes a lot of programming by someone that speaks BMW.
Is a DME a PCM?
Who or what is ESS?
_______________________________________
My Ride: 2002 M3C
NikolaiD is offline   Reply With Quote
Old 11-17-2008, 09:00 PM   #10
M54B25
My Ride: 2006 E46 M3 ZCP
Have anyone tried swapping DME from a M54B25 MS43, with a M54B30 MS43 + align the EWS. But it might work The M54B30 vs M54B25/20 differs in the intake manifold & some other minor changes.
'06 M3 ZCP Titanium Silver w/PP + Nav.
'07 VW GTI DSG
'10 335i M-Tech
M54B25 is offline   Reply With Quote
Old 11-17-2008, 09:02 PM   #11
4ngie
4ngie's Avatar
My Ride: Chrissspyy
You can do the engine swap and still use the same DME if you keep the 2.5 injectors. Otherwise, it will throw a code. I drove my car for a year like that until we changed the EWS, DME, etc just last week.
4ngiefest VII - 10/5/2013
4ngie likes this.
4ngie is offline   Reply With Quote
Old 11-24-2008, 02:19 PM   #12
copracr
My Ride: 02 325i
Did you do a write up on that? it would be very interesting to see what all is involved in the swap. One question though - why switch the DME? Does it have a better tune on it? Why not retune the original DME if so?
OK, that was 3 Q's.
Old 12-15-2008, 06:14 PM   #13
copracr
My Ride: 02 325i
Why didn't you just retune the DME you had?
Old 12-15-2008, 06:55 PM   #14
4ngie
4ngie's Avatar
My Ride: Chrissspyy
Because I got a reallllllllly good deal on a DME for a 3.0, so we just replaced. I suppose I could still retune my 2.5.. where do I get this done?
4ngie likes this.
Old 04-24-2009, 11:41 PM   #15
evilstar
My Ride: 633csi & 325i
Wow this is kinda weird about a year ago i remember reading this thread because i wanted to do the same thing now ive accutually done it. I never realized his name was Rafals my name is rafael ohhh spokey...
evilstar is offline   Reply With Quote
Old 10-27-2009, 06:28 PM   #16
mujjuman
My Ride: not an E46
I'm trying to swap in a M54B30 in place of my M54B25, would I or would I not need to swap the ECU as well?
I'm getting mixed answers between threads and different posts...
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 10-28-2009, 09:17 AM   #17
dpgrand
My Ride: 2005 330xi
the 3 liter engine will run using the 2.5 injectors (not optimally, but it will run)
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
Old 10-28-2009, 01:38 PM   #18
azzy989
azzy989's Avatar
My Ride: 325i
no need to swap the ecu....send your ECU to ess and they will get it to 3.0 specs for you... so that you can run 3.0 injectors and the 3.0 maf
Old 10-28-2009, 02:23 PM   #19
mujjuman
My Ride: not an E46
That's cool. How much does ESS charge for this?
Also, is there a drastic decrease in power if I runthe 2.5 injectors and the 2.5 maf?
Anyone did dynos?
And bow do I remove/install my ecu?
Sorry of it's like I'm asking so many questions. I just want to learn everything and be fully prepared before I start this.
mujjuman
2003 325xi 5MT
sig by Solidjake
Old 10-29-2009, 11:51 AM   #20
dpgrand
My Ride: 2005 330xi
Just being honest, if you don't know how to remove your ecu, you have a LONG ways to go before you can consider doing this swap.
