Old 08-13-2008, 07:37 PM   #1
andrew_nz
My Ride: 2000 323i
Question 2000 323i electrical bug
I've been having a strange electrical problem with my 2000 323i since I bought it a few years ago. I checked on this forum back then and found a few posts with the same symptoms, but nobody ever solved the problem. I've just gotten used to the problem now, and it isn't that big of a deal really, but now I want to sell the car before I move, and I'd like to have it fixed. I think somebody might be weary of buying a car with start up problems, even if they are minor. If anybody knows what's wrong or can point me to an old thread about it that would be great.
Here's the symptoms:
When I turn the key, sometimes the start up dash light routine won't come on, only the seat belt light. When that happens, if I try to start the car, the engine will crank and crank but won't start up. All the other electronics (radio, headlights, windows, seats, ac) work great, just the car cranks and won't start if that dash light routine doesn't come up.
Then if I turn the key a couple more times until the lights come on, the car will start right up no problem at all. It's not the key, I bought a new one and both do the same thing. Mostly it's just annoying because I have to turn the key so many times to get the start up routine to come up.
Then, just a few months ago it started doing some other strange things. Sometimes, the car will start up great and then a couple seconds later will just die. When I restart it, it starts up and runs no problem.
Also, twice while I've been driving around town, the car died suddenly, all the dash lights went off, and then it just came back on. That one is a little scary I can tell you.
I figure it might be something with key security system that isn't recognizing the key, but I'd like to know what you guys think. I haven't had it in to a dealer to read the codes, because the previous threads with the same symptoms said the dealer couldn't figure out what was wrong and they spent a bunch of money for nothing. If you guys have any ideas I'd be tickled to hear them.
Cheers,
Andrew
andrew_nz is offline   Reply With Quote
Old 08-24-2008, 12:14 AM   #2
MSumners
My Ride: 323Ci
Same problem. Any progress on this?
MSumners is offline   Reply With Quote
Old 08-27-2008, 12:31 PM   #3
andrew_nz
My Ride: 2000 323i
Nothing yet, sure wish I knew what was going on though. Best I can tell it's a short or something in the key security system. If I figure it out I'll let you know.
Andrew
Old 12-03-2008, 09:27 PM   #4
Latinbear4
My Ride: Black 323i
Send a message via AIM to Latinbear4
Andrew
Hello.. I am having similar issues with my 2000 323i. It is so irritating. My issues is as fallows. Sometimes the dash lights wont come up except for the seatbelt light which stays on even is i click the seatbelt. Non my steering wheel controls work and the radio doesnt turn on. Thank god the engine always cranks. I have a feeling it can be the electronics that run under ACC1( one turn of the key) but i have not had anyone else mention anything to confirm it. Then while i am driving whenever it feels like it seatbelt light will go off airbag light will come on for a sec then off. and then radio will turn on. If you got a fix for this please let me know. Thanks!
Latinbear4 is offline   Reply With Quote
Old 12-03-2008, 09:34 PM   #5
whoami
My Ride: E90
hmm, never had any of the symptoms stated..
i duno
whoami is offline   Reply With Quote
Old 12-03-2008, 10:29 PM   #6
Eliott's-BMW
Eliott's-BMW's Avatar
My Ride: E46 3-Pedal Mafia
Is not a bad ignition switch? Sounds like it to me...
Eliott's-BMW is offline   Reply With Quote
Old 12-16-2008, 01:19 AM   #7
revell112
My Ride: 2000 323i
Any updates on this... I think I might have the same problem with my 00' 323i
revell112 is offline   Reply With Quote
Old 12-16-2008, 07:42 AM   #8
Bmw440
My Ride: 2000 323i, 2001 528i
Send a message via AIM to Bmw440
From what i have been reading, it could be a bad ignition switch. or the tumbler on the ignition switch, it supply voltage to all the electrical components.
Bmw440 is offline   Reply With Quote
Old 12-16-2008, 08:46 AM   #9
pyro225
My Ride: 328ci
I had a similar issue in my 328ci and it was the ews causing it not to start - i ended up buying a new ecu ews and key set now its fine
pyro225 is offline   Reply With Quote
Old 12-17-2008, 10:47 PM   #10
Latinbear4
My Ride: Black 323i
I think I found the problem I was having. Make sure that the connection (red wire) to your alternator has not gotten loose due to engine vibration. Make sure you are getting good contact between alternator and red wire. The easiest way to get access to the wire is by removing the air filter cabin. very simple.. Also check that your rear plate bulbs are working fine...let me know if this stopped the problem for you as well. Good luck.
Old 12-17-2008, 11:01 PM   #11
mechanic_101
My Ride: 2005 325I
your problem sounds like ignition switch. Get a used one on ebay and try it out.
mechanic_101 is offline   Reply With Quote
Old 12-20-2008, 12:28 PM   #12
methemandus
My Ride: e46 323ise
any update on this i got same prob
methemandus is offline   Reply With Quote
Old 12-20-2008, 10:01 PM   #13
Latinbear4
My Ride: Black 323i
Old 12-21-2008, 01:31 PM   #14
kbracken
My Ride: 2000 323i
I had a similar issue a few months back but instead of it happenin periodically it just happend out of nowhere. I had driven to work one morning and when I left to go to lunch, nothin. Everything turned on like you guys are sayin but it would not crank at all. I called the dealership and they told me that my key had gone bad so I ordered a new key ($185 my cost). That was on a Wednesday and they told me that if I ordered the key that day before 2:00pm that I would have it Friday so we pushed my car into the shop at work and there it sat. Friday came and they said that the key didn't show up and that it would be Monday before I would get my new key so I got frustrated and took my key apart. Well my key didn't go bad but the chip inside had moved too far back (away from the key cylinder). I had adjusted the chip and moved it closer to the key cylinder inside the key and put the key back together and it started right up. I have never had another problem with that key again, now I just have two keys that work. Don't know if that is the same thing with your guys issues but I thought I'ld let you know what my issue was and see if maybe it helps you out. Hope it helps.
19" Rims, One-Piece Projection Headlights, 10000K HID Kits on Low Beams and Fog Lights, Clear-Smoked Side Markers, Debadged, Custom Audio/Video System
kbracken is offline   Reply With Quote
Old 12-21-2008, 04:38 PM   #15
methemandus
My Ride: e46 323ise
cant be the key same with all three
Old 05-19-2010, 03:53 PM   #16
Phantom_Tulaba
My Ride: pure Hotness
So did this turn out to be alternator related with the loose wire? Also, what did the rear plate lights come into play with this? lol...
Werd!
Phantom_Tulaba is offline   Reply With Quote
Old 11-22-2010, 03:21 PM   #17
methemandus
My Ride: e46 323ise
fixed it
all sorted ignition switch after all 2 min job no more problems
323i, dash lights, electrical, problem, starting
