Old 11-19-2008, 03:19 PM   #1
///MR3LIGION
My Ride: y2k E46roid/ GSXR750
Cool Foam lance/ gun or this PRODUCT
Foam LANCER,
Could I use this w/o the pressure washer thus acting like a regular foam gunner. I have a pressure washer but just want to know if it works fine w/o it.
Foam GUNNER,
Would this work just fine?
To both of you,
Do I need to purchase a FOAM shampoo for it to work or a regular carwash soap is cool?
What brand should I get for the LANCER/ GUNNER?
"3Starz&DaSUN"
"Camouflage is not your object. Don't be afraid to speak the truth, and don't cater to the lowest common denominator."
///MR3LIGION is offline   Reply With Quote
Old 11-20-2008, 05:46 PM   #2
///MR3LIGION
quiet hey........
"3Starz&DaSUN"
Old 11-20-2008, 06:09 PM   #3
eyezack87
My Ride: ...
Foam gun is designed to work with a normal hose and stuff. AKA this: http://www.amazon.com/gp/product/B00...3BMEBC4EAJP4M9
Foam lance is designed to work with pressure washer only using an array of attachments designed to work with one another. The most common one is the CamSpray attachment
It goes down to personal preference. I have a foam gun for now since I cannot afford a PW + foam lance YET. Works well enough for me. I use Megs Gold Class shampoo with great effect
Now, would you have a foam gun or a foam lance? To put the picture in your mind, here is a comparison of the two. First is foam gun on maximum setting. 2nd is some guys foam lance lol
You can see why I want the lance now
Need a detailer in SoCal? Shoot me a PM. I am located by Mission Viejo/Irvine
eyezack87 is offline   Reply With Quote
Old 11-20-2008, 06:11 PM   #4
eyezack87
My Ride: ...
I also want to add that my last experiment mix of car washes/P21S TAW was so bubbly that they were all carried off by the wind so I decided to tweak it a bit and thats what you see in my picture lol
Old 11-21-2008, 10:49 AM   #5
///MR3LIGION
This may be an alternative for the bucks
http://www.walmart.com/catalog/produ...uct_id=9189097
But then I am not exactly sure if it would work. My assumption is feasible with a High water pressure or just the hose alone....
"3Starz&DaSUN"
Old 11-22-2008, 05:42 AM   #6
Stormos
My Ride: Not alot!
Foam Lances Rule!!! I LOVE mine!
Stormos is offline   Reply With Quote
Old 12-15-2008, 06:21 PM   #7
joedaddy
My Ride: OCTA
can somebody list out the parts that i need to order online?
I figure I can just pick up a pressure washer from Costco or Home Depot.. but what about foam cannon, etc?
joedaddy is offline   Reply With Quote
Old 12-16-2008, 06:01 PM   #8
Greg@DetailedImage.com
My Ride: is clean & protected
As stated above a foam lance is what is used with a pressure washer and produces a finer mist. The foam gun can be used with any hose and requires no additional attachments. We carry the Gilmour Foamaster II foam gun which works great if interested. Normally it's $59.99 and we have it on sale for Decmeber only and it comes with a FREE Chemical Guys Citrus Wash and Gloss ($9 Value). This is an excellent automotive shampoo that can safely remove old wax and sealant and give you a fresh surface to start detailing with. Simply just add in the desired amount of shampoo, adjust the dial and hook it up to your hose and start spraying foam everywhere! Let me know if you have any questions about these items.
Greg @ Detailed Image
Old 12-19-2008, 07:33 PM   #9
mrtt
My Ride: 500HP
after foaming the entire car, do you just rinse off or actually rub it and then rinse?
mrtt is offline   Reply With Quote
Old 12-20-2008, 02:20 AM   #10
Stormos
My Ride: Not alot!
I've seen the gilmour in action and it's not a patch on a PW Foam Lance.
good if you have no PW though.
Old 12-21-2008, 01:41 PM   #11
I typically spray the foam over the vehicle and then use a my Ulti-Mit or Grout Sponge or Sheepskin Wash Mitt to wash the surface (with a rinse bucket). If you just spray the foam you certainly will remove some of the surface contaminants but a mitt/sponge will be needed for a more thorough cleaning. If you don't use a mitt or sponge then you definitely should not apply any product after like a polish, wax, etc. because you will likely grind in contaminants causing micro-scratches. Let me know if you have questions.
Greg
Old 12-21-2008, 08:34 PM   #12
mrtt
My Ride: 500HP
Greg
I see... can you direct me where to buy the foam lance along w/ attachment to use w/ my pressure washer?
After using a sponge to clean vehicle, do you recommend using pressure washer to rinse or just bucket of water or does it matter?
Before covering your car w/ foam, do you rinse your car w/ water first?
Old 12-21-2008, 09:59 PM   #13
PHARMTECH
My Ride: 325i
I' selling a foam lance.
I used it once to try it out, it has quick disconnect fitting $95 plus shippingUS only
Name:	foam lance.jpg
PHARMTECH is offline   Reply With Quote
Old 12-22-2008, 04:37 PM   #14
I don't carry the foam lance now but i'm sure you can get it with a quick google search. It should be a pretty straight forward purchase to get everything you need. You don't have to rinse the vehicle with water before, it's really personal preference.
To rinse the vehicle most effectively I recommend you remove any of the nozzles and just let the water flood the surface with a regular hose. By flooding the surface you help lift and carry contaminants down and off the vehicle. Start at the top and work your way down. This process also helps pull the water down the paint as you rinse it, thus decreasing the amount of time you spend drying.
Old 12-22-2008, 10:18 PM   #15
mrtt
My Ride: 500HP
how big is the bottle?
Old 12-22-2008, 10:48 PM   #16
PHARMTECH
My Ride: 325i
I'm not sure I think maybe a pint or more.
I have seen others replace the bottle the threads are common size.
I used it full of soap without water, it produced sods that looked as if the car had snow on it!
Old 12-23-2008, 08:20 PM   #17
mrtt
My Ride: 500HP
do you run out of soap before you can finish covering the car?
Old 12-23-2008, 11:30 PM   #18
PHARMTECH
My Ride: 325i
Never in fact it floods the street you have to cut the soap with water or you get more suds than you can handel.!
detaildr@socal.rr.com
Old 12-26-2008, 12:42 AM   #19
DetailDan
My Ride: Jeep
Send a message via AIM to DetailDan
You dont need a special soap, but some foam more than others. I can tell you that Megs gold class and NXT dont foam much. But CG citrus wash n gloss and pure citrus wash foam a lot.
DetailDan is offline   Reply With Quote
