Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 12-20-2008, 06:16 PM   #21
sillieidiot
My Ride: '06 AW 330ci
Originally Posted by glockman9c View Post
I have NEVER seen a dead pixel in a PLASMA.
Change sources, change settings, change something.
I have seen television programming that had dead pixels in the camera they used to shoot the show (ie - the work during commercials)
I see dead pixels all the time in LCDs.
Usually if a plasma has an issue, its a complete line and obviously a defect like any other issue on any other item.
I repeat, I have NEVER seen a dead pixel in a PLASMA.
I am not saying it is impossible, just not common like an LCD.
wow you're lucky or something. panasonic plasmas are the ones where you have the highest possibility to see a dead/stuck pixels. i've never seen them on any other plasmas. but there is 2 specific lines for panasonic that have them (don't remember exactly which). it's a manufacturer defect for sure.
Old 12-20-2008, 06:36 PM   #22
sillieidiot
iirc you got a panasonic plasma right? keep in mind that they won't replace your tv because of dead pixels. they offer no warranty for that, unless your dead pixels are in the center on the tv. so you should just exchange it if you can
Old 12-20-2008, 10:13 PM   #23
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
Originally Posted by hayabusa55 View Post
I'm using 1920X1080 images for the break-in and they're read from a SD card. I rebooted my cable box connected through HDMI because it has a blue screen at the start, and the same pixels are black.
Try component cables then take it back. Not a common issue at all. Everyone makes a bad something sometime.
NEVER heard of an issue. NEVER seen an issue. I guess I am VERY lucky.
Put in a 65" and 46" Panny plasma today with no issues.
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 12-20-2008, 10:23 PM   #24
'busa
'busa's Avatar
My Ride: E90 335i (sold)
Yeah, I just bought it and CC is even extending their return policy for everything purchased between Nov 1st and Dec 24th until Jan 24th.
'busa is offline   Reply With Quote
Old 12-20-2008, 10:56 PM   #25
sillieidiot
well yea it's very rare on plasmas to begin with. but i do know/have seen panasonics with the issue.
Old 12-21-2008, 06:07 AM   #26
Owtlaw333
My Ride: 2009 Mazdaspeed 3 GT
If he's within the 30 days (or 15... whatever it is) there should be no problems swapping the set. It's only outside that 30 days that he'll have issues having it fixed under warranty.
Bringing it back for the new people...
productionof1.com
|||_Buy my photos?_|||
Owtlaw333 is offline   Reply With Quote
Old 12-22-2008, 08:59 AM   #27
'busa
'busa's Avatar
I'm afraid the next set will have more dead pixels or maybe some more noticeable ones...
Old 12-22-2008, 09:13 AM   #28
Rayce185
Modifiziertes ///Mitglied
Rayce185's Avatar
I was just wondering: Dead pixels on a plasma?!
Have you tried different sources, different resolutions... etc?
dun dun duuuunnnn
Rayce185 is offline   Reply With Quote
Old 12-22-2008, 10:23 AM   #29
'busa
'busa's Avatar
I don't know that it's 'dead', because when the screen is any color but blue it works fine, but when it's supposed to show blue, there are 5 pixels that are black.
I've seen it on an image directly read from the memory card slot in the TV and on a cable box image connected through HDMI.
Old 12-22-2008, 12:26 PM   #30
GlockMan
GlockMan's Avatar
Buy two more before returning two.
Side by Side by Side comparasion.
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 12-22-2008, 12:52 PM   #31
'busa
'busa's Avatar
Old 12-22-2008, 05:00 PM   #32
sillieidiot
hopefully you will be fine. like i said get it setup. leave it for a couple of hours then turn it on and see.
Old 12-22-2008, 05:01 PM   #33
sillieidiot
yes it's possible, very unlikely though. most probable cause is from manufacturer defects
Old 12-22-2008, 05:03 PM   #34
sillieidiot
try leaving your screen on a fuzzy screen for awhile. it might take it out. damn i forgot what it's called, but the one that is grey with all the dots when you don't see a picture
Old 12-22-2008, 05:35 PM   #35
'busa
'busa's Avatar
I don't know if I can hold off the anxiety and not turn it on.
Hopefully it's not a whole batch that's bad. I'll try to return it today or tomorrow.
I can't. If there's no screen, it goes black immediatelly. I've watched plenty of TV/movies recently and done a lot of the break-in images. All 5 pixels are still there.
Old 12-22-2008, 05:43 PM   #36
sillieidiot
well for plasma's, it takes a lot longer to unstick the pixels. up to 3 months. but by then, if you still have it, then you're SOL cause warranty won't do anything about it.
i hope you will get a good one. at least not turn it on for an hour lol. what's an hour if it stops you from returning it again and going through all the trouble.
Old 12-22-2008, 09:26 PM   #37
'busa
'busa's Avatar
Just replaced it. New set, knock on wood, no dead pixels. Me, this happy -->
Old 12-22-2008, 09:53 PM   #38
GlockMan
GlockMan's Avatar
Just forget it ever happened. I have three and have installed 100s. No issues.
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
