Thread Tools Search this Thread Rating: Thread Rating: 85 votes, 5.00 average. Display Modes
Old 12-22-2008, 08:13 AM   #1
paraklas
My Ride: ESS TS2 320ci
Talking DIY: Stewart Water Pump + Expansion Tank + Coolant Change + 2 Tensioner Pullies
Here's my complete DIY..
EMP Stewart Components + Expansion Tank + Coolant Change + Tensioners
After 2 years, I decided to do a complete coolant change. So I took the opportunity to replace my expansion tank as well since it was leaking a bit from the top part. Coincidentally, my water pump decided to fail too by making a "hiiissshhhiiiin" sound once warm, indicating worn bearings. Not wanting to throw a belt or something I chose to replace it with the high performance/flow water pump with stainless steel impeller & high durability bearings from EMP Stewart components. More expensive than the OEM pump but at least one less thing to worry about. Since I would have to remove the belt to access the WP, I grabbed the opportunity to replace both deflection pulleys from the tensioners. It was a good thinking because after I removed the belt I noticed a lot of free play in both tensioner pulleys, another indication of pending failure.
Considering that almost all of the affected components are either made from composite materials or aluminum, I followed the exact torque specs found in BMW TIS to avoid snapping things. You NEED a torque wrench from 10Nm and up.
Torque Specs:
Drain Plug on Engine Block: 25Nm
Pulley on Water Pump bolts: 10Nm
Water Pump on Block nuts: 10Nm
Deflection Pulley on Tensioner: 35-40Nm (I could not find specs for the tensioner pulleys so I measured the approximate value with my torque wrench)
Part List:
EMP Stewart Components BMW E46 High Flow Water pump
4L OEM Coolant
4L Distilled Water
Bleeder Screw
Expansion Tank drain plug (blue)
Radiator plug (blue one, different for auto/manual transmissions)
Coolant Drain plug washer
Expansion Tank
(For exact part numbers go to http://bmwfans.info and enter last 7 digits of chassis number to get the correct part)
DIY:
If you want to replace the thermostat now it's a good chance! Also, remove the lower splash shield to access the components below. Use a set of ramps or jack stands - NEVER USE THE OEM JACK FOR SUCH WORK.
Belt diagram to remember the path!!! Not exactly CAD design but does the job
The new pump looks beefy and well designed
New expansion tank
Fan removal (Manual transmission). Remove air intake by popping the 3 push/lock pins. Remove the push/lock pin on the right side of the fan
Remove both plugs and the T25 torx screw on the left. Lift it and it's out of the way. 5 Minutes!!
To remove A/C Belt, insert a 16mm spanner on the illustrated bolt and rotate counter clock wise to compress the spring.
When the 2 holes shown below are aligned, insert a metal rod like an allen key to hold the spring compressed. Now remove the A/C belt
Pop the protection cap from the pulley and insert a T50 bit and remove the bolt. The pulley just drops. Replace it with new one and tight back to 35-40Nm. Re-install protection cap and you are done!
Remove airbox to allow access to the various hoses beneath. Remove 2x10mm bolts on the airbox, disconnect MAF plug and the clamp that holds it to the rest of the intake boot. You need to access the hose below that goes in the expansion tank.
Time to remove the main engine belt and the tensioner. Again insert a 16mm key with a small extension to prevent ratchet touching the crank pulley and rotate clockwise to compress spring. Once compressed, slide engine belt out of the pulley and release the tensioner. Pop the protection cap from the tensioner, insert T50 bit and remove the deflection pulley, just like the A/C one. Install new one and tight back to 40Nm. Don't forget the protection cap.
Time to do the expansion tank now.
1. Let engine cool down
2. Remove expansion tank cap & bleeder screw
3. Go below car and remove expansion tank drain plug (blue) and let the coolant drain in a bucket. Do not allow pets in the area, coolant is sweet and if your dog drinks it, he will die.
4. Remove coolant level sensor. Unplug it and twist it 45 degrees for removal.
5. Remove expansion tank quick release spring
Remove plastic bleed screw, radiator cap and 2 quick release springs from upper radiator hose.
I had to spray some WD-40 on the hose to tank & radiator connection to soften the seals because they were almost glued in place. Let it soak for 5 minutes and job becomes much easier.
There's another hose that needs to disconnect and is the lower one from the heater valve. Lift quick release spring and wiggle the hose out of the tank. Stand on top of the tank, place both hands on the bottom of the tank and lift upwards shaking it a bit. I had to put some strength to get the tank out mainly because of the bottom connection being stuck. Remember to catch any coolant. Once the old tank is removed, I inserted the new one in place, lubricating its seals with undiluted coolant. Once in place re-install all the hoses, drain plugs, and connectors. One step completed at a time. The only thing left not in place was the bleed screw because I would add coolant later.
Next step was to drain the radiator from old coolant: Remove the small blue plastic screw and allow coolant to drain completely.
Draining coolant from engine block. Go below car and locate the drain plug. It's next to the ground strap behind the cat converter. You need a ratchet wrench with a u-joint and a couple of extensions. I couldn't take pictures because both my hands were occupied. The drain plug needs a little force to break free and once removed a lot of coolant will flow. It was that time that I discovered the taste of coolant too. It's part number 4 and washer part 5. Once coolant stops running, replace washer and re-install plug. Torque to 25Nm.
Engine drain plug with its washer
The final step is to remove the actual water pump. Locate the 4 bolts that hold the composite pulley on the water pump and remove them. The pulley just slides out. Don't drop it or hit it because it looks (and probably is) fragile.
To remove the exposed pump, remove the 4 nuts that hold it on the engine block. If it's stuck in place, thread 2x M6 bolts evenly on the water pump. Once they touch the engine block screw them evenly until they break the pump free. Pull the pump and collect any remaining coolant.
New (Left) Vs old (Right) pump. The OEM pump looks like a toy next to the Stewart one. I could spin the old pump hearing the shot bearings inside rattle. Lasted 80000km.
And that's it basically. Installation for the water pump is exactly the opposite of removal. Once installed, I re-inserted main engine belt, a/c belt, fan and airbox with MAF. I inspected everything in case I forgot to connect a part and started the coolant refill and vent process.
1. Mix 50/50 OEM coolant with distilled water (4L+4L) 8L total
2. Set ignition to ON (engine off) position, set the heater fan to lowest speed and temp setting to max (32 degrees) this will open the heater valve for proper bleeding.
3. Slowly pour mixed coolant inside expansion tank until bubble free fluid emerges from bleed plug. I needed around 7.5 Liters of coolant.
4. Screw bleed valve in place
5. Start engine and allow it to operate until warm (thermostat opens)
6. Watch for any leaks and also watch the temp gauge. If it goes beyond middle turn engine off and check for air pockets and re-bleed system.
End result:
Once everything is working properly, re-install lower splash cover and enjoy your car!
Total time: 5 hours.
Useful procedures from TIS (Converted to PDF):
Water Pump Replacement
Draining & Adding Coolant
Venting Cooling System
Old 12-22-2008, 09:58 AM   #2
budman
-not a mod-
budman's Avatar
My Ride: ..
Excellent write up. Nice job.
-Gunnar
budman is offline   Reply With Quote
Old 12-22-2008, 10:03 AM   #3
JonJon
Tinfoilhatatarian
JonJon's Avatar
My Ride: .
Send a message via AIM to JonJon
Wow dude... WELL done
JonJon is offline   Reply With Quote
Old 12-22-2008, 10:08 AM   #4
davidwarren
Halfway to 2L
davidwarren's Avatar
My Ride: 2010 335i
good write-up. I need to do the expansion tank....
You down with UCC? Ya you know me!
sowing the seeds of jiggery pokery
davidwarren is offline   Reply With Quote
Old 12-22-2008, 10:56 AM   #5
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Nice write-up.
You need to get the BLING water pump shaft nut from bimmerworld!
Old 12-22-2008, 10:59 AM   #6
Custom3
My Ride: HellRot 330CI
nice...i did all that in the summer....very easy diy
Old 12-22-2008, 11:02 AM   #7
Colemanator02
My Ride: 2002 E46
Colemanator02 is offline   Reply With Quote
Old 12-22-2008, 11:23 AM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Damn man, freaking AMAZING write up!! Thanks
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 12-22-2008, 12:26 PM   #9
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Great write up. The OEM pump does look like a joke compared to the stewart pump. Ever since I installed my stewart pump, my coolant gauge always reads a tad lower. Is your coolant gauge still reading in the middle?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 12-22-2008, 01:47 PM   #10
paraklas
Originally Posted by aggieE46 View Post
Nice write-up.
Thanks. Whats the bling nut?
Mine too. It's a tad lower than before!
Old 12-22-2008, 01:53 PM   #11
bigjae1976
bigjae1976's Avatar
bling nut
Good, at least I'm not the only one. I really hope this Stewart pump lasts a long time. It was pretty expensive.
Old 12-23-2008, 04:09 AM   #12
paraklas
Old 12-23-2008, 10:25 AM   #13
bigjae1976
bigjae1976's Avatar
Yup, mine was in the same place before my thermostat went bad.
Old 12-23-2008, 10:44 AM   #14
taghirap
My Ride: tricycle...
Send a message via Yahoo to taghirap
Great diy
taghirap is offline   Reply With Quote
Old 12-24-2008, 12:27 PM   #15
dakkon
My Ride: e46 330ci/e30 318is
im going to be doing the exact same thing come spring, but i am also going to get the TMS underdrive pullies, temp should remain the same even with the undriving on the water pump, due to the increased flow of the stewert.
dakkon is offline   Reply With Quote
Old 12-24-2008, 12:47 PM   #16
aggieE46
Keep it clean
aggieE46's Avatar
http://store.bimmerworld.com/shared/...t=products.asp
Water pump shaft nut. Finishes it off nicely. Seriously.
Old 12-30-2008, 01:52 AM   #17
GunMoto
My Ride: EG8 | E46 | W211
Send a message via AIM to GunMoto
link *fixed*
http://www.nexternal.com/bimmerworl/Product706
GunMoto is offline   Reply With Quote
Old 12-30-2008, 02:52 PM   #18
danlauz
My Ride: 330 cic + X5
att: paraklas
my 2003 330 CIC (35000 KM)- manual .) is on rest for the winter. the car has been running 5 winters since dec 2002 and, for the last 2 winters, its inside my building sleeping at around 15 celcius. I know brake fluid and coolant fluid was made at BMW dealers in 2006. NOW, I plan to do the following in marsh-april 2009.. can you please give me your comments if you think its too much or, as I plan to keep my car for long time (running only during summer), parts cost is not an issue for me:
a) spark plug
b) brake fluid
c) power steering fluid
d) coolant fluid (what about expansion tank, water pomp, thermostat)
e) straps were never changed so, I will change them. I am thinking also to change the pullies.
f) transmission (manual 5 speed) and differencial (never done)
is there anything you would suggest to me ?
danlauz is offline   Reply With Quote
Old 12-31-2008, 04:43 PM   #19
paraklas
a) spark plug
No need unless you are experiencing misfires or other spark related problems
b) brake fluid
No need IMO, it can go another year
No need either
These usually go because of the continuous stress, so no need unless they are leaking/malfunctioning.
You can do the belts, cheap and easy. Pullies are not maintainance parts, no need
You can change both here
enjoy your car!! You've got really low mileage to be worried about anything. You can check the tires & pressures since it's not good for them being still for a very long time.
Happy holidays & new year!
Old 12-31-2008, 07:36 PM   #20
//TRD power
My Ride: 3.0 | 200hp | 214trq
very nice write up
//TRD power is offline   Reply With Quote
coolant, expansion, stewart, tensioner, water pump
