Old 06-20-2002, 08:44 PM   #1
BAVARIAN323i
Ballin'
My Ride: 1999 323i
Send a message via AIM to BAVARIAN323i
Anyone have any experience with wheel spacers? or have them?
do they rub ?
BAVARIAN323i is offline   Reply With Quote
Old 06-21-2002, 04:18 PM   #2
BAVARIAN323i
Ballin'
My Ride: 1999 323i
Old 06-22-2002, 04:46 AM   #3
presario
My Ride: 330ci
Depends on how many mm you want to push your wheels out. It also depends on what you are currently running. But if you push it out after measuring it correctly, you shouldn't rub. Let us know how much you want to push your wheels out.
Sig by Jojo//Celsius One
presario is offline   Reply With Quote
Old 06-22-2002, 11:39 AM   #4
AWay
My Ride: 330i
Send a message via AIM to AWay
I'm thinking about picking up a set of spacers too, but...
First I have to determine the offset's of the sport package type 68 wheels. My dealer told me et46 up front and et42 in the back, but he said it was confusing to him and these may not be right. If I got this information for sure, I would be able to determine how much of a spacer I could add in. Anyone know for sure the offsets?
Thinking about maybe 7mm all around, that should be on the safe side with my Cup Kit.
AWay is offline   Reply With Quote
Old 06-22-2002, 11:57 AM   #5
BAVARIAN323i
Ballin'
My Ride: 1999 323i
I have the non-sport suspension, and 18x8.5 rims with 225/40's - How much can I go?
thanks
Old 06-22-2002, 12:00 PM   #6
chrisbbb
My Ride: 99 328I
Send a message via ICQ to chrisbbb Send a message via AIM to chrisbbb
I might be wrong here but arent spacers bad for your car. By going to larger wheels and tires you are allready putting more stress on your car and now you want to put even more by shortening the length of your lugs.........correct me if Im wrong
chrisbbb is offline   Reply With Quote
Old 06-22-2002, 01:34 PM   #7
presario
My Ride: 330ci
Re: I'm thinking about picking up a set of spacers too, but...
Originally posted by AWay
Thinking about maybe 7mm all around, that should be on the safe side with my Cup Kit. [/B]
Whoa, 7mm all the way around should be too much for the sedan, especially if you have the CHs and the cup kit. Your front will rub like crazy and your rear should rub too.
You might be able to put 5mm rear only on the sedan with 18x8.5. The sedan has a rear fender size not much bigger compared to the front so there isn't much room to push it out. To be safe, just measure it. In my opinion, 5mm would be the max.
"I might be wrong here but arent spacers bad for your car. By going to larger wheels and tires you are allready putting more stress on your car and now you want to put even more by shortening the length of your lugs.........correct me if Im wrong"
When you purchase spacers, you have to purchase longer lug bolts which accomodate for the extension size. Thus for a 5mm spacer, you have to buy a lug bolt that is 5mm longer than the stock 27mm shank. Also, spacers are not bad. If you read the H&R website about their Trak spacers, they explain what spacers do. They are supposed to help with performance, although that is very very minimal. The old adage "wider is better" holds because it would help in cornering abilities. But how much difference is 5mm on each side gonna make? Probably almost none. It is mostly for looks- to full up the fender gap left by the wheels.
Old 06-22-2002, 06:47 PM   #8
AWay
My Ride: 330i
I forgot to mention...
I don't have my CH's anymore, sold them. And I was rubbing a little as they were, no way I could have done another 5mm anywhere!
Back to type 68's baby!
Old 06-22-2002, 10:26 PM   #9
BAVARIAN323i
Ballin'
My Ride: 1999 323i
you get longer lugs with the spacers, so you are not shortening them...
Old 06-22-2002, 10:35 PM   #10
Dev
PSHOPWERKS
My Ride: Yellow Porsche GT2
If you have 18x8.5 BBS CHs on a sedan, you won't need any spacers to push your wheels out further. You should be more worried about rubbing (if dropped).
PSHOPWERKS
Mods: 1 Inch Nail in Tire | Purple painted calipers (you know you like Purple calipers)
Current Hate Level: 10 | Previous Hate Level: 9
The hatin' level on the E46Fanatics.com board.
Dev is offline   Reply With Quote
