Old 01-06-2009, 11:29 AM   #1
Arin330i
My Ride: 2002 330i
dropping a s54 into a 330i
Is it possible to drop a s54 m3 engine into a 2002 330i? If so what is needed?
Arin330i is offline   Reply With Quote
Old 01-06-2009, 11:32 AM   #2
akb4
My Ride: is gone :(
323i but same thing..
http://e46.mit.edu/
akb4 is offline   Reply With Quote
Old 01-06-2009, 11:35 AM   #3
Arin330i
My Ride: 2002 330i
Wow! thanks for the link hahah, well im going to wait until college and maybe if i have the money and the time ill pull that one off :]
Old 01-06-2009, 11:37 AM   #4
akb4
My Ride: is gone :(
good luck, with the money part while in college.. im in college right now and im BROKE! just like every other person going to school.
Old 01-06-2009, 12:15 PM   #5
hoveringuy
My Ride: e30
I know someone that is installing an S54 that will run it with a euro S50 ecu. It will avoid the wiring mess that Mite46 had. Plug and play...
Hoveringuy
www.seattlecircuit.com
hoveringuy is offline   Reply With Quote
Old 01-06-2009, 02:48 PM   #6
Arin330i
My Ride: 2002 330i
Well, i have a full ride to OSU and my father is paying dorm and stuff of the sort, so my money will go to gas, parts and food! I am quite lucky on the money end, but enjoy buying and building my own cars, even though i could have my father pay for it all.
Old 01-08-2009, 10:34 PM   #7
Whammy
My Ride: ZHP
Hoveringuy
damn
Whammy is offline   Reply With Quote
Old 01-09-2009, 06:26 AM   #8
Bimmer Dude Xi
My Ride: 03 325XI 07 ZX-6R
Send a message via AIM to Bimmer Dude Xi
Has anyone tried dropping in a S54 into a E46 Xi?
|Dinan High Flow Air Box|Eibach Pro Kit|Koni Sport|UUC Strut Barbarian|UUC TSE3|UUC Underdrive Pulleys|18" VMR V710|
|BMC Race Air Filter|CRG Spectrum Levers| Galfer Steel Braided Brake Lines|Volar Motorsport Spiked Frame & Bar-end Sliders|
Bimmer Dude Xi is offline   Reply With Quote
Old 01-09-2009, 09:36 AM   #9
shock29
My Ride: '01 325i
S54 into an 4WD platform would be
shock29 is offline   Reply With Quote
Old 01-19-2009, 10:19 PM   #10
scottieprada
My Ride: 88m3 01 convt m3
does anybody no what is needed to put a e46 m3 into an 88e30 m3
scottieprada is offline   Reply With Quote
Old 01-20-2009, 12:06 AM   #11
Stealthwagen
My Ride: '00 323iT / S54 6Spd
Hoveringuy
Well, I suppose if the newer (S54 engine) will be used in an older-gen car, the backdating may be ....reasonable....and meeting emissions regs & stuff for an OBDI car, or older, will be doable in that case. Will definitely need someone who is comfortable with the electronics/software/firmware on these vehicles. Most importantly how the various modules interact with one another.
Plug & Play? Sure, as long as you have top-notch resources from which to draw. Else it'll be Plug & Pray.
My experience "dropping" the S54 into my E46 wagon was, well, more challenging than expected. Mechanical stuff (my expertise ) was a breeze. As Ben Liaw @ Rogue documented (props to Ben for his advice on my project ), everything pretty much bolts right in. That's the easy part. Making the M3 DME and associated M3 modules work together in a non-M vehicle is a challenge unless you have unlimited funds and can just change everything on a whim, or really, really, know what you're doing.
Remember that the DME, LKM, EWS, Ignition key, Body Control module and Gauge cluster all "talk" to one another over the CAN bus and so must think they belong together (ie. from the same vehicle). They look for S/N and mileage data stored in memory across themselves and it needs to cross-check. Otherwise, no start, or start with CEL's, poor running, etc. Some of this can be taken care of by "re-alignment" of the various units via the GT-1 or MODIC. Some not. Buying "uncoded" modules on a trial and error basis adds up to big $$ quickly. Burning a new "uncoded" DME with the wrong firmware is a $1000 screw-up. Oh, there are now 15 or 20 M3 DME p/n's to choose from in the BMW parts catalog. Trying to figure out which one you need can become a costly exercise. You can make $1000 paperweights in a hurry with one coding error on the GT-1. Then you have to figure out how to deal with signals (read: wires & connectors) that the M3 is looking for that don't exist on the transplant chassis & vice-versa.
So if you are electronically savvy in general and modern automotive CAN-bus system savvy particularly, have access to the specialized BMW diagnostic tools & equipment and to factory service data you can pull it off. Not impossible, but tricky. Far, far from "just drop it in" as so many here seem to think.
Beyond awesome when done of course.
Grocery Getter
Stealthwagen is offline   Reply With Quote
Old 01-21-2009, 12:07 AM   #12
scottieprada
Wow
thanks for the help
Old 01-21-2009, 10:49 AM   #13
dpgrand
My Ride: 2005 330xi
one word - transfer case
'05 330xi - Koni, H&R, Rogue, Supersprint, UUC, Dinan, Apex
dpgrand is offline   Reply With Quote
Old 01-21-2009, 02:35 PM   #14
hoveringuy
My Ride: e30
I think you've described the most difficult aspect of an S54 swap: the integration of stock contorl modules. They all talk to each other and the S54 ECU is worthless without them.
The beauty of the S50 euro ECU is that it's not as picky. It wants a VR crank signal but the S54 has a Hall sender. I've solved that (www.seattlecircuit.com). It also needs a road speed signal.
Other than that, the basic motor architecture is the same. Dual Vanos, same cam signal wheels, similar displacement, etc.
The swap is in progress and I'm excited to see how it turns out.
Meanwhile, my M54 OBD1 runs great. When I get my standalone VANOS controller dialed-in I expect it to make at least 260hp with 270 possible. Plus, it's ALUMINUM!
It's already making 200 at the wheels on the Dynojet with very basic intake VANOS only and no ECU tuning.
Old 01-21-2009, 05:07 PM   #15
Bryan@Jlevi SW
1.888.JLEVISW
My Ride: E46 330i ZSP
Send a message via AIM to Bryan@Jlevi SW
By S50 ECU do you mean the S50B30 DME?
Much of the same mechanical parts you would use for an E30 S5x swap. The difference will be the wiring, which is nuts.
Bryan@Jlevi SW is offline   Reply With Quote
Old 01-21-2009, 05:16 PM   #16
phrozen06
phrozen06's Avatar
My Ride: E46, E92 M3, R32 VW
Send a message via Yahoo to phrozen06
http://www.rogueengineering.com/Merc...y_Code=2002WAG
http://www.rogueengineering.com/Merc...y_Code=2003ZHP
phrozen06 is offline   Reply With Quote
Old 01-21-2009, 05:38 PM   #17
Stealthwagen
Steve:
Found one of your M54 ->E30 swap thread. Nice work! Lot's of fun bringing these beasts to life, eh? I take it you are the brains behind Seattle Circuits? Looked at the site the other night & like the work you do there too.
You're right about the full OBDII S54 project. It's tricky, but I wanted a vehicle I could drive every day, would be as close to a "factory" car as I could get it, and would pass emissions.
What will your car look like through the OBDI port? By that I mean when you go to get state inspection or emissions certification, I assume the car will come up as an E36 S50. I suppose that's fine. I don't expect most inspection outfits would wonder about that in an OBDII era chassis. Unless they cross-check the chassis S/N.
And I suppose finding a "friendly" inspection station is a possibility if need be.
In any case, props for your undertaking. I always enjoy seeing guys willing do take an innovative path.
I'd like to know more about the SA Vanos setup. How does it extract more poewr than the OE setup? Can you see it being adapted to the S54 and what sort of gains can be expected there? As you know, I'm already at 107 BHP/lit.
Good luck with the project & keep us posted on progress.
Best regards, Todd
Grocery Getter
Old 01-21-2009, 06:57 PM   #18
hoveringuy
My Ride: e30
Steve:
Best regards, Todd
I'm still active duty military so I haven't worried about emissions yet. Even when I get out I'm in a non-emissions area of Washington State.
That said, with my cat I'm sure the car could pass the sniffer. It's not like I run a radical cam or anything.
One thing I've learned in converting the M54 to OBD1 is that 90% of the effort BMW has made in improving the engine has gone towards economy and emissions. Power is only an added benefit if it doesn't impact the previous.
Case in point: Exhaust VANOS. While it does benefit torque at certain points by reducing pumping losses it was also meant as a way to have internal exhaust gas recirculation. I have heard of substantial gains in M54 power by retuning the VANOS from economy to power. More overlap at higher rpms isn't good for emissions but it sure boosts the power.
I haven't worried too much about developing the actual map yet. I still need to get the basic functionality nailed-down and bullet proof before I start burning time on the dyno.
The S54 has a different VANOS setup than M54. The cam has more sensor elements (7, I think) compared to my 2. The oil pressure is higher and there are two solenoids per cam. My cam takes about 1 1/2 seconds to traverse to full advance at 3000 rpm. I'm sure I could adapt it, however.
I'm as curious to know how it will turn out as you!
Old 02-03-2009, 10:18 PM   #19
ATLZHP6M
My Ride: TS2+ ZHP, ESS E39 M5
S54 on ZHP
I have some questions for you guys:
I'm considering the S54 swap, however I'd like to keep most of my ZHP parts.
Is it possible to use the ZHP stock diff (3.07) and drive shaft?
Also, could I use the same 6-speed manual tranny on my ZHP?
The exhaust is probably the least of my worries.
If I buy the engine, with the wiring harness, DME, Cluster and keys, what else would I need to do to make this work?
ESS TS2+ Street/Track Toy
ATLZHP6M is offline   Reply With Quote
Old 02-04-2009, 11:25 AM   #20
dpgrand
My Ride: 2005 330xi
Your existing tranny would work, but if you're going to be launching etc (aka being hard on it) know that a s54 packs more power than your m54, and the likelyhood of your tranny dieing is going to go up.
