Old 01-05-2009, 04:41 AM   #1
AfghanScarface
My Ride: Debadged M3
Send a message via AIM to AfghanScarface
Do I need to perform an additional wash after polish?
I am trying to bring back the luster of an old school Mercedes that is now my daily driver and mini project. I don't have too many fancy supplies at my disposal, but I am making do with what I got in the garage
My question is do I need to wash the car a second time after applying the polish/before applying the wax?
Here is my line up in this order given the supplies available:
1. Wash- Meguiar's Gold Class
2. Paint Correction- NuFinish Scratch Doctor
3. Wash again(?)- Meguiar's Gold Class
4. Paint Protection- Zymol (Blue Bottle)
Any help is greatly appreciated
Originally Posted by Bimmer4Lyfe View Post
Either pursue her and risk getting Mono, or don't pursue her,...stay home and use your Mano.
It's either Mono or Mano .... You decide
AfghanScarface is offline   Reply With Quote
Old 01-05-2009, 09:11 AM   #2
Len013091
My Ride: S52 E30, 330i
Send a message via AIM to Len013091
You can if you want, personally, I'd wipe it down with Isopropyl alcohol instead to remove polish residues.
Len013091 is offline   Reply With Quote
Old 01-05-2009, 10:49 AM   #3
Ultim8-One
My Ride: 2006 Carbon Black M3
I use poor boys spray n wipe after each polish step.
Ultim8-One is offline   Reply With Quote
Old 01-05-2009, 11:31 AM   #4
DetailDan
My Ride: Jeep
Send a message via AIM to DetailDan
NuFinish is loaded with fillers, so if you rewash or do an alcohol wipe down chances are you're going to remove the fillers and the paint wont look any different.
DetailDan is offline   Reply With Quote
Old 01-05-2009, 11:36 AM   #5
Custom3
My Ride: HellRot 330CI
a wash after wax is recommended if there are a lot of spots where white residue remains.
Old 01-05-2009, 03:08 PM   #6
Beematic
My Ride: Carbon Black M3
Best to mix 50/50 with water.
Beematic is offline   Reply With Quote
Old 01-05-2009, 03:17 PM   #7
AfghanScarface
How do you apply it and remove it?
Old 01-07-2009, 06:20 PM   #8
PuckMan
My Ride: 335i Coupe
I mix it in a spray bottle, spritz it on the panels and wipe with clean MF.
M3 + trailer hitch = oxymoron
PuckMan is offline   Reply With Quote
Old 01-07-2009, 06:50 PM   #9
DetailDan
My Ride: Jeep
Im tellin you, you're going to remove the fillers from nufinish and realize its not doing a damn thing. Itll be a good little experiment.
Old 01-08-2009, 12:19 AM   #10
Petrucci_M3
My Ride: 1995 M3
Exactly what I do, very simple.
Lol I was thinking the same thing.
1995 ///M3 Cosmos Black/Anthracite M-Cross/Amaretta
Petrucci_M3 is offline   Reply With Quote
Old 01-08-2009, 01:25 AM   #11
AfghanScarface
ok guys so what should I do after polish? Do I go directly to the Zymol? I initially thought it would be a good idea to give the car a second wash after polish. Was I wrong?
Old 01-08-2009, 12:42 PM   #12
dreamdrivedrift
My Ride: 99 M3 & 95 325i
Send a message via AIM to dreamdrivedrift
If there's a lot of residue go ahead and wash it, or QD it.
Chris
dreamdrivedrift is offline   Reply With Quote
Old 01-08-2009, 01:28 PM   #13
DetailDan
My Ride: Jeep
Heres the thing...
When I polish a car I wipe the areas down with alcohol to remove the polishing oils to make sure Im getting true correction. Sometimes, the oils in the polish can mask defects and make it look like they've been removed when they really haven't. After Im done polishing, I will rewash the car to remove all the polishing dust (the oils are already removed from the alcohol at this time).
The polishes I use actually removed imperfections, they dont contain fillers like many polishes, such as NuFinish for example. Nufinish will not remove the imperfections, it will do a good job of hiding them. So by rewashing or wiping the car down with alcohol you'll just be removing the fillers, revealing the same imperfections as before. Basically making what you're doing useless. If I was you, Id skip the nufinish all together. Instead, get a PC and some good polish. If you dont want to do that, than apply a filler heavy glaze which will do a good job of hiding the defects, than apply your wax. You could also use something like Megs NXT wax which also contains fillers.
Note that fillers and polishing oils are two different things. Some polishes are DESIGNED to fill, others arent, but sometimes do it unintentionally.
Old 01-08-2009, 10:10 PM   #14
AfghanScarface
The thing is that this car is really scratched and swirl marked. It was also neglected and left to bake in the sun for ages at a time. Even so the paint is actually in relatively good condition overall, it just needs a little "sprucing up". I don't really want to drop any cash on polish right now and I mean the NuFinish is right there in my garage. I just don't want to apply Zymol by itself, I think it needs more than that.
But I guess what i'll do is do the NuFinish and go straight to Zymol right after and let it seal. Then maybe go ahead and do a second wash to get rid of any residue. Thoughts?
Old 01-09-2009, 01:32 AM   #15
DetailDan
My Ride: Jeep
You can apply the NuFinish then wax it. You dont need to rewash after that, it wont be necessary.
Old 01-09-2009, 03:39 AM   #16
Petrucci_M3
My Ride: 1995 M3
Is the NuFinish just a filler? You might want to try at least a Meguiars polish.
Old 01-09-2009, 05:25 PM   #17
AfghanScarface
Goddammit you guys are gonna make me broke but fuk it I guess ill try to pick up some megs or poorboys polish
Old 01-12-2009, 02:31 AM   #18
Goldman Sachs
My Ride: 01 BMW 325i
You can use crap product but if you want to do it right you're gonna have to buy somethin else
Goldman Sachs is offline   Reply With Quote
Old 01-12-2009, 02:35 PM   #19
AfghanScarface
I really wanted to work with what I had in the garage but I am going to buy a polish.
