Thread Tools Search this Thread Rating: Thread Rating: 11 votes, 3.18 average. Display Modes
Old 12-05-2008, 08:35 AM   #41
steve.325i
My Ride: 2003 325i
Hi, on my 2003 325i auto I didn't have the electric fan they show here but a mechanical fan with a fan clutch.
The following link shows the tools you need - I ordered from bimmertools - & has another link to another forum covering the procedure.
http://forum.e46fanatics.com/showthread.php?t=564570
Steve
steve.325i is offline   Reply With Quote
Old 12-05-2008, 10:12 AM   #42
TX_Bullet
My Ride: 2001 325Xi
idle pulley aka deflection pulley for who was asking. I have the hydraulic system which im having a problem with.
I change my alternator this weekend and stripped the t-50 bolt in side the tensioner pulley. Does anyone know how to get this hydraulic system off?? Or have an idea of how to get the stripped bolt out?
I'm sure you guys know there isnt very much space with the fan out
TX_Bullet is offline   Reply With Quote
Old 12-05-2008, 10:36 AM   #43
darkmanlfe
My Ride: rocket propelled 323
Send a message via AIM to darkmanlfe
mine has been making noise since 2 years ago. especially in the cold morning. but lately it has stop after spraying WD40 on it. just dont spray it on the belt.
Albert Einstein once said - Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.
darkmanlfe is offline   Reply With Quote
Old 01-17-2009, 10:19 AM   #44
atlmcdonald
My Ride: 2001 325i BMW
I am trying to find the 32mm slim wrench and the pulley holder on line but I am not having any success. Can anyone help me out with identifying who I can get this from other than the local bmw dealership. I need to replace the idler pulley, but I cannot get the fan off.
atlmcdonald is offline   Reply With Quote
Old 01-18-2009, 11:05 AM   #45
steve.325i
My Ride: 2003 325i
fan clutch tool & 32mm thin wrench
Hi, as I said, I bought mine from bimmertools.com. It was a little pricey ($73), but they are really solid.
http://www.whatsyourconcept.com/item...asp?itemID=879
Old 01-18-2009, 03:02 PM   #46
FuzzBall
My Ride: `01 325i
Easy alternative instead of buying the pulley holder:
Spray your fan nut with some lube if it's seized.
Take the wrench, place it on the fan.
Remember, reverse threaded.
Take a hammer, and tap straight down while simultaneously using your left hand to push the wrench clockwise.
I've always used this method, and 90% of the time I can get it within 1-3 taps. The other 10% usually requires a bit more lube and another dozen taps.
Be careful, hit it too hard and you'll be buying a new water pump(I've never actually seen someone do this... but it's possible)
FuzzBall is offline   Reply With Quote
Old 03-23-2009, 09:36 PM   #47
lacrosseguy017
My Ride: 94 325i full m3 swap
very nice write up man, ill be bookmarking this for reference when i go to do this on, probably, wednesday.
1994 325i with full m3 swap from 1995 m3 /// S50 Engine ///Dinan 2 Chip /// CAI /// Front and Rear Cross Drilled and Slotted Rotors /// Coilovers /// 8000K Hella Projectors /// 8000K Angel Eyes /// Yellow Fogs
lacrosseguy017 is offline   Reply With Quote
Old 03-24-2009, 08:32 PM   #48
lacrosseguy017
help! i cant get the fan off. im sitting here turning the nut for the fan from left to right as noted on page 1 but nothing is happening, so help?
Old 03-24-2009, 08:40 PM   #49
Gun2Head
Gun2Head's Avatar
My Ride: 2001 325i
Do you have the two wrench set used to remove fan?
Vorsteiner Hood/Euro-Spec Bumpers/M5 Mirrors/Foose 18"/H&R Springs/KONI FSD/Toyos/Angels Eyes HID/Interior Xenon Kit/Dice/ Sharked/Conforti CAI/UUC TSE3/UUC FCAB/UUC SwayBarbarian/UUC Strutbar/UUC Underdrive pulleys/EE LED Tails
Detailed Image Auto Detailing Supplies
Gun2Head is offline   Reply With Quote
Old 03-24-2009, 10:37 PM   #50
lacrosseguy017
ha no i do not but i got it off like right after i posted that. i just used an 11/4 wrench, yes, eleven/four wrench and a really long screwdriver. the screwdriver was used as a crowbar to hold the part of the fan with 3 bolts still while i loosened the fan nut. but after that, everything was very simple.
Old 03-24-2009, 10:51 PM   #51
Gun2Head
Gun2Head's Avatar
My Ride: 2001 325i
Excellent! Some of the guys use the two wrenches and others are lucky enough like you to use one wrench and a long screw driver. I tried the screw driver and couldn't budge it, so off to the two wrenches I went. Change water pump as well while you were there?
Old 03-24-2009, 11:58 PM   #52
lacrosseguy017
nah, it was alreayd 930 here when i started that little project, so i was just more interested in getting the tensioner changed out, but turns out im gunna have to replace that deflection pulley as well because both that and the tensioner pulley had gone bad. so i'll get that sometime next week probably. i have a few other minor issues to worry about for now.
Old 07-12-2009, 10:14 PM   #53
guest0927
Banned
My Ride: E46
Cool
haha nice einstein qoute. well where is it did you actually spray wd-40 on...if you didnt spray on the belt??? and till this day does it still squeal???
guest0927 is offline   Reply With Quote
Old 07-30-2009, 12:57 PM   #54
jbarber617
My Ride: 2002 325i sedan
Talking Tensioner Replacement
My engine started making a loud whining noise at start up but would disappear when it warmed up. The dealer said it was the tensioners and wanted $1300 for the repair. I found this great post and it gave me the confidence to try the repair myself. I bought 2 new tensioners and belts from Autohaus AZ and a $15 32mm wrench at Autozone and did the repair myself in about 90 minutes. The engine sounds like new again. Thanks to E46Fanatics for saving me over a thousand bucks!!!
I ended up getting the mechanical tensioners. I drive the car about 10,000 miles a year so I figure I have another 7 or 8 years before I have to worry about this again.
jbarber617 is offline   Reply With Quote
Old 07-31-2009, 01:47 AM   #55
ThatGuy_JZ
My Ride: '02 Steel Blue 325Ci
Send a message via AIM to ThatGuy_JZ
Thanks for this DIY, it helped me when I replaced mine!!
- 2002 Steel Blue 325Ci -
ThatGuy_JZ is online now   Reply With Quote
Old 10-22-2009, 12:09 PM   #56
Devious1
Invalid User
My Ride: 330ci
Send a message via AIM to Devious1
you only need to replace those pulleys? i thought the tensioner was a whole unit.
Devious1 is offline   Reply With Quote
Old 10-22-2009, 07:27 PM   #57
steve.325i
My Ride: 2003 325i
True for the stationary (idler) pulley only.
If you have the non-hydralic version, you can not purchase just the tensioner pulley, you have to replace the complete tensioner & pulley assembly.
Old 10-23-2009, 01:37 PM   #58
ssm1991
My Ride: 2004 325i
Get 11-28-1-435-594. It's the deflection pulley for the E46 316i/318i and is exactly the same as the M54 mechanical tensioner pulley. Dealers there in NA won't stock them since the 316i/318i weren't released there, but can still be ordered from Tischer for $37.45 (with some waiting time).
ssm1991 is offline   Reply With Quote
Old 10-23-2009, 01:44 PM   #59
Devious1
Invalid User
My Ride: 330ci
how do you tell which one you have? i have an 2002 330ci
Old 10-24-2009, 08:15 AM   #60
steve.325i
My Ride: 2003 325i
I was worried about the same thing. You just have to do a visual and see it it looks like item # 2 in post 57 (non-hydrallic) or if it looks like the pic in post 9 & has a hydrallic cylinder.
Not much help I know. But if you have the hydrallic type the cylinder should be easily identified.
I also highly recommend doing the idler pulley @ the same time. It's inexpensive and it typicall goes with the same frequency of the tensioner pulley.
