Old 01-30-2009, 04:00 PM   #1
MyKmYk
My Ride: E46/E90 M3, Mini CMS
Send a message via AIM to MyKmYk
Ebay Headers Woes....
Ugh. So I love my Ebay headers. LOVE. But I know I wont pass my inspection. I have about 6 months left, so I've been gathering my options.
Went to this great local shop to see how much it would run me to get something legal in the cats/exhaust dept. He said it was not even possible.
As a result I've decided that I want to get an O2 sim. and just put in high flow racing cats with a new exuast setup. That should satisfy all the needs of the inspection, correct? I'm in Texas, btw. My local mechanic told me all this should work, but I wanted to run it by the knowledble people here 1st.
Thanks in advance.
MyKmYk is offline   Reply With Quote
Old 01-30-2009, 04:09 PM   #2
KriTiKaL AspecT
My Ride: 2001 AW 330Ci
Yea your in good shape going that route.
Headers - KW V2 - Hotchkis Sways - 55w 6000k HID - 35w 6000k HID fogs
EVO 3 SSK mit ein DSSR - EE Tails - Meyle LCA, FCAB, & RTAB w/ Rogue Limiters - M3 Mounts ....
-Paul
KriTiKaL AspecT is offline   Reply With Quote
Old 01-30-2009, 04:17 PM   #3
KriTiKaL AspecT
I just noticed your DFW. Will your car be sniffed? A high flow cat might not do the job.
I have three more months until my inspection. My o2 filters should passify my DME I just hope my resonator will mistaken for a cat.
-Paul
Old 01-30-2009, 04:23 PM   #4
TxZHP04
My Ride: ESS TS2+ ZHP
To my knowledge, they only sniff pre-OBDII cars around here.
Old 01-30-2009, 04:43 PM   #5
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Yeah, they'll just look to make sure your ready light is on and that you don't have an SES after it's started.
I feel your pain, man. It's not a fun situation.
Old 01-30-2009, 06:34 PM   #6
MyKmYk
Tell me about it. I'm seriously considering just going back to stock headers. I figure you get about 8-10 horses from the headers, and my shop told me they can get me about the same effect and responsiveness (as headers) with a full custom exhaust setup that will easily pass emissions and sound great.
Maybe I can get someone local to help me do it myself..... Oh how it hurts to love your car so.
Old 01-30-2009, 08:03 PM   #7
SammyV
My Ride: CB M3
Send a message via AIM to SammyV
i doubt you will get 10hp from a catback if you retain the cats.
SammyV is offline   Reply With Quote
Old 01-30-2009, 10:28 PM   #8
MyKmYk
So from what my exhuast guy has said, the problem with O2 sims is that it will cause the car to run too lean on a regular basis, causing the car the get worse mileage. Additionally, it will cause the racing cats to fail prematurely should I have cats put on. So thats not too encouraging to me.
But all these issues are just so.....!
Old 01-30-2009, 10:40 PM   #9
netengwiz
My Ride: E46 330i
If you get ceramic cats, yes. I would recommend metallic high flow cats like those sold from Magnaflow. That's what I have installed.
|KW V2|Volk LE37T|Dinan|Eisenmann|Rädenergie|FormulaOne|Stoptech|Evospor t|Eibach|
2010 Audi Q5 Premium Plus S-Line|H&R|
2012 Ducati Streetfighter|Termignoni|DP|Lightech|Rizoma|
netengwiz is offline   Reply With Quote
Old 01-31-2009, 03:46 PM   #10
JohnBlaze
My Ride: Black Sunshine
The postcat O2's have nothing to do with running to rich or lean. It's the precat O2's readings that the on board computer uses to modify air fuel ratio. The postcat O2's are simply for emissions readings, or that's my understanding...
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Old 01-31-2009, 04:17 PM   #11
MyKmYk
I hope your right. In that case I wouldnt mind going the O2 SIm route.
I need to get my car codes read. I just have the light at the moment. Also, if I try the defouler method how will I know its working? Do I need to install it, clear the codes, and then wait to see if the light comes on? Or should I clear the codes, install, and then start it up?
Old 01-31-2009, 10:22 PM   #12
aggieE46
Keep it clean
aggieE46's Avatar
Mine netted about 20 to the wheels. I was sad to see them go.
Old 02-01-2009, 10:58 AM   #13
MyKmYk
I'm going to try the defouler method soon. /you needs a 1/2" drill bit to make the sensor fit, correct?
