Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
#1 |
Ebay Headers Woes....
Ugh. So I love my Ebay headers. LOVE. But I know I wont pass my inspection. I have about 6 months left, so I've been gathering my options.
Went to this great local shop to see how much it would run me to get something legal in the cats/exhaust dept. He said it was not even possible. As a result I've decided that I want to get an O2 sim. and just put in high flow racing cats with a new exuast setup. That should satisfy all the needs of the inspection, correct? I'm in Texas, btw. My local mechanic told me all this should work, but I wanted to run it by the knowledble people here 1st. Thanks in advance. |
#2 |
My Ride: 2001 AW 330Ci
Yea your in good shape going that route.
![]() Headers - KW V2 - Hotchkis Sways - 55w 6000k HID - 35w 6000k HID fogs EVO 3 SSK mit ein DSSR - EE Tails - Meyle LCA, FCAB, & RTAB w/ Rogue Limiters - M3 Mounts .... -Paul BSME |
#3 |
I just noticed your DFW. Will your car be sniffed? A high flow cat might not do the job.
I have three more months until my inspection. My o2 filters should passify my DME I just hope my resonator will mistaken for a cat.
#4 |
To my knowledge, they only sniff pre-OBDII cars around here.
#5 |
Keep it clean
Yeah, they'll just look to make sure your ready light is on and that you don't have an SES after it's started.
I feel your pain, man. It's not a fun situation.
#6 | |
Maybe I can get someone local to help me do it myself..... Oh how it hurts to love your car so. |
#7 | |
#8 |
So from what my exhuast guy has said, the problem with O2 sims is that it will cause the car to run too lean on a regular basis, causing the car the get worse mileage. Additionally, it will cause the racing cats to fail prematurely should I have cats put on. So thats not too encouraging to me.
But all these issues are just so..... ! |
#9 |
If you get ceramic cats, yes. I would recommend metallic high flow cats like those sold from Magnaflow. That's what I have installed.
![]() |KW V2|Volk LE37T|Dinan|Eisenmann|Rädenergie|FormulaOne|Stoptech|Evospor t|Eibach| 2010 Audi Q5 Premium Plus S-Line|H&R| 2012 Ducati Streetfighter|Termignoni|DP|Lightech|Rizoma| |
#10 | |
s54door
#11 | |
I need to get my car codes read. I just have the light at the moment. Also, if I try the defouler method how will I know its working? Do I need to install it, clear the codes, and then wait to see if the light comes on? Or should I clear the codes, install, and then start it up? |
#12 | |
Keep it clean
Mine netted about 20 to the wheels. I was sad to see them go.
#13 |
I'm going to try the defouler method soon. /you needs a 1/2" drill bit to make the sensor fit, correct?
