Old 02-15-2009, 03:50 PM   #1
323tom
My Ride: 2 turbo e46's
LSD/Headers/Cams Question
hey guys, I currently have a 2000 323ci, If I dont sell my supercharger to do a s54 swap I will strap my charger on and buy a LSD and headers and possibly cams... What diff would be perfect for a blown 323? If you have links I would apretiate it, also what about cams and headers what brands would you suggest and also post links if you have them... By the way I dont want ebay headers so dont post pics of those please... All quality parts please, Thanks..
323tom is offline   Reply With Quote
Old 02-16-2009, 07:45 AM   #2
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Technik headers and Schrick or Technik FI cams.
Old 02-16-2009, 01:41 PM   #3
323tom
hey
ya I was thinking technick headers/cams as thats what my supercharger is but I am sending my ecu to be reprogrammed to AA so I may just buy active headers and skip out on the cams as there really pricey and exspensive to install, as for the LSD I have heard 3.46 diffs are best for my application, Do I just buy a stock used diff someone is buying and have it rebuilt or is there rebuilt diffs out there for sale? If so can someone send me a link I know Tunermotorsport sells them but I cant find one on the site for some reason lol..
Old 02-16-2009, 08:49 PM   #4
aggieE46
Keep it clean
aggieE46's Avatar
Go with the Technik headers. Better gains.
Old 02-16-2009, 09:50 PM   #5
TxZHP04
My Ride: ESS TS2+ ZHP
I don't believe Turner is stocking limited slip units any more. Koala Motorsport, Performance Gearing, Diffsonline, and Metric Mechanic will build you a complete diff in whatever ratio you want. They'll ship you the built diff then you swap it in and return your old diff for a refund of the core charge.
Old 02-17-2009, 04:18 PM   #6
323tom
hey
hey thanks for the companys websites... I priced out a diff at diffsonlines website and a diff for my 2000 323 in a 3.46 ratio is 3800-600 core charge+shipping? Thats seems like alot I remember turner motorsport used to have a LSD for 1999 which I thought wasalot at the time but now that I have the money it seems to be even more?
Old 02-17-2009, 08:07 PM   #7
TxZHP04
Turner wasn't selling a complete final drive, only the LSD unit (ie, no case, no ring and pinion gear set, etc). Once you bought their LSD, you had to have it built into a diff. Diffsonline, etc provide a completely built final drive. I actually recommend buying a complete final drive assembly like this as they are built by pros so there are no concerns about your local installer not getting the pre-loads exactly right and ruining your expensive LSD unit. They also typically come with a warranty (my diff from KMS did) so even if there were a problem, it becomes a simple warranty matter and not an exercise in finger pointing.
Old 02-17-2009, 09:45 PM   #8
323tom
diff
hey alright I somewhat understand now... So diffs are over 3000$ your saying as there custom made and ready to swap right in? Thanks
Old 02-17-2009, 11:38 PM   #9
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Depends on a lot of things. I'd call Diffsonline and discuss what your options are.
