Rating:
Display Modes |
#21 | |
-Dave
2002 325xi - Titanium Silver - Sold 2009 335i x drive Sedan - Space Gray, M Sport Package |
#22 |
sweeet!
#23 |
ALL 99 and up should do it anyways. Hold down unlock button and all four windows will go down including sunroof. Put key in driverside door handle and turn to the right and hold until all go back...
![]() 03' 330i Mods |M Tech II|P46| Orion V2|Painted Rear Diffuser and Moldings|Clears|Painted Grills|Koni FSD|Eibach|M6|WeissLicht LED| 09' ///M5 Mods |BMW Performance Gloss Grills, Gills and Reflectors|SuperSprint|RPI|WeissLicht LED| |
#24 |
Power steering hose replacement
Does anyone have a write up on changing power steering hoses. I have a couple of hoses leaking. The Stealership quoted me $600 for P&L. I would like to diy.
#25 |
This will definitely come in handy!
#26 |
DIY Dash Removal / Replace.
http://forum.E46Fanatics.com/showthread.php?t=628898 Useful for Double-DIN installs, Bluetooth, replacing damaged / cracked parts etc... |
#27 |
#28 |
Is there a DIY for the expansion tank on an automatic with the mechanic fan? I've only seen the manuals done.
#29 |
Hey does anyone know if there is a DIY for this front splitter? http://www.turnermotorsport.com/imag...itter_1_lg.jpg
#30 |
Is there any DIY necessary for changing brake pads and discs?
Have done it on one other car (non-bmw) and am unsure if there is anything I need to keep in mind. For instance on a Rover I owned, when replacing the pads the brake cylinder needed to be pushed in, which required you to twist it while pushing... |
#31 |
^ Check this website´s Tech section, DIY for changing brake pads.
No, no, there is no climate change, it just getting hotter and hotter....and hotter. Yeah, right!?!!? |
#32 | ||
Owner/Admin
I've organized the list into categories, it should help people sort through the list easier. I have a couple more links to add from my PMs as well! Tim
#33 |
greatest thread!!
#34 |
DIY for lighted cupholders
I just stumbled across this. This could concievably be done to amke a Euro center tray lighted as well.
http://www.tmk.com/cupholders/index.shtml |
#35 |
cool thread! thanks.
#36 |
My Ride: my favorite two feet
found this link today very helpful as i'm about to do this diy
http://www.lincomatic.com/e46sunroof/e46sunroof.html moonroof repair |
#37 |
bump for class of 2010
#38 |
Any DIY links on changing rear springs?
#39 |
There isnt one on adjusting the parking brake
![]() I keep seeing threads where people ask how to do it but they always get the e-brake boot response. I want to do the proper adjustment in the rear where you have to remove the wheels and all that. Ill see how it goes... |
#40 |
Here's a free bump - it's always worth looking through this
