Old 02-14-2009, 06:55 AM   #1
BMW3 tamayo
My Ride: 01 325i sedan
Depo P46's just installed question
I just installed the Depo's P46s and there is some moisture in the headlights. How do I get the moisture out? Also, How do adjust the lights so I'm not blinding on coming traffic?
BMW3 tamayo is offline   Reply With Quote
Old 02-14-2009, 07:31 AM   #2
mistrzmiasta
My Ride: GLK350,ML63,Duc 748
remove the front lens...its held in by tabs that you have to lift up and pull it off...i believe there is 8 tabs to lift and then it pops out to remove moisture....to level them there should be a plastic screw you can turn with a phillips screwdriver....park your car about 20 feet away facing a wall and turn the screw until its about level
mistrzmiasta is offline   Reply With Quote
Old 02-14-2009, 07:54 AM   #3
dfjaws
My Ride: '07 335i / '02 Z3
One trick to make sure the lights are level is to pull forward (towards the wall) slowly and see if the light moves. If the beam moves down the wall, they are angled up, if it moves up, they are angled low. Keep trying that until the 'cut' doesn't move up or down the wall, or at least until its close
dfjaws is offline   Reply With Quote
Old 02-14-2009, 08:32 AM   #4
NorthJersey 3er
NorthJersey 3er's Avatar
My Ride: '03 M3 / '72 2002tii
+2 to what these guys said. when you have the lens unclipped, theres a rubber seal that runs around the headlight unit itself, get a heat gun or hair dryer and heat it up the seal a bit to soften it then put the lens back on and you'll be good to go
Matt
co-founder of
euro techniks
NorthJersey 3er is offline   Reply With Quote
Old 02-14-2009, 11:01 AM   #5
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: 335i
Also when you have the lenses off, make sure none of the lense guides have been bent across the rubber seal. Happened to me, see bottom right corner of pic. I bent it back and it fixed my fogging issues.
-Gary
DiscoStu is offline   Reply With Quote
Old 02-14-2009, 11:52 AM   #6
BMW3 tamayo
Thanks guys, I'm alittle scared to remove the lenses since they are brand new head lights.
Old 02-14-2009, 12:57 PM   #7
mistrzmiasta
dont be scared i mean its very very easy to do...take your time with the clips and you should be fine brother
Old 02-17-2009, 10:24 PM   #8
BMW3 tamayo
Alright, just did everything you guys suggested and there is still moisture. Are the bulbs not in tight enough? Help.
Old 02-17-2009, 10:45 PM   #9
XPLCTBMW
My Ride: is soldddd
Send a message via AIM to XPLCTBMW
how the hell are you getting more moisture in there so quickly if u just tried the above methods?
XPLCTBMW is offline   Reply With Quote
Old 02-17-2009, 11:02 PM   #10
BMW3 tamayo
don't know, but it is pissing me off. It is not as much moisture as before, mostly near the bottom of the lens.
Old 02-17-2009, 11:04 PM   #11
325inut
My Ride: Nissan 350Z
I have the same prob. It's weird.
325inut is offline   Reply With Quote
Old 02-17-2009, 11:13 PM   #12
sandman512
My Ride: 2005 325I
Here's a pic. on how to adjust the lights if you still need to.
sandman512 is offline   Reply With Quote
Old 02-18-2009, 01:39 AM   #13
fndrh1st
My Ride: 01 325i
i get moister in my left p46 from time to time. Its usually because the weather stripping is not seated right on the plastic. Heat it up or glue it. However you want to have it stick on.
fndrh1st1
fndrh1st is offline   Reply With Quote
Old 02-18-2009, 02:14 AM   #14
brysterman
My Ride: 2002 330Ci
Not to be a smartass, but did you make sure the moisture was out of the headlight assembly before putting it back together? I made that mistake on some taillights from an old car--I felt like a moron...
brysterman is offline   Reply With Quote
Old 02-20-2009, 01:12 PM   #15
BMW3 tamayo
yes, first thing I did was remove the moisture. I was told 2 things I can do is:
Drill a tiny hole at the bottom of the light or make the existing vent holes bigger.
Old 02-20-2009, 01:32 PM   #16
sandman512
My Ride: 2005 325I
\Wouldn't that let moisture in?
Old 02-20-2009, 01:33 PM   #17
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
I don't recommend drilling into the headlights, the problem is that there is an open seal on your headlight somewhere. Make sure the rubber boots on the back of the headlight are 100% secure.
Old 02-20-2009, 07:18 PM   #18
BMW3 tamayo
I figured that drilling was a bad idea, I'll check all the seals again.
