Old 02-26-2009, 03:47 PM   #61
TX_Bullet
My Ride: 2001 325Xi
Car still isn't done, last time i talked to the mechanic he told that he is going to have to replace the rubber hose coming from the master cylinder to slave cylinder.
He is under the impression that the throw bearing is not releasing because the clutch pressure line is damaged not allowing fluid to go back only forward(like a check valve)
Originally Posted by jbeurotech View Post
Sometimes the Cheapest quote is the most expensive in the end
Number of Destroyed Newb Destroyers- 1
The Mods
Power Flex FCAB
Much more coming.....
TX_Bullet is offline   Reply With Quote
Old 02-28-2009, 12:25 PM   #62
TX_Bullet
My Ride: 2001 325Xi
I went to the shop last night and made some very key observation. I saw that the guide tube http://www.realoem.com/bmw/showparts...25&hg=23&fg=15 #2 in the drawing is making severe contact with the clutch disc.
When you start the car in nuetral you here a loud screeching sound( metal to metal contact), but when its started in gear(clutch in) it tries to move and if you hold your foot on the great( obviously the car doesn't move, but stays running)no screeching sound and is a b*tch to get out of gear.
What I'm observing is that this man put the clutch disc in backwards.
What happens when he needs to take off the SAC pressure plate to flip the clutch disc to the other side. How do you calibrate it?
The Mods
Power Flex FCAB
Old 03-01-2009, 11:20 AM   #63
jbeurotech
Regional Sponsor
My Ride: 2000 E46 with 254K
Did you find the cheapest shop to do the work??? Find a better shop sounds like they don't know what they are doping but hey they probably were the cheapest....... I lose jobs every day because I am "to Expensive" however most end up back at the shop for the work to be redone or repaired. Sometimes the Cheapest quote is the most expensive in the end
Seth Thorson
Service Manager/BMW Tech
JB Eurotech Service "Your Reasonable Dealer Alternative"
General Questions can be sent to appointment@jbeurotech.com
1. Do not argue with an idiot. He will drag you down to his level and beat you with experience.
2. Light travels faster than sound. This is why some people appear bright until you hear them speak.
jbeurotech is offline   Reply With Quote
Old 03-01-2009, 06:26 PM   #64
TX_Bullet
My Ride: 2001 325Xi
When your right.........your right.
Actually it was my friends shop who normally does performance work on muscle cars. BMW was a new breed to him.
Yesterday I went over there and pulled the tranny out with him to explain that he indeed have the clutch disc backwards. Nothing was damaged except my wallet for having to buy a tranny I never needed.
I have learned my lesson on this one for sure. Next time DIY
Now that the clutch chapter is closed time to do the valve cover and power steering hose.
I greatly appreciate all the members that helped me with any and all knowledge they could provide.
The Mods
Power Flex FCAB
Old 09-01-2016, 11:40 PM   #65
Jholmes8541
My Ride: Acura tl, bmw 530i,
Originally Posted by TX_Bullet View Post
The only that I think it may be is #5(http://www.realoem.com/bmw/showparts...94&hg=21&fg=10) in the picture snapped while I was bleeding the system and now I have a M10 bolt in its place.
This is the last straw, my father feels that the clip breaking and as much play is in the clutch now is why she is not disengaging. The clip will be installed today, I'll keep you posted.
Are you having the exact problem?
Did you ever figure out what the problem was? I currently have the sane issue_nr_
Jholmes8541 is offline   Reply With Quote
