Old 10-14-2008, 08:23 PM   #1
trippmann
My Ride: 2000 323i
Send a message via AIM to trippmann
DIY: Trunk Acess
hey guys, my first diy, so cut me a break!
As always, i am in no way responsible for anything that happens to your car if you follow these steps, to your own car.
1. Start in the back seat. Open the armrest.
2. Pull the leather sheet down
3. Pull out the black foam thing... and discard.
4. You should now be left with a metal plate, tack welded in about 10 spots. now procede to the trunk.
5. With the trunk open, "go figure" remove the 4 plastic screws from the back pannel.
6. then just pull the blue covor out.
7. Ok here's the hardest part. i personally used a dremel 400xrs, or what ever the name is, with the high strength metal cutting bits. i went through 1 used, and one brand new one.
8. Locate the 10 or 12 spot welds, and use your dremel to grind away the welds.
9. Once all welds are broken, kick, puch, head butt, i dont care the metal plate and it will pop out into the cabin area.
10. *Optonal* I took a sanding bit, and with my dremel i ground down the corners and sharp edges, and ran a piece of clear tube over the area, to prevent cuts or whatnot.
Thats all guys, good luck! hope i did an allright job!
I'm surprised along with "making 100k a year, and dating super models" this forum doesn't have "make my girl cum every time" to the list.
Originally Posted by Tampa02e46 View Post
^It seriously was the worst decision of my life to sign up for this site.
trippmann is online now   Reply With Quote
Old 10-14-2008, 10:49 PM   #2
Autobot325i
My Ride: 2003 325i E46
Send a message via AIM to Autobot325i
wish i had a folding arm rest...but i did knock out the metal plate with my fist
***NEW UPDATE***
1985 318i E30
Autobot325i is offline   Reply With Quote
Old 10-14-2008, 11:24 PM   #3
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
what are your plans for the cutout
/_________\
OO=[][]=OO
Old 10-15-2008, 04:06 PM   #4
trippmann
My Ride: 2000 323i
thinking about doing a soundsystem upgrade. but....i know nothing of audio electronics... so 2 subs, something else, and some sick looking blacklight neons!
Old 10-16-2008, 11:31 AM   #5
HELLAS NC
My Ride: 03 320Diesel Tractor
NEONS!!! AAAAAAAAAAAAAAARRRGGGHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sound:
Neons:
I don't have a solution, but I admire the problem.
HELLAS NC is offline   Reply With Quote
Old 10-16-2008, 05:23 PM   #6
//TRD power
My Ride: 3.0 | 200hp | 214trq
does anyone sell a mini fridge that can fit in there like the 760Li?
//TRD power is offline   Reply With Quote
Old 10-16-2008, 07:07 PM   #7
Anub!s
My Ride: 330ci
Send a message via AIM to Anub!s Send a message via MSN to Anub!s Send a message via Yahoo to Anub!s
i know of something you can put in a hole
seriously though, say no to neons
Anub!s is offline   Reply With Quote
Old 10-16-2008, 08:02 PM   #8
trippmann
My Ride: 2000 323i
you dont think that neons in the trunk, or some sort of lighting to go along with the system would look good?
Old 11-25-2008, 04:21 AM   #9
Burger888
My Ride: 03 325i M Sport Pack
Can anyone comment as to whether doing this actually increases road noise inside the cabin?
People talk about how well sealed the cabin is when talking about subs located in the trunk. I have been thinking about doing this to open up the amount of bass from the trunk, but am concerned about increased road noise.
Burger888 is offline   Reply With Quote
Old 11-25-2008, 09:22 PM   #10
trippmann
My Ride: 2000 323i
personally, i have NOT noticed any increse in road noise. and even if you did, your going to be putting a sub or something in so that would sort-of counter-act it no?
Old 11-26-2008, 03:38 AM   #11
Burger888
Yeah, but I'm debating whether to try and mount the sub direct in the ski pass in IB or have it in the actual trunk in an enclosure with the ski pass hole just allowing bass to enter the cabin.
Have you done anything with a sub install after you knocked your ski pass out?
Old 11-26-2008, 10:09 AM   #12
Whammy
My Ride: ZHP
What if you do not have the armrest in the back seat (upper)?
Whammy is offline   Reply With Quote
Old 11-26-2008, 07:39 PM   #13
trippmann
My Ride: 2000 323i
i have not decided on a sound system, and as for the lack of arm rest, ive never owned a bmw that hasnt had one so i cant say. sorry
Old 12-19-2008, 04:53 PM   #14
rsultan84
My Ride: 2005 330i ZHP
Is there anyway to turn this into something like for putting your skiis though? I don't have the cold weather package so, I lack the folding seats. Every car I have had before this had them standard... grr.
I can't go skiing with my ZHP. Not that the tires are great in the winter anyway. But. Id like to have the option!
rsultan84 is offline   Reply With Quote
Old 12-21-2008, 01:27 AM   #15
er1c
My Ride: 2005 M3
Send a message via AIM to er1c
I have a 323i which came stock with no ski hole and no rear armrest.
I knocked out the steel plate, thus opening up the hole.
And I purchased a used rear bench seat /w backing & armrest on the forum here.
And bam... I now have a rear armrest and ski hole.
The rear seat backing w/ armrest and without armrest both have the same fitment. Pop out old seat with no armrest and pop new one in with armrest.
er1c is offline   Reply With Quote
Old 03-03-2009, 07:58 AM   #16
xavi330i
My Ride: 2004 330i smg
I would hate to get my arm cut by those sharp edges. But I have a one piece rear seat.
xavi330i is offline   Reply With Quote
Old 03-06-2009, 09:25 AM   #17
Focal E46
My Ride: is a DIYer
This is the greatest thing I found all day. I have two HUGE subs and I always have to leave one of the seats down to let some of that moving air and sound out. Of course, when I park the car I have to put the seat up so no one sees the system and breaks my window. Then when I get in I forget to pop the trunk and put the seat back down. This solves everything. Thanks to the poster!!
Focal E46 is offline   Reply With Quote
Old 03-06-2009, 09:28 AM   #18
Custom3
My Ride: HellRot 330CI
nice....
Old 03-20-2009, 11:42 AM   #19
325CI Man
My Ride: 2001 325CI
i have the exact same problem. plan on cutting this thing out as soon as i get home. no more folded down back seat. thanx
325CI Man is offline   Reply With Quote
armrest, boot, diy, ski, trunk
