Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 02-10-2009, 07:37 PM   #41
mimalmo
My Ride: 04 330i ZHP 6MT
Originally Posted by imolazhp_ci View Post
What test equipment did CNET use?
We are relying on their so-called "eagle eyed reviewers" so I'd like a list of the gear those guys use so I can better understand what their "reference" point is.
If you are used to driving around Yugos a short trip in a Corolla will seem like heaven and a drive in a Lada might seem OK too.
Subjective tests should never be the argument for such a definitive statement as is made by CNET. A fine example of poor journalism.
mimalmo is offline   Reply With Quote
Old 02-12-2009, 08:06 PM   #42
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
I assume you guys all put the cheapest gas in and the cheapest tires on your car also?
Weakest link theory: make your weakest link the component that costs the most to upgrade.
Service call theory: troubleshooting service calls are more expensive than buying better stuff to start with.
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is offline   Reply With Quote
Old 02-12-2009, 09:02 PM   #43
Owtlaw333
My Ride: 2009 Mazdaspeed 3 GT
Oh c'mon... that hardly applies here. As long as the leads are good on the cable, these will do any typical setup just fine and you know it!
Bringing it back for the new people...
productionof1.com
|||_Buy my photos?_|||
Owtlaw333 is offline   Reply With Quote
Old 04-15-2009, 01:44 AM   #44
NFRs2000nyc
My Ride: S2000+Wrangler
Some good tests for you guys to check out, and learn about HDMI, not get duped by salesmen.
http://gizmodo.com/gadgets/hdmi-cabl...t-2-268788.php
http://gizmodo.com/gadgets/hdmi-cabl...ale-282725.php
The fact of the matter is, it all depends on length and resolution. Under 30 feet, and 1080p, you will not notice a difference with a decent monoprice cable, and a $5000 solid gold cable.
NFRs2000nyc is online now   Reply With Quote
Old 04-15-2009, 09:05 AM   #45
GlockMan
GlockMan's Avatar
Just replaced some Monoprice cables for a customer having problems.
WooHoo.
It is the best!
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 04-15-2009, 09:06 AM   #46
GlockMan
GlockMan's Avatar
That is suprising considering what the inventor of the HDMI has said in every training that we have attended with him.
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 04-15-2009, 04:32 PM   #47
Owtlaw333
WooHoo.
It is the best!
productionof1.com
|||_Buy my photos?_|||
Old 04-15-2009, 05:05 PM   #48
GlockMan
GlockMan's Avatar
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
Old 04-16-2009, 02:38 AM   #49
NFRs2000nyc
Listen, I don't mean to offend anyone, nor do I want to argue about things like this, especially with someone that does this for a living. I am 100% certain that you know at least 3 times more than me on the subject of home audio and video.
I am only here to discuss science, and get to the truth. Scientifically speaking, digital signals are exactly that, digital. Which means, they are either ON or OFF. Weird images on a TV is NOT a bad signal. It is extra artifacts introduced to a picture (not like the old days when you needed to put the rabbit ears EXACTLY in the right spot to get a clear picture.)
Assuming the cable isn't damaged, a short run can be any kind of wire. If you are good with soldering, you can turn a coat hanger into an HDMI cable, and I assure you, your BLU-RAY movies will look great. In a long run situation, the cable's (metal) resistance becomes an issue, hence why higher quality (purity) metal makes a difference.
Anywho, I am sure everyone here, including myself respect your opinion, as you obviously know what you are talking about, but we as consumers, also need to look out when someone is pulling the wool over our eyes (salesmen.)
Old 04-16-2009, 02:45 AM   #50
Owtlaw333
Not entirely true. You can get sparkly artifacts (don't know how else to describe them, lol) in an image from a digital signal if the connections aren't great. It's usually caused by bad contacts, but I would assume it can also be a problem of long lengths as well.
Ever had your computer or Xbox overheat and you get weird static? That's almost exactly the same effect you get from a bad connection on a digital signal. It usually only shows in a certain color channel though (like dark areas) and not on the entire screen.
productionof1.com
|||_Buy my photos?_|||
