Old 04-15-2009, 05:08 PM   #1
325CI2004
My Ride: 09 335I
Possible to buy this part?
Replaced my flexible coupling a while back and had trouble with the alignment during reinstall. There is the alignment fin on the steering rack and mine is kinda banged up. I did the best i could with a visual alignment, but have it in my mind that its not right. Is it possible to buy this plastic part separate from a whole steering assembly and replace vs. doing a guesstimate alignment?
If it matters, for a 04 325ci.
Searched on getbmwparts and realoem and havent had any luck.
09 E90 335i Alpine White/Chestnut Brown
325CI2004 is offline   Reply With Quote
Old 04-16-2009, 10:08 AM   #2
325CI2004
My Ride: 09 335I
bump
Old 04-16-2009, 12:00 PM   #3
Polish_328Ci
My Ride: M3
Shouldn't you be getting an alignment as oppossed to trying to set it back as best you can?
Polish_328Ci is offline   Reply With Quote
Old 04-16-2009, 12:47 PM   #4
325CI2004
My Ride: 09 335I
I just got an alignment. But since this piece has a tendency to bend when removing the flexible coupler, the steering wheel might not be centered. Ive tried re-centering the piece, but if its off one spline, it will make the wheel crooked. This doesnt necessarily affect the alignment, just the orientation of the steering wheel.
But since the tab guide is slightly bent, it makes it a little harder to make sure its on straight.
If i could buy this part and replace it so its straight, i would rather do this then get re-aligned again.
