Old 04-16-2009, 08:47 AM   #1
zkc
My Ride: 2004 m3
Stranded on the Highway...
Last night my trusty 2002 330i w/136,000 miles that I've had since new stranded me for the first time. It's now at the mechanic's and I'm awating their call...
It has been starting a little hard for the past couple of weeks and while I was driving home on the interstate last night it started to hesitate and lose power. I pulled off at a truck weigh station so I wouldn't be on the shoulder and I had no warning lights etc... and it was still running but there was hardly any power. No leaks or anything else. Once I turned it off it wouldn't start again, it sounded like an old flooded car.
Any ideas of what the problem might be???
Thanks,
Zac
zkc is offline   Reply With Quote
Old 04-16-2009, 08:49 AM   #2
John_Peters
My Ride: 2001 325i
Did you run out of gas?
Jk Seriously though thats weird. Hope your mechanic can get you back on the road again soon.
John_Peters is offline   Reply With Quote
Old 04-16-2009, 09:06 AM   #3
zkc
My Ride: 2004 m3
I would feel stupid but that would definitely be the cheapest fix.
I'm pretty sure it had about 1/4 tank left and the OBC said 90 miles to empty...
Old 04-16-2009, 09:57 AM   #4
Chris-TK
My Ride: Mazda
Could be that your coils went bad.
K.
Chris-TK is offline   Reply With Quote
Old 04-16-2009, 03:11 PM   #5
K:^P
My Ride: 00 323//65 Fastback
Seriously, pour some gas into the tank. Your fuel level sensor maybe inaccurate.
K:^P is offline   Reply With Quote
Old 04-16-2009, 03:16 PM   #6
SteveX82
My Ride: 2001 325i
Sounds like an electrical charging problem to me.
SteveX82 is offline   Reply With Quote
Old 04-16-2009, 03:19 PM   #7
backroadswest
My Ride: '04 330Ci & '05 M3
Bad gas or water build-up in remaining 1/4 tank?
Do you often run the tank down below that level?
If not, chances are you might have water in there, and when it gets down that low it starts sucking the diluted fuel/water mix.
backroadswest is offline   Reply With Quote
Old 04-16-2009, 03:19 PM   #8
N89
My Ride: 330Ci
That's what I'm thinking too... those instrument gauges after time need to be readjusted for accuracy. Perfect example of my car is that after 188,000 miles the tach shows about 500RPMs too low.
N89 is offline   Reply With Quote
Old 04-16-2009, 03:20 PM   #9
backroadswest
Speaking of which, is anyone changing fuel filters, or are we considering them "lifetime" as well?
Old 04-16-2009, 03:23 PM   #10
semich4rmedlyfe
My Ride: 02.330Ci.ACS.DINAN
Absolutely change them. They are not life-time. I helped a friend change one and it came out black...
semich4rmedlyfe is offline   Reply With Quote
Old 04-16-2009, 03:27 PM   #11
backroadswest
At what mileage?
Old 04-16-2009, 03:32 PM   #12
tiloulou330i
My Ride: 02 330i zsp
Send a message via AIM to tiloulou330i Send a message via MSN to tiloulou330i Send a message via Yahoo to tiloulou330i
Your alternator is gone buddy....
Filbert
Originally Posted by nawmean?
I know I sound naive, but some of the advice I've taken from this board has helped my life quite a bit
tiloulou330i is offline   Reply With Quote
