Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#1 |
Attn: Those with oil temp gauge...
and have chosen to install it this particular way...
where did you guys get the sender that threads into the drain plug hole? what size is it and how much did it run you? thanks!!!!
- Stan Peng - EUROPROJEKTZ Southeast | Co-Director ![]() |
#2 |
i got mine from leatherz.com and it came with the sender.
#3 |
the vdo gauge came with the sender?
#4 |
yeah man came with everything:
http://leatherz.com/Merchant5/mercha...=E46_GaugeKits Look at option one and two.
#5 |
PhD Mech. Eng.
The leatherZ kit taps into the back of the oil filter housing. There are pros and cons. Pro being it reads the same place where the factory oil pressure is located. Con being that the vdo kit sender is way too big and that space is way too tight. Go for an Autometer, Defi or Greddy and you will get a 1/8 npt sender. More compact sender.
The drain plug is where I mount mine. The plug is M12x1.5 and there are adapters sold by Autometer or egauges that allow a M12 to 1/8npt.
![]() Technik Engineering ASA Stage 1. Supercharged E46 M54B25. 2011 NASA TTC So Cal Champion! Track blog. Technik Engineering oil cap o-ring maintenance kit available. |
#6 | |
#7 |
"Have some candy!!"
My Ride: 2003 Technik S1 M3
yeah that how its set up on mine also.
![]() Bimmerfest Potluck here!!! "The road was miles ahead..It fell away, now I'm at thee end... Just a sky, the fall, and you..I got holes in my para~chute...... Then-you-say,' never gonna find all the answers~ answers will find you..Don't know how I'll feel tomorrow~ Don't know the truth. But we can lie,.. lie.., lie.., lie here together..lie..,lie..,lie..,lie here together..'" |
#8 |
i want this bad....so god damn expensive though...well for me it is
#9 |
its a little cheaper here
http://www.bavauto.com/fland.asp?par...DO%20KIT%20E46
#10 |
Same here
#11 | |
Are they the exact same kit that leatherz has? Bavauto VDO guages are cheaper. I wonder if the illumination is the same as leatherz. I lioke to keep everything amber - leatherz states only thier kit is amber. VDO Vision Series Gauges (Oil Pressure, Oil Temperature, and Voltmeter) OEM-matching amber illumination (only available from LeatherZ) LeatherZ Oil Distribution Block, with senders pre-installed, that replaces the factory oil pressure switch and measures temperature and pressure at the oil filter housing LeatherZ E46 Gauge Panel, which replaces the storage bin. The LeatherZ Gauge Panel is CNC cut from ABS plastic for a perfect fit and is covered in Black Spinneybeck Leather Oil-resistant wiring and connectors Detailed, step-by-step installation instructions specifically written for E46 cars with pictures and diagrams
![]() Part out - Beige/Tan Interior http://forum.e46fanatics.com/showthread.php?t=836111 Stock 330i/325i exhaust w/ Magnaflow Cats http://forum.e46fanatics.com/showthr...831&highlight= |
#12 |
My Ride: E30 325ic & E46 M3
Those are some ugly gauges! I wish EAS would make some gauges like they did for the E9x M3 series.
#13 | |
Banned User
What about a AEM gauge along with an A-pillar mount , or a holder on the dash ? It looks alot better than that ^^ |
#14 |
They are good looking for stock. No ricey Defi like gauges.
#15 |
they look like they aren't worth $300 is because they aren't worth $300...everything is over priced for our cars
