Old 03-12-2009, 11:21 PM   #21
Amir PG
My Ride: ///Mpower
Send a message via MSN to Amir PG
does any one have the software, mind says it need a key so i need the software with crack...i have the equipment
E30 ///M S52B32 Eating Disorder
E36 ///M S50B30 WIDEBODY
E46 ///M S54B32 ACS 3
E46 330 S54B32 (under construction)
Amir PG is offline   Reply With Quote
Old 03-13-2009, 02:19 AM   #22
Acarder
My Ride: 69' M3
Originally Posted by dambro24 View Post
check engine reset( which resets then click back on in a few seconds)
airbag light (which comes right back on )
asc (which goes off then right back on )
intrument cluster taillight( which goes off and right back on after few seconds)
sounds like somethings genuinely wrong with the airbags, ASC, cluster, and engine then. The codes keep coming back, it's not the tools problem.
Acarder is offline   Reply With Quote
Old 05-04-2009, 11:39 AM   #23
st2000
My Ride: 316
Hi guys just a general question about Carsoft 6.5, I reset my service interval and erased an error memory but now when i open the driver or passenger door the windows lower a slight bit and go back up once door is shut. My car is a 4 door. Also before when I locked my car the indicators used to flash and there was a little blip and now the doors just lock and nothing happens. Any ideas how I can revert back to the old way?
st2000 is offline   Reply With Quote
Old 05-04-2009, 12:28 PM   #24
ken@bimmertools
Is NOT A Mechanic
ken@bimmertools's Avatar
My Ride: F30
For those of you considering going the PC/Software route, please consider a few things:
1. Be aware of the source of the software, its warranty, legality, and its compatibility with your car(s). If anything is questionable, avoid it.
2. Don't spend money for features you do not need. Most BMW owners are more than armed with diagnostic information that they get from their non-OBDII, BMW Specific Peake Research scan tools. There are people who will use the advanced features on a PC System frequently, and for them, those products are the way to go. However, if you just need to read codes in order to repair a problem that is within your capability, a simple plug-and-play reader is your best option.
3. Software systems can offer bi-directional communication that may allow you to tamper with portions of the vehicle's electronics that you might not want to. Be careful.
Those products certainly have their place. But, before you buy, ask yourself if a Peake tool might be everything you need. Have a look at the article in my signature titled "Is your check engine light on?"
Ken@bimmertools.com if you have any questions about the tools.
Ken
Bimmertools is under new ownership! Please welcome Taylor@bimmertools.com.
Click Here to say hi.
ken@bimmertools is online now   Reply With Quote
