Old 05-05-2009, 04:51 PM   #1
john_p
My Ride: '06 Z4M, '00 328i
Steering column - upper part rattles
E46 328i with 120k
There's a rattle coming from the upper part of the steering column, especially over bumps. I can also feel a lot of the bumps on the road. No clunking under braking and the control arms were recently replaced so I don't think it's those.
The top part of the steering column (where it goes into the car) has a small amount of play. If I wiggle the upper part it replicates the noise that I get over bumps. Probably 2mm or about 1/10" .. Is this amount of play normal? There is less play at the bottom of the column (near the rack) than this.
Is it the universal joint mid-column or is it possible that parts 1, 9 or 10 on the diagram below are loose or worn ?
http://www.realoem.com/bmw/showparts...50&hg=32&fg=30
If not how do I test for tie rod ends / steering rack problem?
john_p is offline   Reply With Quote
Old 05-05-2009, 04:59 PM   #2
n2Bimmer
My Ride: Loves Corners
http://www.realoem.com/bmw/showparts...42&hg=32&fg=30
Replace #2.
Old 05-05-2009, 05:01 PM   #3
alibusoul
My Ride: 04 330Ci
Yea i replaced number 2 and it felt like it just brought everything together and stiffened the whole car up. It's only like 50 bux... very worth it.. and it took me like 30 min to replace it. 2 screws and your done
alibusoul is offline   Reply With Quote
Old 05-05-2009, 05:06 PM   #4
GDA
My Ride: M5, 325i and 330i
I replaced the steering coupler (part 2) and afterwords still had a knock upon coming to a stop in the steering column. I had to replace the upper u-joint and all is very tight now (part 5). My car is at 141k just for reference.
GDA is offline   Reply With Quote
Old 05-05-2009, 05:38 PM   #5
n2Bimmer
#5?, which one?, they are all labeled #5, is it the other rubber coupling?. How much are they.
Old 05-05-2009, 05:53 PM   #6
GDA
Its the one in the upper right hand area of your picture. The part with the U-joint and foot long 3 piece extendable section that extends down to the flex steering coupler. Its not cheap either.
Old 05-05-2009, 06:16 PM   #7
n2Bimmer
So you mean number 1.http://www.realoem.com/bmw/showparts...42&hg=32&fg=30
Old 05-05-2009, 06:49 PM   #8
john_p
I don't have part 2 (or 1), but I guess part 4 (and 3) are equivalent parts on RHD cars.
You can see the lower part in the left hand pic (this is taken under the car looking up) and the right hand pic has the bulkhead on the left and the steering column going down. You can see the bottom of part #4 and the top of part #3. I think the lower part looks pretty old, but that could just be the 120k of road dirt and UK winters it's had to cope with..
Interesting that the entry to the rack is on the right hand side of the car.. you'd think it'd be on the left..
ID:	313836   Click image for larger version
Old 05-05-2009, 07:11 PM   #9
GDA
Oops. Yes #1 was the final solution.
Old 05-05-2009, 07:22 PM   #10
n2Bimmer
I see, so now you have to find out if Number 3 is bad or number 1.
Old 05-05-2009, 07:23 PM   #11
n2Bimmer
Thank you, I have a slight knock when i drive fast over bumps and cracks on the freeway. Might look into it later on. Nothing bad yet
Old 05-07-2009, 03:32 PM   #12
ndk2
My Ride: 1999 318
have the same problem have replaced lower joints mine seems to be in adjuster mechanism
ndk2 is offline   Reply With Quote
Old 05-07-2009, 04:22 PM   #13
john_p
Should the adjustable part of the steering column (connected directly to the steering wheel) be locked securely to the next lower part ? Or is it just pushed in? It seems that there is play right up to where the 'crash disc' is, and is where the rattling noise on my car is.
Or is this just because the adjustable couplers are worn that they permit the column to move about a bit too much?
Old 05-17-2009, 01:28 PM   #14
enm780
My Ride: 320ci
E46 320ci with 60k
I also have some movement in part called "steering shaft" which replicates exactly the noise I hear when inside the car. I replaced the coupling part, control arms and bushes... Any advice guys? Thanks.
enm780 is offline   Reply With Quote
Old 05-19-2009, 09:03 PM   #15
sling
My Ride: 2004 330cic
Hey, I also have this problem. I have replaced all the suspension parts and the flexible coupling. The movement is definitely above that to the next joint. Has anyone been able to replace it themself; any advice?
sling is offline   Reply With Quote
Old 07-19-2012, 11:56 AM   #16
NISH
My Ride: BMW 318i E46
I also have that problem with my bmw E46 318i 2000 model wen u go over humps it rattles its annoyn.checked everyting all is well.gna remove steering covers this weekend and check if all is tightened at the bottom coupling and were the steering adjusts.will keep u guys informed if I do come right.
NISH is offline   Reply With Quote
Old 07-22-2012, 12:55 PM   #17
Chaos1187
My Ride: 01' 325i M54 BMW
Keep this one updated for sure, same problem here as well. It just came out of nowhere. Started hearing and feeling a knock at the steering wheel. Over bumps in the road that I hit just right. Very annoying and ugly feeling in wheel. Def not something a BMW should have to experience. Let me know if you find anything out guys. I am currently fixing another issue but feel that this has to do with one of the two joints...no way everything can be good and your hearing a noise from the locations where the joints are.
Chaos1187 is offline   Reply With Quote
Old 07-22-2012, 01:07 PM   #18
NISH
Hi guys I'm back,yesterday I pulled the underneath steering covers @ tightened everyting jus to make sure its all secured.road tested problem still persists annoyn steering rattle from upper column.joints are secure and no free play at all.even tried greasing them joints,still no joy.I read in a thread it can be a upper column steering bearing,can anyone shed some light on this and hw do I go about ripping thing apart,cause I'm a little afraid wen it comes to the airbag removal.thanks
Old 07-22-2012, 01:50 PM   #19
B33MER
My Ride: 330i SMG M-Sport
Never mind ...
330i SMG M-Sport Paket II Euro Spec
Mods:
CF Roundels all around, Black grillz, 7000k Angel eyes,6300k HID fog lights, Hamman Lip reps, ACS roof spoiler reps, Alutech front and rear struts, BMC CDA with DIY heatshield, Pro RS braided brake line, ///M Billet Oil Cap, OEM ///M mats, ///M aluminium pedals,
Last edited by B33MER; 07-23-2012 at 09:09 AM. Reason: Just realise 1&2 is for LHD only ... silly me
B33MER is offline   Reply With Quote
Old 07-22-2012, 02:43 PM   #20
NISH
Hi guys I'm new to the forum,so I must change illustration number one which is the steering shaft and ill no 2 which is the steering knuckle or joint,that should sort my problem out,for the rattling in steering column.thanks for all the help guys
