Thread Tools Search this Thread Rating: Thread Rating: 168 votes, 5.00 average. Display Modes
Old 04-19-2009, 02:40 AM   #201
boxtyp3
My Ride: Hellrot
Thumbs Up
Great DIY! Nice diagram too!
boxtyp3 is offline   Reply With Quote
Old 04-19-2009, 11:46 AM   #202
Frampey
My Ride: BMW 318ci
Hi, i have made myself cable and installed it, but as yet have not managed to get it to work, can anyone help? i have the mp3 player playing but cannot find it when i cycle through the modes.
i am using a business cd hu manufactured 10/2002 which obviously has the aux on the back.
the software version is sv-40-02-510
i have the bmw cd changer currently installed
i made the cable from a 3 phono to headphone jack. i cut off the phono connectors and used the red and white as audio, and yellow as ground. Is this why i am not having any joy, i thought this cable would be fine?!? Help please
Frampey is offline   Reply With Quote
Old 04-27-2009, 06:31 PM   #203
BeepBeepE46
My Ride: 2005 BMW 325i MT
Hi,
I got aux input installed in my car but apparently I can't use the cigarette adapter while using aux mode. Any suggestions?
Edit: 12 amp noise filter... gotcha
BeepBeepE46 is offline   Reply With Quote
Old 04-30-2009, 09:58 PM   #204
merbimer
My Ride: bmw 325ci conv
Thumbs Up
Very ingenius!!
The information is great and the pics also. Thank you for the posting!
I'll be doing this installation soon on my '02 325ci
Vert
merbimer is offline   Reply With Quote
Old 04-30-2009, 10:00 PM   #205
spatimouth01
My Ride: 2003 325I
so I'm probably going to buy the OEM BMW cable. Does anyone know if it has the resistors/caps built into the cable?
spatimouth01 is offline   Reply With Quote
Old 05-01-2009, 06:17 AM   #206
tony325ci_51
My Ride: BMW 335i 2007 Coupe
According to the diagram it seems to have the components built in.
I've just ordered the parts, including the fly-lead to mp3 player for about 15 to make my own, not sure where the best position is to place the socket yet though.
I'm guessing the components aren't essential to use the input, the caps probably just provide some level of protection to the input and the resistor simulates a device being there so your "aux" menu option will show.
tony325ci_51 is offline   Reply With Quote
Old 05-08-2009, 11:11 AM   #207
spatimouth01
My Ride: 2003 325I
Purchased the cable from BMW and the Aux input appears without having anything plugged into the input. Works great!
Old 05-08-2009, 02:24 PM   #208
tony325ci_51
That's what the resistor in the cable does, fools the HU into thinking something is connected so the AUX display appears.
Old 05-08-2009, 02:28 PM   #209
tony325ci_51
Originally Posted by tom @ eas View Post
Here's how:
1. Turn Radio Off.
2. Turn Radio On.
3. Press and hold the "m" button for about 10 seconds.
4. Press < or > to navigate, you will need to go to the 2nd screen to look for the SW Verison which is in a SV xx-xx xx format.
5. To be Sirius/AUX or XM compatible, the radio must be SW 43 or higher.
6. Turn radio off to exit.
The MODE button is not a good enough of an indicator to check if a radio is AUX or Sirius compatible. It needs to be manufactured 09/02 or later.
How do you find out SW version on business CD. Holding down my M button does nothing, apart from put it into Manual mode.
Old 05-11-2009, 04:48 PM   #210
Assi
My Ride: 318i 2002
Here's how:
1. Turn Radio Off.
2. Turn Radio On.
I have Professional HU in a 2002 model of 318i. And yes, I have the MODE button. SV 03-02 66 - is it AUX compatible?
Assi is offline   Reply With Quote
Old 05-12-2009, 04:04 AM   #211
///Pulo
My Ride: 330CI///M individual
arghhhhhhhh business CD version 40!!!!!!! spewinggg!!!!
would have made an awesom project aswellll....
... so whats my options now
6s MT E46 BMW 330CIC Convertible M-Sport Individual Phoenix Yellow
///Pulo is offline   Reply With Quote
Old 05-13-2009, 11:41 PM   #212
kenny89_e46
My Ride: 01 black e46 sedan
ok if i read ALL of this right. for a 01 325i sedan i would have to get a newer HU if it doesnt not have a AUX button or i would have to get an interface to convert the Cd changer(which i dont have either) to an AUX port?
an the new HU has to be 09/02? and then i could make my own AUX cable for an i pod that could fit in the new rear HU?
One more qquestion...i have a chevy and i did something similar but as soon as i unplugged the radio(stock) security thrft system locked me out completly and had to contact GM to activate it again. will it do it on a bmw stock HU?(stupid question)
kenny89_e46 is offline   Reply With Quote
Old 05-14-2009, 07:43 AM   #213
Skiracer41
My Ride: wastes my money
Aweaome DIY but im stuck with the non mode HU
Skiracer41 is offline   Reply With Quote
Old 05-14-2009, 10:17 PM   #214
tony325ci_51
I unplugged my 2001 325Ci HU and plugged it in again fine, no code, security, etc.
Old 05-15-2009, 12:16 AM   #215
kenny89_e46
sweet! ok!
Old 05-15-2009, 01:06 AM   #216
tony325ci_51
Originally Posted by srle View Post
http://kaiser-media.de/bmw/aux-in/
mabye i have found the answer....
Sounds good, I ordered the parts, but at the moment I can't recommend Conrad, I ordered on 30/4/09 and here we are over 2 weeks later, no parts delivered yet.
The parts list in English is included below:
Conrad UK
Thank you for your order.
Please find enclosed the details of your order:
Your order has been despatched from our warehouse.
You will usually receive your order within 5-7 days.
Invoice value GBP 13.19
Your shipment includes the following items:
Quantity Part no Description
1 x 734136 Stereo jack socket 3.5 mm
2 x 609390 Ribbon cable 10xAWG 28 (FIL.100222)
1 x 702013 Post plug connector 2 X 5 pin
2 x 453366 Capacitor 0.22 UF KDPU 5.08 mm
1 x 421030 Metal-film resistr 0.6W 1% 300K 020
1 x 731102 Right-angle stereo connector 3.5
1 x 607754 Heat-shrink tubing set 3:1
1 x 527769 Euro board 160 X 100 dot pattern
Please note items on the same order may be shipped separately.
Thank you for placing your order with conrad-uk.com
Yours sincerely,
Customer Service Team
Conrad Electronic UK
Please do not reply to this email address. If you have further questions, please visit our extensive FAQ
on http://www2.conrad-uk.com/infocenter/faq.php. If you did not find what you were looking for, please
contact our Customer Contact Centre at service@conrad-uk.com, please quote your customer number in all
communication to Conrad Electronic UK. We aim to respond within 24 hours.
Hours of operation: Monday to Friday, 8am to 4pm.
Old 05-16-2009, 04:11 PM   #217
e46black325
My Ride: 325i
having problem getting off head unit cable
nice post for the DIY AUX cable.
I opened the trim (broke one pin, ouch), and got to the head unit, but could not get the head unit harnesss connector to come of, any suggestions?
thanks
e46black325 is offline   Reply With Quote
Old 05-16-2009, 08:48 PM   #218
dr2
My Ride: Black 325i 2003
thanks
http://m3.madrussian.net/diy/ipod/diypop18.htm
just pop it off
i did mine today and it works perfectly, my first mod and im happy with it
dr2 is offline   Reply With Quote
Old 05-19-2009, 12:43 AM   #219
Blues
My Ride: '04 BMW M3
i have an iphone 2G so like very few wires fit into it. i took apart an ipod wire to see what it was like and it like a fabric type thing and idk how i would connect that. any help would be appreciated. thanks!
Blues is offline   Reply With Quote
Old 05-19-2009, 03:21 PM   #220
2001bimmer330i
My Ride: 2001 BMW 330i
I was just reading these old threads. Looks like the link is:
http://www.europeanautosource.com/pr...roducts_id=293
This is for the 2001 33i. I have a question of how this installs. Any pics on this?
Business cassette is not compatible for AUX. You will need something like our AUX kit:
eas Auxiliary Audio Input
http://www.europeanautosource.com/pr...roducts_id=630
2001bimmer330i is offline   Reply With Quote
bmw aux in, diy aux input, input cable
