Old 07-30-2009, 12:37 PM   #1
MB2000BMW323i
My Ride: 2000 323i BMW
Exclamation Replacing Radiator Expansion Tank, need help, 2000 323i
HI,
I read through the other post on the replacing of my tank expansion, but never found an answer for my biggest problem.
1st, I got the tank out ok, and have the new one, but when I put the old tank on the ground and was looking at it, I noticed a small piece fell out, or off of it, its round and the same size as a quarter, it has 3 notches on it, and its black, made out of a hard plastic type material, it broke into 4 pieces so can't be used again, but I can't seem to find where this went originally, and if I need to find a replacement, I can't find where it came from, like if it was from inside the old tank, and maybe the new one has it inside where I can't see.
Any advice on this?
2nd problem,
When I look from the top in to where the expansion tank goes, there is a spring sticking up. Does this need to be put back on in a certain way? Or do you think this broken piece has something to do with the spring. I did see someone had asked about the spring in another post, but didn't see an answer. I would appreciate any help.
My car is a 2000 323i and it has 164,000 miles, and this is the 1st thing I have had to replace due to wearing out, (big crack in side, ive done basic maintenance) Runs awesome though, and want to get it back on the road.
MB2000BMW323i is offline   Reply With Quote
Old 07-30-2009, 01:40 PM   #2
wolfman
My Ride: 2003 325i
From memory of my own replacement, you could have broken the thermostat for the Transmission Fluid cooling block (on the bottom of the rad - correct me if your car's not an Auto 'box). I did the same thing and had to go out and get a replacement. It seemed to break quite easily and that's probably what the spring is.
Some pictures would probably help, but I'm guessing that's what your problem is.
wolfman is offline   Reply With Quote
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
