Old 07-31-2009, 07:16 PM   #1
m-teknik
My Ride: '04 330i
Question exhaust butterfly
what is this valve for ? what is it's function and how does it work ? which models have this part ? thanks
Name:	330i exhaust1.JPG
m-teknik is offline   Reply With Quote
Old 07-31-2009, 07:22 PM   #2
BMWh0r3
My Ride: is f'ing loud
Send a message via AIM to BMWh0r3
search golf-tee mod
-Brandon
-formerly RednekwithaBMW
http://forum.e46fanatics.com/showthread.php?t=697426
BMWh0r3 is offline   Reply With Quote
Old 07-31-2009, 09:24 PM   #3
330i_guy
My Ride: 330i
i have it on my 330 also but not sure what it is or how does it work...
330i_guy is offline   Reply With Quote
Old 07-31-2009, 09:43 PM   #4
eneka
My Ride: 2003 325i
it's supposed to make the car quieter at lower RPMs and at idle.
My facelift 325i has it too.
The golf tee mod tell you how to remove the tub and plug it with a golf tee.
eneka is offline   Reply With Quote
Old 08-01-2009, 04:09 AM   #5
m-teknik
My Ride: '04 330i
why did I ask this valve ? because I want electrical cut-off for my 330i. Electrical cut-off valves are expensive , they require more work and I prefer always stock parts. So I want to have electrically operated loud and quite muffler , can we operate this valve with electrical switch ?
I found this figure. I think M54 330i have the same shape.
Old 08-01-2009, 04:20 AM   #6
ejamin73
My Ride: '04 325i Sport Pkg
Mine doesn't have it & it's an '04 325i
Sig thanks to Owtlaw333
I just can't imagine the word without the smell of burned gas coming out of a well tuned engine:drool:
Originally Posted by zhp pilot View Post
nice try on the sig you tard. unfortunately, when you click the link you see the actual quote.
you are on a roll with the FAIL tonight. :lmao:
ejamin73 is offline   Reply With Quote
Old 08-01-2009, 04:40 AM   #7
330i ZHP
330i ZHP's Avatar
My Ride: slow cars
hmmm, i thought only 330's had the valve
- Stuart
Old 08-01-2009, 06:10 AM   #8
mkodama
mkodama's Avatar
That's what I read as well...
MY 330i FOR SALE - $4000 WITHOUT WHEELS
Downloadable E46 Owner's Manual - BMW Oil Info - Find Any BMW Part Number - Lookup Any OBD2 Code
For Sale:
AUTOart and UT Models die-cast model cars - Goodridge Stainless Braided Brake Lines - Black Coupe Sports Seats (Used)
PM me for details for any of the above.
Old 08-01-2009, 10:38 AM   #9
m-teknik
My Ride: '04 330i
Originally Posted by BMWh0r3 View Post
search golf-tee mod
I had just understood this mod. Also I tried on my car today. But no different sound at idle. It may be %3 more , but can not noticable.
Old 08-01-2009, 12:13 PM   #10
MysticBlau330Ci
My Ride: 330Ci '04
Mine is fully open at idle. I was driving behind a 330CiC and it was open at idle too(car at a standstill). But when the driver moved off (not too fast) it started to close. I guess it would re-open at some point later.
MysticBlau330Ci is offline   Reply With Quote
Old 08-01-2009, 04:22 PM   #11
m-teknik
My Ride: '04 330i
Infact I need quite exhaust at idle speed and sport sound at higher (3000+) rpm... Is there any reasonable solution for street car ?
Old 08-01-2009, 05:17 PM   #12
Acarder
My Ride: 04 6MT 330i, 328i
US 330's have it, and 6 cylinder (ie 2 exhaust) euro's have it.
Man the M52TU muffler is stupidly designed, time to cut mine off.
Buy a Aston Martin? You'd be hard pressed to find an exhaust for the E46 that had a custom actuator set up built in to do what you want... If you got headers and used the stock muffler you'd be able to benefit from the stock butterfly valve that opens and closes while still increasing sound
- Matt
Acarder is offline   Reply With Quote
Old 08-01-2009, 09:18 PM   #13
eneka
My Ride: 2003 325i
my U.S. 2003 325i has it..
Old 08-01-2009, 10:10 PM   #14
Acarder
Are you sure someone didn't slap a 325 badge on your 330?
Seriously though, ugh I thought I had it down which cars came with them. It seems pretty inconsistant. Maybe if your VIN ends in an even number you get a clutch stop, and if it ends in a prime number you get a butterfly valve.
- Matt
Old 08-02-2009, 02:01 AM   #15
eneka
My Ride: 2003 325i
nah i bought the car new from a dealer so i'm pretty sure it's a 325...
hmm...i guess ima go poke my head around other e46 exhaust pipes to see if they have one too..
Old 08-02-2009, 06:13 PM   #16
m-teknik
My Ride: '04 330i
I edit my comment. I tried for a few days on my car and it has tougher sound. But do not hope aggresive sound , it became only deeper sound.
Old 08-02-2009, 09:41 PM   #17
josephi
My Ride: 330i
That's the opposite of mine. '02 330i. Just checked it with the engine off, and it was fully open. I started the engine and checked it again at idle, and it was fully closed. I did try the golf tee mod for a while and found that the exhaust tone at low rpms was deeper, but being an older guy, I prefer a quieter and mellower sound, so I hooked the hose back up.
josephi is offline   Reply With Quote
Old 08-02-2009, 09:44 PM   #18
uninc4709
My Ride: 2002 BMW 325i 5spd
pretty sure 325s dont have the valve
uninc4709 is offline   Reply With Quote
Old 08-02-2009, 09:46 PM   #19
josephi
My Ride: 330i
After applying the golf tee mod, are you sure the flap is fully open at idle? The reason I ask is because when I first tried it, I found that my flap remained closed because it was not rotating freely, probably due to corrosion in the hinge, which means that it was probably stuck closed even when I was doing high rpms on the road. I sprayed some WD-40 up into the hinged area and worked it opened and closed until it loosened up.
Old 08-03-2009, 01:21 AM   #20
m-teknik
My Ride: '04 330i
This may be the same reason for my first drive , I noticed the difference after my first trial....
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
