Welcome to the E46Fanatics forums. E46Fanatics is the premiere website for BMW 3 series owners around the world with interactive forums, a geographical enthusiast directory, photo galleries, and technical information for BMW enthusiasts. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
#1 |
Replace Window Regulator or Defective Window?
Ok,
This thread is not getting much play on the other bmw forum that I vist so I am posting it here. a couple of months ago, because some idiot decided to take my cds by breaking my bimmer/s window, I had a window installer replace a broken driver's window glass on my e46 with non oem. During the install we noticed that the slide on the regulator had a broken piece which we decided to jb weld, to see if it would hold. I was in no rush to add to the damage cost having to get a regulator and wait for it to arrive before installing the widow. Problem, I recently had my windows tinted and the tint guy brought to my attention the fact that the window that was replaced is possibly not a 100% fit due to imperfections on the angles.. I did did the zip tie DIY thinking now i would be able to roll window up and down, but it widow will only go up 60% of the way. What gives? window needs to be adjusted? regulator is bent and it needs to be replaced in spite of successfully doing the zip tie DIY? possible window glass not fitting 100%? see pic. The window starts to push up agains the metal part of the door....(I removed part of the trim to get a better view.) ![]() Another view ![]() THis is as far as it will go... ![]() The front passenger side window, rolls up and down nicely and stays on the track plane....
DD: 01 325I ZSP, WTB: Meyle or Powerflex 66mm FCAB's, GROM Aux In Expedition Rig: 80 Series Modified, Land Cruiser |
#2 |
My Ride: 1999 BMW 328i E46
Its because its non OEM glass.
![]() ![]() ![]() "17 year olds think, hmmm If I pull this handbrake lever all my girlfriend's clothes will fly off"-Jeremy Clarkson |
#3 |
I screwed up and can't post
Go buy glass from the dealer, and demand a free fitting from your installer if you can't do it your self.
#4 | |
That sounds $ I wonder how much an OEM glass is.
#5 |
how did you get the panel removed from the door?
#6 |
How? There are a few DIY threads on here on how to do it. search window regulator DIY.
#7 |
I've been thinking. I may as well buy a new window regulator, install it, and if I still have problems push the installer to replace the window glass with one that fits right.....better use of my time and money, I will assume a window regulator is cheaper than a new OEM glass.
#8 |
Conclusion: after taking the felt on top of the door where the window rests fully down...I looked closely at the window lay out and realized that the window was not properly put in the guide. I had to re loosen the window from the regulator, rest the window on the guide, before fastening it to the window regulator again. It has been working 75% good now, meaning it is still slow to go up past the 1/2 way point but at least I can close the window now.
