Click Here for The Tire Rack
Sponsored by The Tire Rack
Old 08-15-2009, 09:46 AM   #1
shadow 2
My Ride: 02 325xi
Question on Tire Size
My car has 205 x 50 as its OEM size. When I check Tire Rack or Discount Tire for optional sizes in 17 inch tires, they both move down to 45 sidewalls. I would like a wider tire but still would like to keep the 50 sidewall for added protection from our lousy Indiana roads. Is there a reason that you should not get 225 x 50 tires for my car?
shadow 2 is offline   Reply With Quote
Old 08-15-2009, 11:30 AM   #2
myksbmw
My Ride: BMW 2003 325i
205 x 50 is usually what comes on the factory 16" wheels, is that what you have?
myksbmw is offline   Reply With Quote
Old 08-15-2009, 01:43 PM   #3
ChrisTKHarris
My Ride: 325Ci
The reason why the profile decreases to a 45 with a 225 is because you need to decrease the aspect ratio to maintain the same overall rolling diameter so that you're speedometer will be accurate.
-Chris
ChrisTKHarris is offline   Reply With Quote
Old 08-15-2009, 01:50 PM   #4
frobie15
My Ride: has a door star
Send a message via AIM to frobie15
Like what Chris said, a wider tire with a lower aspect ratio will give the same sidewall height. It's a ratio of the width, not a set sidewall height.
Go ahead, ask me a question... Check out the CopTalk thread in the California forum
Thank you Sam
frobie15 is offline   Reply With Quote
Old 08-15-2009, 11:03 PM   #5
shadow 2
My Ride: 02 325xi
Thanks for the info. I have 17 inch wheels, but it appears from what you are telling me I will need to go with the 45 sidewalls to get a wider tire in the 17 inch size.
Old 08-16-2009, 11:43 PM   #6
BartenderPlease
My Ride: 328i Sport
Send a message via AIM to BartenderPlease
45 series is correct, 235/45/17 would be your best bet
harry
VMR VB3 | 19x9.5 et30 | 19x10 et38 | 235/35's
BartenderPlease is offline   Reply With Quote
Old 08-17-2009, 11:31 AM   #7
CRXnut
My Ride: 2004 325ci
the correct 17 inch size is actually 225/45/17 and it has exactly the same sidewall as 205/50/17
Here is a good tool for calculating sizes - http://www.miata.net/garage/tirecalc.html
CRXnut is offline   Reply With Quote
Old 08-17-2009, 12:01 PM   #8
ChrisTKHarris
My Ride: 325Ci
225/45/17
-Chris
Old 08-17-2009, 02:26 PM   #9
shadow 2
My Ride: 02 325xi
Thanks guys, that's what I will get with these wheels.
Old 08-17-2009, 05:37 PM   #10
BartenderPlease
My Ride: 328i Sport
FYI, 235/45 is a great upgrade and causes zero problems
harry
Old 08-17-2009, 07:01 PM   #11
shadow 2
My Ride: 02 325xi
What kind of upgrade? I would think weight would start to become a real issue with a tire this wide.
Old 08-17-2009, 08:20 PM   #12
BartenderPlease
My Ride: 328i Sport
Upgrade as in wider tire for a little more grip and a little better look. Weight won't become a big issue. But as they said above 225/45/17 is the correct size because it is OEM recommended, but 235's won't hurt a thing.
harry
Old 08-18-2009, 04:05 PM   #13
Gary@Tirerack
Moderator
Gary@Tirerack's Avatar
My Ride: 1995 BMW M3
Agreed, and well stated.
Refer to 'Gary/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by ordering through the sig link.
Click sig! -->
Gary@Tirerack is offline   Reply With Quote
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
