Welcome to the E46Fanatics forums. E46Fanatics is the premiere website for BMW 3 series owners around the world with interactive forums, a geographical enthusiast directory, photo galleries, and technical information for BMW enthusiasts. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
#1 |
My Ride: E46 320i + E60 530i
What on EARTH is this LEAK?!?!?!!?!? ARGHH!!!
I've circled several problem areas with a big, fat red circles.
Can anyone please identify what on earth is causing these leaks? It's starting to annoy me just knowing that the leak is there! --------------------------------------- ![]() ![]() ![]() ![]() ![]() Last edited by iftwb; 08-19-2009 at 04:27 PM. |
#2 |
I screwed up and can't post
That is the power steering pressure hose. But until you locate the source, there's no way to tell what oil is leaking.
#3 |
I'm sure you're be fine, lol
Call me by my Jersey Shore nickname: "The Tan-gent" ![]() Modded G35 with plenty of goodies ** Political signatures are not allowed - Tim330i ** |
#4 |
clean that up and keep an eye on it...looks like the pressure power steering hose has a leak...mine is also leaking
4 Sale:..6 New OEM Bosch Ignition Coils http://forum.e46fanatics.com/showthr...768&highlight= |
#5 |
I'm going to go with power steering.
Get a flashlight and check up top and follow the lines |
#6 |
Okay,
RockLee after doing some research, I've discovered that if you order a replacement O-ring for the Power Steering Reservoir (from say Pelican Parts), it should fix the problem. I remember now, I did this a while back and it fixed the problem. But only at top? Now I've got a problem down below... Last edited by iftwb; 08-19-2009 at 05:12 PM. |
#7 |
My Ride: 1999 BMW 328i E46
I want to know that too, because I have to clean the ****in reservoir all the time.
![]() ![]() ![]() "17 year olds think, hmmm If I pull this handbrake lever all my girlfriend's clothes will fly off"-Jeremy Clarkson |
#8 |
The power steering reservoir is one issue. However, I have another few questions for you guys:
1. What exactly did I circle in Picture #1 to Picture #3? 2. In Picture #1 to #3 - you can see a bolt attached to a strong, thick metal casing tube circled with the red ring. Does this attach to the power steering pressure hose circled in pictures #4 to #6? 3. If the bolt/nut is where the leak is coming from, would replacing the bolt/nut with a new washer (if one exists behind it) fix the problem? 4. If it all comes to worse...should I replace the unit circled in red in Picture #1? If so, what parts am I looking at? Last edited by iftwb; 08-19-2009 at 05:11 PM. |
#9 |
The reservoir is leaking because there is a hole in the cap designed to allow a leak. If you don't allow it to leak, it will blow up. Is that what you want ?
#10 |
PS lines, you can replace them if the leak is bad.
2004 Ci Dinan S 325 M56. TOW HOOK/WINTER USE;) PAID OFF!!!! Carbon fiber fun for everyone. SUPPORT THE TROOPS, FREEDOM IS NOT FREE.
#11 | |
Of course not, now do we? But before I replaced the O-ring, it stopped all the leaks? No explosions? Blow ups? ![]() Part numbers? |
