Welcome to the E46Fanatics forums. E46Fanatics is the premiere website for BMW 3 series owners around the world with interactive forums, a geographical enthusiast directory, photo galleries, and technical information for BMW enthusiasts. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
///M3 Forum
The BMW E46 ///M3 is the M version E46 and puts out an amazing 333 HP and 262 lb-ft of torque at stock specs! There are an amazing amount of modifications for both the coupe and convertible models so read up and get started modifying your cars today! |
#1 |
Arghh help !! Yellow engine light on my smg m3
Last time I had the yellow light on ( not so long ago ) it was coilpack 4 that had ceased . but this time it looks like a different matter
The car is running in limp mode ( feels as rough as anything ) Have read with carsoft and got the following errors : .................................................. ............................................. DME/DDE - Status : ERROR - 132 HFM reference tension .................................................. ............................................ EGS - Status : ERROR - 97 Term. 30 supply for EGS SG .................................................. ............................................ EWS - Status : ERROR - 01 Key 1 not recognised Key recognising procedure during the start process : - The transponder in the key is supplied true the ring antenna. En sends the key data to the EWS control unit. - The EWS control unit controls the data, and then sends the permission signal to the engine control unit (DME/DDE) en de starter - After starting the EWS control unit calculates new data (changing code) and then sends it to the transponder into the key. .................................................. ............................................. LKM/LCM - Status : ERROR: - 40 Thermical Oil Level Sensor .................................................. ............................................. I have cleared the faults but the DME still reports an error and it still sounds like a tank and the yellow light is off , but I havent driven it anywhere . Can anyone shed some light on to what the fault maybe |
#2 |
Try cleaning your HFM. Mine did the same when I got it, replaced all the coils and fixed it for a couple of weeks and it came back. It was the thottle actuator that was getting stock.
