Old 09-08-2009, 01:50 PM   #1
Mercutos
My Ride: 99 323i
When are front rotors & pads too thin
I needed new rear brakes bad, pads & rotors.
I got new front pads, just pads, 50k mile ago, so I figured I would just change the front pads & rotors in the front too. Well, they look good, the pad & rotors. The rotors seem to have lots of material left in them. The Pads aren't even worn down past the bevel in the pad material. The car stops great w/ no vibration.
I'm thinking I will just leave the fornts on there for a while. Now that I know how to change those parts I realize it is not big deal to lift up the front & change the brakes, as long as you have a sledge hammer for the rotors.
Not sure how long it will be till I need new pads/rotors up front, trying to figure out whether I should just return the front pads & rotors.
What are the thickness specifications at which pads and rotors are recommended replaced?
Mercutos is offline   Reply With Quote
Old 09-08-2009, 01:54 PM   #2
rhm325i
My Ride: 02 BMW 325i
factory rotors come 23mm thick and min. thickness is 21mm
and bmw recommends replacement of rotors every time you replace pads
rhm325i is offline   Reply With Quote
Old 09-09-2009, 10:22 AM   #3
mbreeden
My Ride: 325Ci 2001 (E46)
Rotors for front and rear have different thickness. Front minimum thickness is thicker than rear (20.4 vs 18.4). Also replacing rotors each time you replace pads is the wrong way around (even though the stealerships may think differently): changing pads when you change rotors is more efficient ;-) BMW does recommend that, because BMW pads seem to be more abrasive and therefore put a more heavy burden on the rotors. If you take the time and effort to measure the rotors now and then: feel free to replace just pads. If not and you want to be better safe than sorry: spend the extra bucks.
mbreeden is offline   Reply With Quote
Old 09-09-2009, 10:44 AM   #4
Mercutos
My Ride: 99 323i
Well, I have a lip on each side of the rotor that is at least 1mm, so I'll keep the set of pads & rotors I have and replace them relatively soon. I'll keep and eye on them every 5k mi when I rotate my tyres.
Old 09-09-2009, 11:44 AM   #5
hummer
My Ride: 2001 330CI
If the car stops Ok, why would you throw away good pads. If the bevels are still visible they are less than half gone! Use them up! Use them until the pad material is at least the same thickness as the backing plate. The warning lite doesn't go on until they are very thin!
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
