Old 10-07-2009, 04:31 PM   #1
Mynewbimmer
My Ride: 325CI-2004-5SPD
Is it bad to cruise around in neutral?
I have an 04 325ci 5pd...I was wondering if any of you in the course of your daily commutes put the car in neutral and just roll down a hill or something? Is this bad to do over a the course of a long hill?
Let me explain for example a part of my daily commute is getting out of a valley, so I drive uphill for like 2 miles and then once i get to the top, I just put it in neutral and let gravity do the rest. (for those of you in SoCal Im talking about the Sepulveda Pass going south on the 405 from the 101) Now this stretch of downhill is about 4 or 5 miles for me and i notice that my temp guage drops from dead center to the white line on the left. This is never an issue if I do it on surface streets like as Im coming to a light because it never lasts long enough.
Is it bad to be doing this? Should I just leave it in gear while im rolling downhill?
Mynewbimmer is offline   Reply With Quote
Old 10-07-2009, 04:35 PM   #2
EDawg
My Ride: :/
sounds like a you need a new thermostat. the temp guage should remain in the middle regardless of how long you roll down the hill in neutral (assuming your motor is not turned off). also rolling down a long hill in neutral will use more gas and wear out your brakes more.
EDawg is offline   Reply With Quote
Old 10-07-2009, 04:37 PM   #3
justin0o
My Ride: '01 330i
i read something here a long time ago about it being bad over long period of time, but I don't remember. :/
PM me for lockerz invites :D
justin0o is offline   Reply With Quote
Old 10-07-2009, 04:44 PM   #4
tehsex
My Ride: 330i zsp...
well it really depends, do you have a manual or an automatic? You don't necessarily need a new thermostat, simply your engine is not under any load and not revving up to switch gears and it's creating less friction and making less explosions than if youd be driving it on a normal road. What your forgetting is that your car is still getting air rammed through the radiator cooling the coolant running through the engine, it's perfectly normal, if you don't trust me ask any other mechanic/ tech.
tehsex is offline   Reply With Quote
Old 10-07-2009, 04:45 PM   #5
Megalocnus
My Ride: 09/98 323i ZSP/MT
Rolling down the hill is possible and saves a bit of gas, but is generally not recommended for safety reasons- takes longer to stop the car in case of emergency. I like the Sepulveda pass, drive there a few times a week, but always in gear.
I do roll to red traffic lights though, especially to those I know well.
Megalocnus is offline   Reply With Quote
Old 10-07-2009, 04:47 PM   #6
jeffb325
My Ride: 325ci
I think a person would have a hard time making a case that it could do anything harmful.
You might try checking your mileage in neutral and in 5th gear by reseting your trip computer at the top of the grade. I would bet that you get better mileage by leaving it in 5th and coasting.
jeffb325 is offline   Reply With Quote
Old 10-07-2009, 04:48 PM   #7
neil1138
Cinnanomnomnom
neil1138's Avatar
It's called hypermiling. And it's not going to hurt anything
neil1138 is offline   Reply With Quote
Old 10-07-2009, 04:53 PM   #8
snowcatxx87
My Ride: 04 330CI / 00 323I
Man where do you come up with this sh1t? Too funny. My whole office laughed. Thanks.
snowcatxx87
snowcatxx87 is online now   Reply With Quote
Old 10-07-2009, 04:56 PM   #9
Mynewbimmer
I have a manual tranny my previous car was an auto and so I never noticed this before. As far as what tehsex said, thats what I was thinking that because the car is pretty much just idling while traveling at about 50 mph the cooling system is cooling faster than the engine is producing heat.
Im not concerned with safety too much as I keep safe distance and I dont imagine the car would ever just turn off. As fas as fuel economy goes...well my commute is about 20 miles with about 4 miles being "free" so over the course of a long time, I would imagine this would save at least 10-20% of fuel in my daily commutes. Now i dont know how much fuel is consumed when u simmply leave it in gear and just roll but could doing that over the course of 4 or 5 miles be bad for any engine components or tranny/clutch to be working because of kinetic energy of the car instead of gasoline?
It seems like a case could be made for both :/
Old 10-07-2009, 04:58 PM   #10
ilee21
My Ride: 2004 M3
well i dont think that rolling in neutral will save much gas... maybe even waste more because when you roll in gear, the cars speed is bringing up the rpm's, but when you put it in neutral the engine has to use gas to keep it at idle. Maybe im wrong. Just what i think.
ilee21 is offline   Reply With Quote
Old 10-07-2009, 05:00 PM   #11
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: White Lightning
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
bad thermostat
Schlüsselkraft
"Christian Fundamentalism: The doctrine that there is an absolutely powerful, infinitely knowledgeable, universe spanning entity that is deeply and personally concerned about my sex life."
VALMONT is offline   Reply With Quote
Old 10-07-2009, 05:08 PM   #12
R1killa
My Ride: E46
A modern gasoline car should always maintain operating temperature during normal use (idle, coast, city, highway) especially the electronic thermostat equipped BMWs. Furthermore this is California so it should definitely stay in the middle. I can idle my car in -13F or more(-25C) here in Canada and it will stay right in the middle as it should. This is crucial for proper lubrication, fuel economy and combustion. Definitely sounds like a bad thermostat.
R1killa is offline   Reply With Quote
Old 10-07-2009, 05:11 PM   #13
Mynewbimmer
If my thermostat is bad, wouldnt it cause overheating (even minor) while going up hills or in traffic? If its ever not in the middle, its to the left. Iv never ever seen it move right from dead center even in traffic, a/c in the LA heat (this summer was HOTTT!!!) I have CPO so maybe I should get it checked out?
Old 10-07-2009, 05:12 PM   #14
Define ///M3
Define ///M3's Avatar
My Ride: Dreams of an AA kit.
i was just wondering this, i also just got my first manual and its little things like this im still scratching my head too
AKA Huggy1989
"I expect to pass through life but once. If, therefore, there can be any kindness I can show, or any good thing I can do to any fellow being, let me do it now, and not defer or neglect it, as I shall not pass this way again."- WP
Define ///M3 is offline   Reply With Quote
Old 10-07-2009, 05:13 PM   #15
JJR4884
My Ride: Facelift Coupe 3.0
Send a message via AIM to JJR4884
it you were in 30 degree weather coasting for that long, i would say no way to the thermostat problem, however being in LA or wherever it is, i'm sure its between 70-80 degrees out there. With those temps, i find it hard to believe your temp gauge moves, however i could be wrong...
as far as saving gas... coasting in a high gear compared to your engine keeping the car in nuetral is such a minute difference i highly doubt that you would see any difference at all
Russo
A warm welcome to you 2010 members
(this is what we have to look forward to....)
Originally Posted by Kolano View Post
should i put the sticker on before i do tints or after i do the tints? also i have a paking sticker and it will expire in a year so i think i will put it on after the tints? anyone has any suggestions ?? thx
JJR4884 is online now   Reply With Quote
Old 10-07-2009, 05:15 PM   #16
JJR4884
if your thermostat is stuck open, your engine will drop in temperature at higher speeds because the air is cooling it down so much faster. My therm was stuck open and my car heated up fine, however as soon as it got some cold winter air in there at 50-60mph, my engine temp dropped
if your thermostat is stuck closed, then it will overheat unless you are going fast enough for the air to cool your engine down
Russo
Old 10-07-2009, 05:15 PM   #17
Swedishbrick
My Ride: '00 BMW 323CI
Depends on where it is sticking.
Stuck open = constant flow of collant from the radiator = running colder
Stuck closed = no flow = overheat
My dad's explorer has a stuck open thermostat and he chooses to ignore it... Poor motor hasn't gotten up to opperating temperature in over 3 years...
Swedishbrick is offline   Reply With Quote
Old 10-07-2009, 05:17 PM   #18
Megalocnus
If I'm getting it right, going in neutral downhill on Sepulveda pass during commute hours will only make you use brakes a lot more frequently and harder. If any gas can be saved this way, it will not be much and certainly won't even compensate the increased spending on brake pads and rotors. If you want to increase your gas mileage, try to shift in higher gear to avoid high engine revs and drive in a way that will minimize braking... cheaper, but not fun. :-)
Keep your tires properly inflated. High performance tires that provide a lot of traction (wide and soft) are going to decrease the mileage too.
Old 10-07-2009, 05:18 PM   #19
JJR4884
best to just keep it in gear and keep control of your car
like others said, if you have to brake hard for whatever reason, the friction from being in gear will make you slow down faster... that alone is a good enough reason to keep it in gear
the only time i used the clutch or neutral is if i come to a stop... i'll down shift usually to 3rd gear (sometimes 2nd) and when i come to 10mph i'll either just keep the clutch in, or throw it in neutral
Russo
Old 10-07-2009, 05:19 PM   #20
justin0o
My Ride: '01 330i
:p
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
