Welcome to the E46Fanatics forums. E46Fanatics is the premiere website for BMW 3 series owners around the world with interactive forums, a geographical enthusiast directory, photo galleries, and technical information for BMW enthusiasts. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
#1 |
water pump just went out..lowest cost option?
my water pump just went bad and broke the fan clutch. i'm on a budget now so can't take it to the dealership. where do you guys get parts to fix your bimmer? i'm looking for some local mechanic on craigslist hopefully it would be cheaper. thanks
#2 |
The Canadian legend
Search/ sponsers on this website, They will help you Out, do all the work by yourself. only go to the stealership as a last resort
#3 |
Jesus Built My Hotrod
I have a used OEM water pump that I will GIVE you if you are anywhere near hampton roads.
#4 |
do it yourself, taking the front end of these cars apart is actually fairly easy, and I've taken the fan clutch off before without removing the front end, just the shroud around it and a few alan bolts. I don't remember on the water pump though. there's a write up around here on changing the entire cooling system that would give you an idea.
#5 | |
#6 |
where do you guys get the parts? which sponsor is best? i'm not the mechanic type plus got no tools but I was able to find two guys since i posted one wanted $100 to come and replace the pump and another $200. the shop wanted $500+ for labor totaling around $1300 for the job. thanks for the help guys, i'm gonna order the parts tonight. should I stick to bmw parts or after market?
#7 |
I'll help you for free. It takes like 30 minutes, lol.
Pelican parts has a pump for like $50.
#8 |
hi, thank you for the offer but too bad i'm in northern va though. do you know how many miles you have on that water pump? they only last for about 90k miles right? i think i'm stuck with this car for a while so I don't wanna go through this again. thanks again.
#9 |
About 60k.
#10 | |
#11 |
Get one with a metal impeller. The OEM ones are crap made with plastic. I would not suggest installing a used waterpump with plastic impeller, unless you want to repeat this a year from now...
#12 |
I did this thing last weekend not that bad took me like 4 hours with no rush and with beer drinking breaks...I got one made by hamburg technic (german OEM) on eBay for $50 bucks and it has a metal impeller!
-Get the special tools 32mm slim wrench and the pulley holder (I have them and can sell them them to you PM me if interested) they make it definitively more easy -Make sure to turn the pulley 32mm bolt clockwise to untighten and counter clockwise to tighten. -take your time when bleeding the cooling system and do not remove completely the drain blue bolt under the radiator to avoid air getting in the system. Good luck!! |
#13 |
If you don't know what you are doing, don't do it unless you want to risk overhheating and destroying your engine. And do not take a water pump with 60K miles on it and put it in your car. It will likely go in less than a year or maybe the day you put it in which means you get to do this job twice.
#14 |
Sienna Red Coupe
My Ride: has moderate rake.
Order all of your replacement parts from www.getbmwparts.com. They are Tischer BMW located in Maryland. Depending on where in Virginia you live, you will get your parts a day after they ship. I'm in Fairfax and usually get my parts a day after I order them. If you're local to Northern Virginia, I wouldn't mind lending a helping hand, and tools, to a beginning DIYer.
-Gary
#15 |
Also will need jack screws to pull it out (M6 screws about 3 to 4 inches in length, try Auto Zone or Advance Auto parts for the M6 Screws).
#16 | |
2004 Ci Dinan S 325 M56. TOW HOOK/WINTER USE;) PAID OFF!!!! Carbon fiber fun for everyone. SUPPORT THE TROOPS, FREEDOM IS NOT FREE.
#17 | |
#18 | |
What goes wrong on the non- OEM pump is the bearing.The weight of the metal impeller causes the bearing to go bad in a short time. My car has 108k miles with original cooling system.Even tough i have a every single part to do an overhaul i still won't do it this year.
Filbert Originally Posted by nawmean? I know I sound naive, but some of the advice I've taken from this board has helped my life quite a bit Last edited by tiloulou330i; 10-13-2009 at 08:21 PM. |
#19 |
I'd be interested in hearing your justification here (not sarcastic) - the majority of water pump-related posts here point to the plastic impeller. I'm going to do mine early next year as a preventative measure, and had planned on going the metal impeller route.
#20 |
You can always install whatever you want on your car but don't be surprised if the metal impeller pump doesn't last 20k/mi.
When someone in here can claim to have over 60k/mi on those aftermarket pumps i'll use them myself. I have 108k/mi on my original oem pump,why should i put an unproven aftermarket one?
Filbert Originally Posted by nawmean? I know I sound naive, but some of the advice I've taken from this board has helped my life quite a bit |
