General Off-Topic
Old 10-22-2009, 03:50 PM   #1
snikwad
My Ride: looks peppered.
Advantages of Diesel fuel
Pretty cool find i think, thought id share.... Taken from DieselPower magazine
Judging by the title of this magazine, it should come as no surprise we here at Diesel Power are a little biased toward diesels. Why?
First of all, there's the emotional element-we were all raised by a pack of wild oil-burners. For a more down to earth explanation, facts, physics, and reason all point to diesel power over gasoline power as the transportation and energy solution. Here are some tidbits of wisdom you can share with the compression ignition non-believers. There are many more reasons, but due to the economy and worldwide ink shortages, we limited ourselves to 50.
1. Only a diesel vehicle can tow, be a work truck, drag race, sled pull, off-road race, and still be a reliable daily driver.
2. Diesel fuel is 15 percent more energy dense than gasoline.
3. A diesel releases less carbon dioxide into the air because it is more fuel efficient.
4. Diesel fuel does not evaporate as easily as gasoline, so it is much safer in accidents.
5. The Army uses diesel fuel.
6. The Navy uses diesel fuel.
7. The Marines use diesel fuel.
8. The trucking industry uses diesel fuel.
9. The aviation industry uses diesel fuel.
10. The mining industry uses diesel fuel.
11. The railroad industry uses diesel fuel.
12. The maritime shipping industry uses diesel fuel.
13. The U.S. Coast Guard uses diesel fuel.
14. The construction industry uses diesel fuel.
15. Diesel engines are like garbage disposals-they'll eat any type of oil-based fuel.
16. It's easier to recycle a diesel engine compared with a gasoline-electric hybrid.
17. After a few decades, someone will pay you for your junk diesel engine.
18. Due to their complicated construction, people will have to pay to recycle their gasoline-electric hybrid.
19. Diesel vehicles do not need complicated evaporation emission control systems.
20. All types of plastics can be made from biodiesel and vice versa.
21. Biodiesel could help off-roaders and racers who are dealing with emission and noise laws.
22. A diesel only compresses air in its cylinders, so fuel does not contaminate the oil like in a gasoline engine.
23. A diesel only compresses air, so carbon monoxide and unburned hydrocarbons do not form in the crevices of the cylinder wall like in a gasoline engine.
24. A gasoline engine needs large amounts of fuel to get it started in cold weather (think about using the choke). If you do a lot of stop-and-go driving, your car will never get its estimated fuel economy.
25. A diesel produces maximum torque at low engine speed. This makes it perfect for getting heavy loads moving.
26. A diesel is more reliable because it does not have to deal with a spark ignition system.
27. An article written by the Health Effects Institute suggests older diesel engines produce safer emissions. Although older engines produce more emissions by mass, their particles are larger and less dangerous.
28. You'll never have to worry about pre-ignition in a compression ignition engine.
29. Biodiesel has 34% more energy densitythan ethanol.
30. The largest and most powerful internal combustion engine in the world is a diesel (Wartsilla-Sulzer RTAA96-C).
31. If you're a fish, it's better to have 100,000 gallons of biodiesel spill into your river than 1 ounce of gasoline.
32. A diesel vehicle holds its value better than a gasoline one.
33. A mechanically injected diesel does not need electricity to keep it going. If your alternator fails, a diesel engine will get you home.
34. It is easier to turbocharge a diesel engine.
35. It is easier to supercharge a diesel engine.
36. Gasoline engines produce deadly concentrations of carbon monoxide. By contrast, diesels produce little carbon monoxide.
37. Diesel fuel is a lubricant. Gasoline is a solvent. What would you rather spray on your cylinder walls?
38. India's Tata Energy Research Institute said clean diesel beats compressed natural gas (CNG) on cost and delivers the same amount of "toxic" pollutants.
39. Compressed natural gas has 75% less energy density than diesel fuel.
40. The best batteries are 85% less energy dense than diesel fuel.
41. The diesel BMW 520D luxury car beat the Toyota Prius economy car in fuel economy tests.
42. Diesel dominated at the 24 Hours of Le Mans.
43. If you're driving up a steep hill or carrying a heavy load, a diesel engine is less likely to stall.
44. Since diesels are built to withstand high compression, they are built with stronger pieces, which makes them last longer.
45. Rudolf Diesel built his engine to improve mankind.
46. With no ignition system, the mechanical diesel engine will not interfere with radios, communication devices, or pacemakers.
47. Diesels are better in remote areas and third world countries because they can run on vegetable oil and are less complicated than other drivetrains.
48. Since a diesel is more efficient, it generates less noise and waste heat.
49. Diesel fuel and exhaust just smells better.
50. Diesel engines require less fuel to drive a given distance or do a certain amount of work. Less fuel burned is less fuel refined, less fuel transported, less fuel stored, and less fuel spilled. And using less fuel in all of these categories is an advantage for the engine, vehicle, driver, economy, environment, and Diesel Power readers just like you!
Why diesel engines rock
Do you ride a sportbike?
Need Just 1 taillight?
Need LED lights?.
For all your parts contact Ruben at Desert Motor Werks
snikwad is online now   Reply With Quote
Old 10-22-2009, 03:51 PM   #2
snikwad
The Sacred Seven
1. A typical gasoline engine has a throttle plate. This unfortunate feature restricts its cylinders from completely filling up with air, except at wide-open throttle. This creates a vacuum in the intake manifold and pumping losses for the engine. A diesel, on the other hand, allows its cylinders to take full breaths of air during every intake stroke and instead relies on increasing the amount of fuel to create torque. The average gasoline engine spends 16 to 40 percent of its total power on overcoming its own air intake restriction (throttle). The word "throttle" is exciting for some reason. Perhaps with more knowledge, its meaning will change to what it represents-a wheezy and inefficient way to control power.
2. Diesel has history on its side. In 1824, Nicolas Leonard Sadi Carnot wrote the book Reflections on the Motive Power of Fire. It answered the question: How much work can you get from a certain amount of heat? He found the amount of work was not infinite and devised a theoretical ideal engine, which laid the foundation for the study of turning heat into mechanical energy. Carnot influenced Rudolf Diesel, and that is why his engine had such a high compression ratio.
3. Diesel engines have a higher compression ratio. Gasoline engines wish they could match diesel's 17:1 to 20:1 ratio, but if they push it past 10:1 (approximate), a gasoline engine's air-fuel mixture detonates before it's supposed to and could destroy the engine. The reason higher compression ratios equal more power is because of the increased cylinder pressure they offer. Let's say you have two identical single-cylinder engines with different compression ratios. If you added the same amount of fuel to each engine, you would get more horsepower from the one with a higher compression ratio. Plus, the lower-compression-ratio engine has more combustion-chamber surface area, which gives the heat more area to escape, instead of pushing down on the piston. Less waste heat equals more horsepower through greater efficiency.
4. A diesel runs leaner air-fuel ratios than a gas engine. Run a gasoline engine too lean and there will be problems like overheating, loss of power, and a non-functioning catalytic converter. In the worst-case scenario, a gasoline engine seizes and the catalytic converter gets destroyed. In order for a modern gas engine's catalytic converter to work properly, it needs a minimum 14.7:1 air-fuel ratio. What's more amazing, is gas engines dump excess fuel under wide-open throttle to cool combustion. A diesel is just the opposite. When fuel is added to the engine, the exhaust gas temperature goes up, and when it runs lean, the temperature goes down. At idle its possible for a diesel engine to run an air-fuel mixture as high as 100:1, and the worst that can happen under these conditions is the engine stalls due to lack of fuel.
5. A diesel's exhaust system will last much longer than a gasoline engine's exhaust system. Remember how we just said a diesel runs leaner? An added benefit is less water in the exhaust system. Water corrodes, so having dry exhaust is key to long exhaust pipe life. Water is not in fuel, but hydrogen is, and it combines with oxygen from the air during combustion to produce water vapor. If the outside air temperature is low enough, condensation occurs inside the pipe(s) and muffler(s), rusting them from the inside out. LexCarb LLC came up with an engineering solution to capitalize on this situation and it is called an On-board Water Recovery Unit. The Army quickly took notice, since it would help with logistics, specifically providing EPA-approved drinking water. Another use includes fueling an onboard hydrogen generator.
6. People who need performance need diesel. Take a look at those who do serious work-what they have in common is diesel power. For example, the military, trucking, railroad, mining, construction, and aviation industries all use diesel fuel. The United States is the only country in the world dominated by gasoline. In fact, we use more gasoline than the rest of the world-combined!
7. Diesels beat hybrids. The only way a gasoline-powered car can compete with the fuel economy of a diesel is when it is paired with an electric motor. Like all electrical devices, an electric motor produces an electromagnetic frequency (EMF). EMF has been linked to causing all kinds of health problems, including cancer. Imagine truck drivers sitting right on top of this device most of their lives. There might be a shield of some type to protect people in the future, but for now, it's drive hybrids at your own risk.
Need LED lights?.
Old 10-22-2009, 03:58 PM   #3
jtmoney2k27
My Ride: p.o.s.
I love diesel cars. I'm actually looking at the diesel A3 for my next car.
What we acquire without sweat, we give away without regret
jtmoney2k27 is offline   Reply With Quote
Old 10-22-2009, 04:54 PM   #4
Krizzy TanG
My Ride: 320ci
Lol funny thread
http://forum.e46fanatics.com/signaturepics/sigpic89655_1.gif
<a href=http://forum.e46fanatics.com/signaturepics/sigpic89655_1.gif target=_blank>http://forum.e46fanatics.com/signatu...pic89655_1.gif</a>
Krizzy TanG is offline   Reply With Quote
Old 10-22-2009, 05:03 PM   #5
Skeeter
Skeeter's Avatar
My Ride: 2004 330ci
Send a message via AIM to Skeeter
335d
for
the
win
Skeeter is offline   Reply With Quote
Old 10-22-2009, 05:03 PM   #6
howie
My Ride: CLK55 AMG, E90 335i
Send a message via AIM to howie Send a message via Yahoo to howie
Still wouldn't push a diesel till i was about 50 years old
howie is offline   Reply With Quote
Old 10-22-2009, 05:31 PM   #7
jacques chirac
My Ride: nothing
Death to diesel. In my whole life, I have seen 5 330I E46. 90 % 320d here.
Smelly Cheese FTMFW
Originally Posted by Sponger View Post
jacques chirac, thank you for blessing this thread with your french self, you crack me up. :lmao: :lmao:
jacques chirac is online now   Reply With Quote
Old 10-22-2009, 05:50 PM   #8
czechchamp
My Ride: is paid for
^ lol
Yeah I don't care for diesel cars either. Too boring
2001 330i Sport manual
Clear corners
iPod IceLink
Stoptech Stg II
H&R Cup Kit
18's ASA AR1's (Staggered)
M3 steering wheel
Matte black grills
LED tails
czechchamp is offline   Reply With Quote
Old 10-22-2009, 06:24 PM   #9
VillanovaGrad
My Ride: Z4 3.0si
diesels rev too low though...
8000rpm feels ridiculous in a gasoline car
VillanovaGrad is offline   Reply With Quote
Old 10-22-2009, 08:07 PM   #10
Tangent_
My Ride: '01 330i
I like diesel and at some point will get a diesel car for a commuter, but there's no way I can agree with this. Diesel exhaust nauseates me. I don't like any exhaust smells, but diesel is 1,000 times worse for me...
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 10-22-2009, 08:08 PM   #11
snikwad
Stubbourn fools.
Need LED lights?.
Old 10-22-2009, 08:13 PM   #12
StupidGermans!
My Ride: my ride
335d
getting mine next spring
StupidGermans! is offline   Reply With Quote
Old 10-27-2009, 03:07 AM   #13
Sync Wireless
My Ride: 4runner, GT-R, MSM
snik, i agree diesel > gas
i recently saw the light. Here is the replacement to my 4runner (i want a white one though):
Sync Wireless is offline   Reply With Quote
Old 10-27-2009, 04:49 AM   #14
mkodama
mkodama's Avatar
The longest response EVER!!!!
My thoughts on this article
False, just a biased opinion as a gasoline engine can do the exact same things.
Agreed, definite advantage of diesel.
Not the diesel that is more efficient, since it is just fuel, but the efficiencies of a compression ignition engine. But despite the additional efficiency, there are much higher particulate levels.
Autoignition temperatures are much higher for diesel, but once it gets hot enough to catch fire, it acts just like gasoline. Also the fact that it doesn't evaporate and will stay around much longer poses problems as well, for example spilled gasoline will evaporate and be very dangerous for that relatively short time and then be gone, but the diesel will sit for much longer, making it a lesser threat, but over a longer period of time. It is still fuel after all.
The Army also uses gasoline and kerosene. This is a fact that doesn't make any fuel better or worse.
The Navy also uses gasoline, kerosene, and lots of nuclear power. Again, this is a fact that doesn't make any fuel better or worse.
Along with gasoline and others. Again, this is a fact that doesn't make any fuel better or worse.
Not all, but most. Not a very good argument because you can say the motorsport industry uses mostly gasoline. Different fuels have different specialties. Again, this is a fact that doesn't make any fuel better or worse.
The aviation industry uses a lot more kerosene and gasoline. Again, this is a fact that doesn't make any fuel better or worse.
Also other fuels. Again, this is a fact that doesn't make any fuel better or worse.
Also other fuels, some indirectly nuclear being electric and getting their power from nuclear electric power plants. Again, this is a fact that doesn't make any fuel better or worse.
False, definitely not any type of "oil based fuel". Many industrial diesel engines aren't very picky with their fuel, but from case to case, may require more specific and limited types of fuel. "Clean diesels" require only specific fuels to prevent fouling their exhaust post treatment equipment and can often be more difficult to find than gasoline.
And just as easy as a gasoline-electric hybrid engine. The only thing is that a hybrid vehicle also comes with a battery pack that is difficult to recycle, but that's irrelevant to making it better than other internal combustion engines.
Depending on the engine, and same applies to other types of engines.
Comparing incomparable sources again; engines to entire vehicles. If a diesel truck had a flatbed full of batteries in the back to power a bunch of interior electronics, same cause applies to a diesel truck. But either way, cars can always be given away as someone will always want the parts.
False. Yes they do unless it is a working class vehicle.
Also with recent technology, gasoline can be made from processed plastics and tires and other discard.
So can mufflers and catalytic converters. lol
False. Yes, diesel does contaminate oil quite a bit and that is the reason for special diesel specific oils with extra detergents.
lol wut? And what about the entire power/combustion stroke?
False, common gasoline engines use more fuel at startup to warm up the catalytic converters and engine, but definitely not "large amounts". Yes, you can get good gas mileage in stop-and-go driving with selective engine shutoff, which can be difficult with diesels since they are more susceptible to cold engine starting. Diesels in general have more difficulties with cold weather since the fuel is much thicker as well as a compression ignition engine requires a minimum temperature to inside the engine to even work.
Definitely a good perk for diesel engines since you don't need as much gearing/gears to make similar torque with many other types of engines.
Well, that's assuming you consider a spark ignition system complex, and also considering you have never have problems with the glow plugs to get a cold diesel engine started. Not a very good argument.
I'd like to see more info on this, but in general, all internal combustion engines create carcinogens in their exhaust. Due to the more common emissions treatment systems on gasoline engines, there are extremely low harmful substances coming out of many of todays gasoline engines, and I would argue less if I had more information to support myself.
True, but there are other things you get to worry about that a gasoline engine may not worry about.
k?
Cool story Hansel. But not surprising. For large industrial applications, which usually require the largest engines, diesel is usually superior.
Explanation to this one? It makes no sense. Compared to gas, both float on top of the water, one sticks to things and suffocates, while the other doesn't but is more volatile. I call falseness on this as it seems much more like a myth.
Depends on what kinda a vehicle, and where in the world, etc... Quite often not true.
Same goes for mechanical fuel injection system or a carburetor. But in general most modern cars won't work with out power, diesel or not.
Agreed
Agreed hear too, lol
The burning of anything can create deadly levels of carbon monoxide, CO2, and other gasses that restrict the bodies absorption of oxygen.
Didn't you just argue in 22 and 23 that only air is compressed in a diesel engine and imply diesel burns right away and doesn't even get on the cylinder walls? lol, and with direct injection gasoline engines, the same would apply to that as a diesel.
Hard to believe, but I won't go against it with my data. Always believable that one type of engine is better than another type of engine at a specific job. Doesn't make either fuel better than the other overall.
True.
Likely true, but electric motors are far more efficient than internal combustion engines, but many batteries can be recharged with renewable energy, while the diesel fuel is one time use.
No objections hear. Diesel definitely has its up.
Troof. Some argued that the rules were slightly biased and as a result diesel rules are becoming more and more strict.
Umm, what? lol, how is that remotely useful or truthful information? If you are in the correct gearing, any engine can make it up a hill without stalling, regardless of size or fuel.
To strictly respond to that that, false. Often higher levels of strength and safety margins did help many years ago. Unlikely difference in modern day engines.
Who didn't build or engineer something to improve at least part of mankind?
No properly made engine will interfere with radios, communication devices, or pacemakers.
Depends on the engine and location, but some diesel engines can't run on vegetable oil. For example, in cold climates, vegetable oil will solidify, making the vehicle until the entire vehicle is moved to warmer surroundings
Waste heat, yes, noise, that is more dependent on other factors.
It also is a carcinogen. woo!
This is all part of the extra energy content and features of a compression ignition engine that you already stated.
MY 330i FOR SALE - $4000 WITHOUT WHEELS
Downloadable E46 Owner's Manual - BMW Oil Info - Find Any BMW Part Number - Lookup Any OBD2 Code
For Sale:
AUTOart and UT Models die-cast model cars - Goodridge Stainless Braided Brake Lines - Black Coupe Sports Seats (Used)
PM me for details for any of the above.
mkodama is online now   Reply With Quote
Old 10-27-2009, 04:58 AM   #15
Acarder
My Ride: 04 6MT 330i, 328i
Finally, its about time someone took the time to refute that Miles. It doesn't help that like 10 things are exactly the same as well.
- Matt
Acarder is offline   Reply With Quote
Old 10-27-2009, 08:42 AM   #16
joem
Modded ///Member
My Ride: '07 RS4, '64 VW Bus
the one about the 100,000 gallons and the fish basically ruins this article for me. redic.
joem is offline   Reply With Quote
Old 10-27-2009, 08:46 AM   #17
Rush4theYehO
My Ride: XI fts(now)
I'd rock a diesel over a friggin hybrid. Those Benz E class diesels are pretty nice.
Rush4theYehO is offline   Reply With Quote
Old 10-27-2009, 08:50 AM   #18
mistrzmiasta
My Ride: 330ci,07 335i,yzf600
Send a message via AIM to mistrzmiasta
carbon monoxide = CO not CO2
Rogue Pulleys,Ebay Headers,K&N Intake,Rogue RSM's,Eibach Pro Kit + Pro Dampers,Zimmermann Drilled Rotors,Euro-Spec Strut Bar,VM Csl's ,M steering wheel,CSL Front,SRS Rear ,M3 Hood , Replica M3 Autofold Mirrors ,M3 Interior Swap,Csl Trunk ,8000K Predator Chromiums ,8000K HID Foglights ,Smoked Corners And Rears ,Matte Black Grill ,///M Shift Knob ,Pioneer Avic D3 , Auto==>Manual Converted ,Fidanza LW Flywheel,,UUC TSE1
mistrzmiasta is offline   Reply With Quote
Old 10-27-2009, 09:11 AM   #19
SteveX82
My Ride: 2001 325i
Originally Posted by mistrzmiasta View Post
levels of carbon monoxide, CO2, and other gasses ......
The author was listing the names of different emissions....
SteveX82 is offline   Reply With Quote
Old 10-27-2009, 09:19 AM   #20
Rayce185
Unbanned User
Rayce185's Avatar
My Ride: Constant WIP
Welcome to last century. We have been using (turbo charged) diesels in our cars for decades.
Rayce185 is offline   Reply With Quote
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
