Old 10-27-2009, 08:59 AM   #1
SilverBullet99
My Ride: 323ci
Puzzled...ideas anyone?
I was watching that wonderful little gauge at the bottom of our gauge cluster, the one that indicates your fuel consumption, while I was driving last week. Coming down my off-ramp, I put the car in neutral to see if the needle would indeed drop to zero...which it did. But right before I came to a complete stop at the intersection, car is still in neutral, it jumps up to about the half way mark for a split second and then falls back to zero.
Any ideas as to why?
In other words, what is causing fuel consumption when the car is in neutral, and only the brake is applied? Or have I just answered my own question?
"Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, your body thoroughly used up, totally worn out and screaming, "Woo hoo! What a ride!"
SilverBullet99 is offline   Reply With Quote
Old 10-27-2009, 09:02 AM   #2
Drewfus2101
My Ride: '03 330i
I'm pretty sure that gauge is operated off of engine vacuum. So at very lost speeds or idle it will jump around some. I have noticed that mine will do some weird jumping like you mentioned at very specific times. So I'm pretty sure that it is normal. If you watch it more, you'll notice it doing what you said more often.
Originally Posted by bmwbun View Post
Prolly switch back to M1 5w-30 afterward though. I like the sound it makes when it leaks through my VANOS seals.
Drewfus2101 is offline   Reply With Quote
Old 10-27-2009, 09:07 AM   #3
BMW#1_323i
My Ride: Slow but satisfying
Ummm, it actually should have gone to 50 not 0? 0 would indicate an extremely high rate of acceleration, meaning 0 MPG, whereas, the other end (50) would indicate that you are using very little fuel. Just an observation.
BMW#1_323i is online now   Reply With Quote
Old 10-27-2009, 09:08 AM   #4
zhp pilot
gnillort
zhp pilot's Avatar
My Ride: Is Missing Something
Fuel has to be supplied when in neutral or idling to keep the engine running. If you're traveling at high speed and in neutral, the fuel used as you travel 1 mile (coasting) is very low, but as you slow down the amount of fuel needed for that same 1 mile goes up. The actual amount of fuel per unit time doesn't change but it takes longer to go 1 mile. That's why your fuel consumption expressed in MPG goes down the slower you are going while in neutral.
'04 Silbergrau Metallic ZHP 6MT
Click sig picture for the most recent photos of das Auto.
E46Fanatics Stickers
Beemer Evolution
zhp pilot is offline   Reply With Quote
Old 10-27-2009, 09:51 AM   #5
GT172I
My Ride: '04 330Ci
^ This
GT172I
GT172I is offline   Reply With Quote
Old 10-27-2009, 10:40 AM   #6
David F
My Ride: 323i, 740iL, 633CSi
Vacuum is probably the only thing the computer does not measure to calculate MPG. The engine/car does not have a vacuum, manifold absolute pressure, or other similiar type of sensor.
David F is offline   Reply With Quote
Old 10-27-2009, 10:45 AM   #7
SilverBullet99
My Ride: 323ci
Thanks for the lesson, sounds pretty sound to me.
Old 10-27-2009, 10:45 AM   #8
mick22589
My Ride: 2001 330i
the gauge operates off of the vaccum of the engine. ergo more sucky=more gas.
mick22589 is offline   Reply With Quote
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
