Old 11-01-2009, 07:09 PM   #1
brads2002
My Ride: 2003 330i ZHP
Help-Hit big hole on hwy
Hi folks
Can someone take a look at their strut towers for me on a 330i (mines a 2003)? My passenger side one is slightly rounded on the top but the drivers side is totally flat. I hit a hole in a construction zone that took out one of my wheels bad. I am hoping I didn't do any other damage. If someone could take a look it would make me feel a lot better knowing what it is supposed to look like. There is no cracked paint or anything so i am hoping i am OK.
Thanks a lot.
brads2002 is offline   Reply With Quote
Old 11-01-2009, 07:19 PM   #2
Acarder
My Ride: 04 6MT 330i, 328i
Passenger one sounds like its mushroomed. Check if all the bolts are flush and parallel.
I wouldn't be overly concerned, they just need to be flattened out and then you need an alignment and a strut brace which are cheap engine candy that stop it from reoccurring.
- Matt
Acarder is offline   Reply With Quote
Old 11-01-2009, 07:24 PM   #3
brads2002
Ah so it is supposed to be flat? Funny thing, my strut brace is on its way from Cali right now. I ordered one tuesday. Figures!
Old 11-01-2009, 07:28 PM   #4
Acarder
Yep, both my cars have perfectly flat ones (this thread made me check ). You wont be able to fit the strut brace if the bolts aren't perfectly flush, although if it still goes on even though they're a little off I guess that doesn't matter. If you can visibly see a bulge though I would get it fixed before attempting to strengthen it. These cars do have pretty weak towers to be honest, I think I might pick up a brace just in case.
- Matt
Old 11-01-2009, 07:36 PM   #5
brads2002
Thanks for checking Matt. I am going to contact the construction company doing the work. They shouldnt have left the road like that. M cross spoke down the tubes.
Old 11-01-2009, 07:41 PM   #6
brads2002
Matt, the brace i ordered from here. Looked pretty nice for short cash. Rotora E46 Non-M Front Strut Tower Bar enter in AFE in the coupon box and it gives you 20% off. It ended up being 60 something bucks.
http://eurobahn.us/index.aspx
Old 11-01-2009, 08:07 PM   #7
Spyder_Venom
My Ride: 325CI
Bummer to hear that - but these strut pockets aren't that strong and this is a some-what frequent occurrence on older (well used?) track E36 and E46 cars. I'm not too sure what the construction company will do, but your insurance company would likely cover it under collision.
Spyder_Venom is offline   Reply With Quote
Old 11-01-2009, 08:31 PM   #8
brads2002
yeah thanks, i will call my ins co too. I would hate to have it go against me though. I am hoping that the cons company will pay for the damages. They really shouldn't have left the road the way it was with nothing marked. I called the state and the lady said they will usually help the driver work things out with whomever they contracted to do the work. Anyone else been in this situation before?
Old 11-01-2009, 09:35 PM   #9
Spyder_Venom
My Ride: 325CI
I went through it once, and was left to deal with my insurance company. Not sure how your laws are structured in NH, but in MN, you assume all risks while traveling on the road. Even though the construction company was the primary contributing factor, you could have driven slower to avoid the issue (is the way they look at it). So, unless it was something that was completely unavoidable (which I don't think is ever possible), they'll consider it a hazard of driving on the road. My insurance company did go after the construction company's insurance company - not sure if they ever got anything, but it was beyond my mere mortal status to even get one of them to call me back.
Old 11-02-2009, 12:40 AM   #10
xi_ter
My Ride: 2003 325xi
Take a dated picture of the hole if it's still there in the hwy. It might help to make a recovery for the damage.
Old 11-02-2009, 09:33 AM   #11
David F
My Ride: 323i, 740iL, 633CSi
If the strut tower is mushroomed, don't loose too much sleep, it is easy to fix. All you need is a new strut bearing (yours is now bent) a block of wood (2x4) and a two pound hammer (or bigger). First, remove the strut (just remove the brake caliper, pinch bolt, and three strut bearing nuts. But, before you remove the three bearing nuts, use a mallet and knock the steering knuckle loose from the strut tube. Now, remove the three nuts, push the steering knuckle down with your foot and the strut will clear the tower and wheel well. Replace the strut bearing. Strategically place the block of wood on the mushroomed strut tower and beat it down flat with the two pound hammer. That is all there is to it.
When I purchased my '99 323i, both towers were mushroomed. Same thing with my '05 MINI Cooper S. I used aluminum reinforcing plates (Craven Speed) on the MINI as the MINI's are by far worse at mushrooming. Not sure if plates are available for the E46, but a strut brace will certainly help, but pricey.
David F is offline   Reply With Quote
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
