Welcome to the E46Fanatics forums. E46Fanatics is the premiere website for BMW 3 series owners around the world with interactive forums, a geographical enthusiast directory, photo galleries, and technical information for BMW enthusiasts. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
#1 |
Loud Ticking Sound - Help please...
I own a 2000 BMW 323i with 113,000 miles, so here is my problem..,
Recently I had my uncle replace the coolant tank because the previous tank was damaged and was leaking (crack in the tank), once the new tank was installed the next day it started leaking again (Coolant light went ON). I thought no big deal and I filled the tank with coolant (Light went OFF) and started driving like this for about a week. Now there's a new problem that I'm dealing with and cannot find out what it is. When the car is running it makes a very loud noise (sounded like a fan was hitting something plastic, but that wasn't it). I took off Radiator, Fan, 2 Belts (Engine & A/C), Coolant Tank, and checked if the noise was gone but the problem wasn't fixed and still made a loud noise. So I turned the car off and checked the all the pulleys and it seemed they were working perfectly. This all seemed to happen since the Tank was replaced... Thanks so much! ![]() ![]() ![]() |
#2 |
i think its something to do with the exhaust or air con maybe ?
mine makes a noise when started but then goes off and the previous owner told me its something to do with the exhaust and air gasses and the air con setting itself ?? |
#3 |
Check Spark PLugs
Check your spark plugs. I had 1 loose plug that caused the car to tick. I tightened it up and noise went away.
#4 |
Here's a video of what I'm hearing maybe this will explain a lot better.
#5 |
Waterpump is about to go..impeller coming apart! might as well get one! My friends just did the same thing. Improper circulation of coolant also reason your expansion tank failed!
#6 |
alternator pulley???
#7 |
Waterpump and Alternator pulley aren't the problem I've checked. I have had 2 different mechanics come check out the car one said it was the starter, and the second says its the Flywheel bearing...
