Go Back   E46Fanatics > Tuning & Tech > Bavarian Soundwerks' Mobile Electronics Forum
Sponsored by Bavarian Soundwerks
Old 11-04-2009, 06:50 PM   #1
lup31337
My Ride: 318d
Cutting a hole in the metal door frame
I've installed few years ago a pair of hertz energy speakers in the factory location (on the plastic door panel). It's a perfect fit, almost too perfect since the magnet is touching the metal door frame. I read somewhere here that by cutting a hole in the back of the speaker it will work in a bigger volume, thus the speaker will reproduce low frequences better. When i told the guy who installed my speakers to do so, he said that the window glass is too close and it will be blocked by the speaker magnet. Is this true ? The magnet will probably go inside a bit since it's kinda squeezed between the metal frame and the plastic panel but not by much . Doing this i will probably lose some of the rattles since the speaker will no longer touch the back side of the door. Anyone done this ? Was my installer right or wrong ?
lup31337 is offline   Reply With Quote
Old 11-04-2009, 08:03 PM   #2
Haberdasher
My Ride: 2001 330ci
I found a few threads on here describing where people have left the speaker mounted on the door panel and still cut the hole into the door and experienced better sound quality. So mounting the speaker to the door may not be necessary. However, there is some space created for additional mounting depth by cutting the doors without interfering with the window.
Some threads:
http://forum.e46fanatics.com/showthread.php?t=317339
http://forum.e46fanatics.com/showthread.php?t=443244
-Dave
Haberdasher is offline   Reply With Quote
Old 11-09-2009, 06:18 AM   #3
champ222
My Ride: 330CI
you will gain a few mm of depth by cutting the doors, but not a lot, maybe 10mm at the most, so it would depend how tight it is in there at the moment if you'll have problems. although if youve got the door card fully on, it probably wont go much further anyway.
i say give it a go... or better yet, mount the speaker to the door instead of the door card.
champ222 is offline   Reply With Quote
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
