Welcome to the E46Fanatics forums. E46Fanatics is the premiere website for BMW 3 series owners around the world with interactive forums, a geographical enthusiast directory, photo galleries, and technical information for BMW enthusiasts. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
The Tire Rack's Tire & Wheel Forum
Use this forum to discuss anything in relation to wheels to tires to offsets. Sponsored by The Tire Rack |
#1 |
Enkei RPF1 wheels (18x8.5ET40) w/ Hankook V12 evo tires (255/35/18) all around
Anyone know if this setup (which is light and should provide above average grip) would work on a 4 door E46? In particular, will there be any rubbing issues up front with 255s mounted on a 8.5ET40 rim?
![]() This looks like a winning combination from a price vs. performance ratio point-of-view. ![]() Anyone have this setup? Comments welcomed…. |
#2 |
255s sound a bit wide... I have a coupe, and I have the same wheels sitting in my back yard waiting to be mounted when I get my car back
The 225s I have on there are stretched just a tiny bit, and they seemed to sit pretty flush on the front when I test fit one. They were the recommended size from TireRack.I can give feedback in regards to a coupe when I get my car back next week.
#3 |
when i get wheels im getting 17x9 et40 with 255s all around...i have a coupe but i dont believe you will have issues. if youre worried 245's would suffice
#4 |
You are good to go with that sweet sweet setup
harry
![]() VMR VB3 | 19x9.5 et30 | 19x10 et38 | 235/35's |
#5 |
Are you guys using this kinda setup fo street use or track?
Filbert Originally Posted by nawmean? I know I sound naive, but some of the advice I've taken from this board has helped my life quite a bit |
#6 |
i dont have the setup but it can be used for both
#7 | |
I ran 245/35x18's all around for a while. That worked ok, lowered the car a touch, no clearance issues, but it did tramline more. Mostly I've run 225/40x18s all around, and that drives very nice on the street, and track handling is nicely neutral, but having a bit more rubber on the road would be great. My offsets are ET42 and ET35 (SSR & BBS, respectively) if memory serves. Somebody give us an answer, please!
B On Trak |
#8 |
My Ride: 1:25 Scale Enzo
9.5 +35 has been done all around has been done on a sedan with 255's without a problem. Check out forum member GunMoto.
-Charles@VMRWheels
Charles @ VMR Wheels Email - charles@velocitymotoring.com Tel - 714.442.7916 ext 107 [24 Hour Live Inventory] [**NEW VMR V701 Straight Spoke**][**NEW VMR V718 Signature Mesh**] ![]() [V713 19"] [VMR Wheels Gallery] [Connect with us on Facebook!] |
#9 |
Great feedback...
I know several guys w/ZHP wheels are running four (4) rear wheels all around w/o problems. The rear wheels are 18x8.5ET50's.The reason for the "square" setup is to reduce under steer. Staggered setup looks nice but it's quite impractical (can't rotate tires which limit tire life/wear). I assume ET40s shouldn't be a problem up front but am not sure. The only problem with using ZHP wheels (M135s) is that they are quite heavy (28 lbs) when compared to aftermarket wheels like the RPF1s (18 lbs). |
#10 |
Swedish - let us know how the fitment works up front. And if possible, take a pic. I can't seem to find many non-M E46 pictures with RPF1 wheels except for either M3s or Z4s w/ 19 inchers.
#11 |
Bartender - nice profile/stance***8230; what setup are you using?
#12 |
Tilo - I was looking to use this setup for both street and autox.
#13 |
Bwoodson - nice choice of lightweight wheels***8230;
#14 |
Charles - that setup worked w/o mods? Nice!
#15 | |
![]() I'll be sure to link to them here along with pics of the fender gaps.
#16 |
It required fender rolling but it wasn't a big issue.
![]() -Charles@VMRWheels
#17 |
I’m ready to pull the trigger this week to get this setup
but have not heard back from Tirerack (they sell both wheels and tires) to see if this combo works. If the 255/35/18 tire fitment is questionable (particularly up front), maybe 245/35/18 square setup is a safer play.Hmmm... I wonder if the BMW caps work with these wheels ![]() ***** Anyone with RPF1s, please post some pics up, especially non-Ms.******* |
#18 | |
-Charles@VMRWheels
