Old 11-09-2009, 03:37 PM   #1
jtmeyer
My Ride: 325CI
Smoke From Engine Bay
Hey guys, once in a while I will notice a smell while driving that kind of smells like burning plastic or something. Last night I opened the hood to take a look and there was a fair bit of white smoke coming from behind the engine on the passenger side as shown on the picture. Any ideas on what this could be? Also when I went to close the hood my drivers side kidney grill decided to fall out; is there any way to zip tie it in place or something, or do I just have to buy a new one?
jtmeyer is offline   Reply With Quote
Old 11-09-2009, 03:40 PM   #2
|AW|NATALIE
My Ride: 2002 with <80K Miles
Just buy new chrome kidneys or better yet black grills. Not that expensive. Only ziptie for a temporary fix while you wait for the new grills to arrive in the mail
|AW|NATALIE is offline   Reply With Quote
Old 11-09-2009, 03:42 PM   #3
rhm325i
My Ride: 02 BMW 325i
It is pretty typical for a m54b25 too leak oil from the vcg where you illustrated
rhm325i is offline   Reply With Quote
Old 11-09-2009, 03:51 PM   #4
MysticBlau330Ci
My Ride: 330Ci '04
seems like a little oil is leaking from your valve cover gasket onto the exhaust. That will cause smoke. Give your engine a nice clean up/wash and look for oil wetness in that area.
MysticBlau330Ci is offline   Reply With Quote
Old 11-09-2009, 04:44 PM   #5
Bimmerboi325i
My Ride: 325i
i think i may have the same problem, on the way to school today my a/c shutted off completely even tho i have it on max and when i lifted the hood i noticed white smoke comin from the passenger side, although the thermostat was reading normal. I'm also experiencing the burnt smell whenever my heater is on...any suggestions?
Bimmerboi325i is offline   Reply With Quote
Old 11-09-2009, 06:03 PM   #6
pat
My Ride: is waiting for boost
Send a message via MSN to pat Send a message via Skype™ to pat
I'd like to keep an eye on this one... I'm having a similar problem. At first I thought it was due to my new clutch but I also got the valve cover gasket done.... oil leak?
FS: OEM rear bumper, hood, trunk
pat is offline   Reply With Quote
Old 11-09-2009, 06:09 PM   #7
SaaDiesel
My Ride: 02 330i ZSP
That is exactly where my valve cover gasket started to leak, right where the O2 sensors are Change it asap!
E46-7 years STRONG
ZSP/ZPP/ZCW
BFP Intake, Euro Cooling Ducts, Smoked Lenses, 8000K HIDS
Matte Black-Grill, Headlight, Window, & Body Trim
SaaDiesel is offline   Reply With Quote
Old 11-09-2009, 06:20 PM   #8
mattcarle21
My Ride: is Breakin My Wallet
Def VCG. That's the infamous spot.
Photobucket
mattcarle21 is online now   Reply With Quote
Old 11-09-2009, 06:24 PM   #9
Define ///M3
Define ///M3's Avatar
My Ride: Dreams of an AA kit.
VCG. fosho
AKA Huggy1989
"I expect to pass through life but once. If, therefore, there can be any kindness I can show, or any good thing I can do to any fellow being, let me do it now, and not defer or neglect it, as I shall not pass this way again."- WP
Define ///M3 is offline   Reply With Quote
Old 11-09-2009, 09:37 PM   #10
jtmeyer
My Ride: 325CI
Okay, if there's a consensus that it's the VCG, is it dangerous to drive the car the way it is? I'm really busy with school right now and don't really have the time to take care of it just yet. I'll have more time in a few weeks. Also where do you guys recommend the best place to get replacement parts?
Old 11-10-2009, 10:49 AM   #11
Sandman316
Sandman316's Avatar
My Ride: 2000 328Ci
I have the exact same problem, white smoke with a plastic/rubberish smell coming from the hood and through the heat vents! I'll be ordering my replacement VCG this week from www.getbmwparts.com. It's only $30!
I'm going to have mine installed at my local bmw shop. Do Not go to the dealership.
The VCG is shown in # 7
Sandman316 is offline   Reply With Quote
Old 11-10-2009, 03:19 PM   #12
jtmeyer
My Ride: 325CI
I know that you guys recommend changing some sort of washers as well with the gasket, does anyone have a part number for those, and how many? Also while I'm having the work done in there I might as well have the plugs changed too, will any generic plug work or is there a specific type recommended for our cars?
Old 11-10-2009, 10:24 PM   #13
SaaDiesel
Its typically not dangerous but keep an eye on your oil level, just search the DIY forum-all your questions will be answered.
E46-7 years STRONG
ZSP/ZPP/ZCW
Old 11-11-2009, 01:43 AM   #14
andypandy_e46
My Ride: 2000 bmw 323i
i have that same burn smell problem too, but theres no smoke comming out
-andrew (andypandy)
andypandy_e46 is offline   Reply With Quote
Old 11-14-2009, 05:42 PM   #15
pat
In my case... this started after the VCG was replaced.
Old 11-14-2009, 06:32 PM   #16
Solidjake
My Ride: 02 330i/03 Cayenne T
Send a message via AIM to Solidjake
Vcg
Jake - 2002 330i
Old 11-14-2009, 07:02 PM   #17
ricke46
My Ride: e46
same here, but only happened once in the last month. exactly where your red circle is. i haven't done anything about it. should i?
ricke46 is offline   Reply With Quote
Old 11-16-2009, 01:36 AM   #18
pat
Actually... mine only did it for a while and it stopped. Hasnt happened in a few weeks. I noticed when it happened, that the wiper fluid was overflowing (bubbling) from the cap.... maybe it leaked into the header?
Old 12-12-2009, 10:03 PM   #19
sahmed87
My Ride: Bmw 330ci Sport Conv
Same smell and smoke in same place is coming from my car (2001 330ci sport cabrio), Engine light has come on, my local BMW specialist says engine light is most likely 'Lambda sensor' (they reset the light and told me to come back when it turns on again, which it has now, but I have no job and don't want to go to them and pay lots), I Haven't seen them about the smell or smoke, as I have no job at the moment and I think it might be expensive to fix it, can I fix the problems myself, can anyone help me and tell me what to do, any help would be greatly appreciated. Thank you ( is it possible to replace the Lambda sensor myself? or the VGC thing? How much will it cost?, is it hard to do?, is there any way I can diagnose the car my self? does anyone know where I can get software and cables to connect my laptop to my car?) Thank you
sahmed87 is offline   Reply With Quote
Old 12-12-2009, 10:21 PM   #20
Xeek
My Ride: 2000 BMW 328Ci
khoalty.com has a great price on matte black kidneys. That's wher I got mine, they look great.
2000 BMW 328Ci
Xeek is offline   Reply With Quote
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
